Go to Post Programming humor is funny, period. - 1168Programmer [more]
Go Back   Chief Delphi > Other > VEX
Unread 26-03-2008, 17:56
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Which sensors do you really use?
I was wondering which sensors you use (especially in competition robots, but also in "fun" ones), and how they are essential to the function (or improvement) of your robot. I'm not looking for examples of, "Hypothetically you could uses an ultrasonic sensor to avoid bumping into walls" but actual examples that are proven to work, and work better than doing without sensors.
So far, the only sensors our team has used in competition are limit switches -- to stop a ring delivery device when it reaches the perfect height for a post, and to prevent a joystick-happy driver from grinding the gears. We have played with other sensors but haven't improved robot function as a result of using them.
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 26-03-2008, 18:08
Re: Which sensors do you really use?
Limit switches and shaft encoders. Haven't done too much with the others.
Unread 26-03-2008, 18:16
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
On the AdamBots FRC robot we are currently using the kit hall effect sensors mounted in the transmissions for distance measurement in hybrid. We are also using a yaw sensor to give us the heading of the robot in hybrid and we even have a one joystick drive mode based on the heading given to us by the yaw sensor.
On the fun side my dad just bought me a PIR sensor today. I'm probably going to use that to wake my robot up when someone turns on the lights or something like that. There is also SONAR sensors that I've used to judge the distance of objects like walls and table legs. I've also used an IR sensor for line tracking with lego robotics.
AdamBots.com- Winner of 7 Best Website Awards!
Unread 26-03-2008, 20:42
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
This year I used ultarsonic sensors in automomous, and also adapted the code to prevent demo robots from damaging walls. I also used limit switches and encoder.
EDIT: Forgot to mention the gyro.
Eric Haskins KC9JVH
Unread 26-03-2008, 21:29
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
Limit switch for setting up our arm movements, shaft encoders for knowing where the arm is, and my favorite... a gyro that alows us to spin (on omni wheels) and still go the same direction WHILE spinning
"Though similar in apperance, unlike a firecracker, dynamite should not be held in ones hand when lit. Ohhhh..."
Unread 26-03-2008, 23:59
AKA: Yolande
Are these for Vex bots??!!? (wistful sigh)
Unread 27-03-2008, 00:02
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Our current robot uses five sonar distance sensors, two gear tooth sensors, and an accelerometer. Amazingly it uses pretty much all of these already. Usually we put five thousand sensors on the robot and they don't get used for quite awhile. This year they were almost all used right away.
The distance sensors are for obstacle avoidance, target tracking, automatic hurdling, and wall hugging. The the Gear tooth sensors and accelerometer are used for drive straight functions, and also our hybrid mode. Plus they are used for a number of other little things.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 27-03-2008, 01:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Keep in mind people, this is in the VEX forum. The request was about what sensors you use on your vex bots, namely ones used in FTC or other vex-based competitions.
Unread 27-03-2008, 22:02
Herodotus's Avatar
AKA: David Resowski
My bad I saw it off on the feed to the right, and didn't notice which forum it was in.
Well in that case, none, as we don't participate in Vex
Unread 27-03-2008, 22:07
Encoders are there as always. I think we're using limit switches and perhaps the button switch. (yes this is for VEX)
Unread 28-03-2008, 17:36
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
We used only 2 sensors for our 2007 FTC robot. 1 limit switch, and 1 shaft encoder.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Which operating system do you use/want to use? neutrino15 Programming 17 12-01-2008 00:05
Which did you use? lukevanoort Electrical 7 26-03-2006 10:10
Which browser do you use? jonathan lall Website Design/Showcase 17 11-07-2004 17:20
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Which Drive Train Will you use? Rick Rules/Strategy 3 07-01-2002 21:49
