Go to Post YES! I am a MENTOR. Not a chaperone. I am busy all day, I don't want to deal with the stupidity that may or may not go on at night. Besides, I might see something as a cool physics experiment, where a chaperone might see someone dropping pop cans down the stair wells. - Not2B [more]
Unread 27-03-2008, 20:40
andrew_4_life andrew_4_life is offline
FRC #0919
andrew_4_life is an unknown quantity at this point
1 joystick controls not turning properly
When I load this code, the drive seems to mess up. Going forward and back is fine, but it won't turn to the correct side. When I turn "RIGHT" it turns "LEFT", when I turn "LEFT" it turns "RIGHT"
I've also tried switching the PWN cables but that just really messed up the controls because it was going backwards.
 /*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
  *   This maps the joystick axes to specific PWM outputs.
  //pwm01 = p1_y;
  //pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
 /*---------- 1 Joystick Drive ---------------------------------------------
  p1_x = 255 - p1_y;
  p1_y = 255 - pwm05;
  pwm01 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm02 = Limit_Mix(2000 + p1_y - p1_x + 127);
We also tried this: (reversing the signs
pwm01 = Limit_Mix(2000 + p1_y - p1_x +127);
  pwm02 = Limit_Mix(2000 + p1_y + p1_x - 127);
Unread 27-03-2008, 20:43
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: 1 joystick controls not turning properly
before the 1 joystick drive portion, do this:
p1_x = 254 - p1_x
This will make the math controlling the 1-joystick drive believe that the joystick is facing the opposite direction than it is.
Unread 27-03-2008, 21:48
It sounds like you just need to redefine which direction is "forward" on your robot.
Seriously, Bongle has a suggestion that will work. You could also fix it in hardware by swapping the motor connections on the output of the speed controllers. That will make the motors run in the proper direction.
Unread 27-03-2008, 23:05
FRC #0919
I'll test out Bongle's suggestion tomorrow when I have access to the robot. But your suggestion of switching the motor connections on the output for the victors won't work because then it will drive backwards when I tell it to drive forwards. You suggestion can easily be done by swapping the PWM cables, but like I said, it makes everything backwards and still turns incorrectly though.
Unread 28-03-2008, 01:22
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
This year, for some reason, every single one of our joysticks was giving us the wrong (opposite) 0-255 numbers on the x-axis. We had to flip it in code.
Converting Joystick controls over to switches Japper Programming 6 27-02-2007 09:50
To function properly? Pirate_Nelly354 Chit-Chat 22 18-08-2006 21:33
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Chain..... How you do it properly? JasJ002 Inventor 12 03-06-2005 08:49
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
