Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 27-03-2008, 20:40
andrew_4_life andrew_4_life is offline
FRC #0919
andrew_4_life is an unknown quantity at this point
1 joystick controls not turning properly
When I load this code, the drive seems to mess up. Going forward and back is fine, but it won't turn to the correct side. When I turn "RIGHT" it turns "LEFT", when I turn "LEFT" it turns "RIGHT"
I've also tried switching the PWN cables but that just really messed up the controls because it was going backwards.
 /*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
  *   This maps the joystick axes to specific PWM outputs.
  //pwm01 = p1_y;
  //pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
 /*---------- 1 Joystick Drive ---------------------------------------------
  p1_x = 255 - p1_y;
  p1_y = 255 - pwm05;
  pwm01 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm02 = Limit_Mix(2000 + p1_y - p1_x + 127);
We also tried this: (reversing the signs
pwm01 = Limit_Mix(2000 + p1_y - p1_x +127);
  pwm02 = Limit_Mix(2000 + p1_y + p1_x - 127);
Converting Joystick controls over to switches Japper Programming 6 27-02-2007 09:50
To function properly? Pirate_Nelly354 Chit-Chat 22 18-08-2006 21:33
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Chain..... How you do it properly? JasJ002 Inventor 12 03-06-2005 08:49
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
