#91
Re: surefire ways to break you robot
show optimism
#92
1. Bring every part you can to the field just in case (ATL). Murphy's Law dictates that the one gear you don't have a replacement for is the one that will break.
2. Forget to tighten loose bolts. Realize later that part of your frame is only staying together because being hit so often (Ramp Riot, it was a pretty contact-heavy year with the King of the Hill bit) bent two pieces of the 80/20 together...and that there are no tightened bolts on that corner of the robot. 2b. Fix that. Something worse will go wrong (see 1). 3. Wire a battery backwards. (Thankfully we caught this when we were checking our batteries in the shop before we tried to use it). |
#93
Use the old KOP BaneBots transmissions. Let's just NOT go there.
#94
Get picked by a good alliance.
nuff' said. |
#95
Dropping a ball on it. Directly on it.
Atlas...*tear* |
#96
short from the battery across the frame.
#97
Uhmmm... I know I'm not the only programmer that makes parts too...
Plus... I'm sure I'm not the only programmer that has fixed hardware problems with software... Quote:
![]() -q Last edited by Qbranch : 28-03-2008 at 08:12. |
#99
Let it roll off the table. (Yes they did happen and oddly enough it was nothing more than a box frame with four wheels.)
#100
#101
more way to break your robot
weight reduction rounding off corners with metal file |
#102
The other coder and I found a great way to break the bot.
For absolutely no reason whatsoever, IFI loader decided to change the file it was downloading to the bot to last years competition code. We didn't figure this out until after our next match. Before that match though, we were really freaking out. The lift wasn't responding at all, when the driving joysticks were pushed the full speed, two of the motors would reverse with for no apparent reason (we never did figure that one out). Luckily, we used mechanum wheels both years, so driving below max speed worked relatively well. No autonomous (thank god they hadnt gotten to that last year by the time they compiled this version). No lift, and no green light underglow either Its all good now ![]() |
#103
- Run hybrid mode with tether or programming cables plugged in (Seriously, I have no idea why, but it screwed up our hybrid every time we did it)
- Try to program with a homemade cable that happened to have one of the wires get yanked from one of the pins (You have never seen the RC flash so many error messages and strange patterns of lights) - Make your own field, get gripper caught in lane divider (We didn't have any lexan/plexiglass/whatever over the bars) and then turn your robot in an attempt to get it unstuck - Tweak the values for your hybrid code "Just a little bit" - Build a cart that doesn't have anything to prevent the robot from just rolling off - Run your hybrid code without first resetting the gyro |
#104
ONE OF OUR COACHES TRIPPED ON OUR FTC BOT
THAT'S RIGHT MR. GRIMES, I'M PUTTING YOU OUT THERE Last edited by NorviewsVeteran : 21-12-2008 at 15:04. |
#105
Forget to secure the battery so it falls out of its holder...and onto the main breaker.
| MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." | Mr MOE | General Forum | 0 | 03-02-2008 16:37 |
| pic: strange ways you test stuff out? | DarkFlame145 | Robot Showcase | 1 | 13-01-2008 15:10 |
| MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" | Mr MOE | General Forum | 6 | 09-02-2007 08:40 |
| What do you do when its time to take a break from building?? | Leo 1529 | Chit-Chat | 23 | 13-02-2006 00:26 |
| MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." | Mr MOE | General Forum | 3 | 15-02-2005 11:38 |
