Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 27-03-2008, 21:32
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Cim breakers tripping?
Hello. My team was having a little trouble at the West Michigan regional with the main CIM motor's breakers tripping towards the end of the match. My mentor tried to explain that as the victors heated up, resistance would rise causing a higher current draw, but that seems backwards to me.
My thought was that maybe 2 victors weren't enough to push our bot and the CIMs were being over-taxed. The bot weighs 119.2 pounds(without batteries) We are using a two wheel center drive system, 1 motor per wheel using standard toughboxes with direct drive to the wheel (no further reduction after the toughboxes). Would adding another CIM to each wheel remedy this situation? Thanks alot!
Unread 27-03-2008, 21:37
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Cim breakers tripping?
One motor : ONE victor.
What are you using on the ends of the bot for wheels? (casters, omnis, static wheels)
Unread 27-03-2008, 21:49
Hazmatt's Avatar
AKA: Matt
Elaborate... Each motor is being driven by ONE victor. The ends of the robot have castors on them.
Relax! It's only ones and zeros!
Unread 27-03-2008, 21:51
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
He is saying that your cant use more than one Victor per motor. What are your center wheels?
Unread 27-03-2008, 21:53
Hazmatt's Avatar
AKA: Matt
The center wheels are treaded 6" wheels.
Unread 27-03-2008, 21:56
Gocho's Avatar
Gocho Gocho is offline
FLL #1418
Team Role: Human Player
Gocho is an unknown quantity at this point
[quote= Would adding another victor to each wheel remedy this situation? [/QUOTE]
Each motor should only be powered by one victor, period. You can't add another one per the rules and adding one in the circuit would most likely not fix your problem. Make sure that the fans are running on the victors because they can and will over heat with extended use. The fact that it is happening at the end of the match rules out a short unless it is just bad luck...
Unread 27-03-2008, 21:58
Hazmatt's Avatar
AKA: Matt
Sorry, what I meant to say was "would adding 2 more cim motors remedy this situation"
Unread 27-03-2008, 22:05
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Assuming you are in complaince with the rules (it's hard to not be given inspections) you should only have 2 CIM motors if you are only using 2 speed controllers. Each speed controller is protected by (at most) a 40A breaker. You can't drive a (single) motor with more than one victor under the rules (this also presents some coordination problems), and the victors can handle more than the 40 A (or so) that the breakers blow at.
Keep in mind that using two CIMs as drive motors gives you half the power of using 4 CIMs. This presents a possible solution, but it is too much weight given your margin.
Since you are only using two CIM motors, you have a limit to the force they produce as well. This depends on the reduction, but if the motors are loaded too much, they will draw excess current, and thus blow the breaker.
If these problems occur late in matches, look for something heating up or binding which would present mechanical resistance. Also, look for ways to eliminate friction within the drivetrain.
However, I would suggest you see if it is merely the time of the match that coincides with the breaker blowing. Consider what the robot was doing at the time. If it was pushing into a robot (or a wall) and you have high traction wheels, this would easily cause a breaker to blow.
EDIT: Almost forgot...
If a victor overheats, its internal resistance increases. However, increased resistance would cause less current draw. If the victor was overheating, you'd have a wonderful burnt plastic smell in the vacinity of your robot. Also, you would see decreased power at the motor without the breakers tripping. If it were to overheat too much, you'll melt the transistor packages, then cause all sorts of thermal effects that would alter the doping of each transistor, rendering it unusable. (but you'd probably stop before this when you saw the smoke and (potentially) fire.)
Part of what the rules do is prevent this. FIRST knows that a properly cooled victor handling 40 A, as expected in a match, would most likely not overheat. Safety is built into the rules
Unread 27-03-2008, 22:08
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
How hot are the motors getting? 120lbs. robot, one CIM per side, direct drive off of tough box. Sounds to me like the two CIMs are having to work too hard. After they heat up, they do draw more current, and could be causing your breakers to trip.
Unread 27-03-2008, 22:11
Gocho's Avatar
FLL #1418
I have seen teams get into pushing matches with only two CIMs and no gear down and do fine and not blow breakers. Check for shorts and make sure that the connections on the power distribution block are tight because they come loose easily. Did it happen at the same time during every match? Did you ever regain power to that motor? and was it both motors or just one?
Unread 27-03-2008, 22:14
Hazmatt's Avatar
AKA: Matt
I really have nothing to compare the heat of the motors to, being on a rookie team and all, but The CIM's were hot. If adding more motors is a necessity, we can always shave a bit off of our 30 lb counterweight.
Unread 27-03-2008, 22:15
Hazmatt's Avatar
AKA: Matt
It seemed like both motors, and I suspected breakers because if I let the robot idle for a few seconds, it would regain full power. The breakers seemed to trip always towards the middle to the end of the match.
Unread 27-03-2008, 22:34
A 40 Amp breaker doesn't magically break at exactly 40 Amps; the trip time is an imperfect function of its internal heating, which is a function of current. When the metal strips inside reach a certain temperature, they bend and push away from each other.
CIMs can draw upwards of ~120Amps if you stall them. At that draw, the breakers should pop within a few seconds. But you aren't stalling them, you are simply asking a lot of them. It is very possible you are drawing 60-80 amps many times a match.
The first time you do this, your breakers won't trip because they are cold. Each time after that, you run an increasing risk of popping as they heat up.
Adding two more CIMs will definitely help the situation. In the mean time, you can reduce the load on your motors by reducing any friction you may have in the transmission.
Unread 27-03-2008, 22:41
Hazmatt's Avatar
AKA: Matt
Okay. Thank you.
Unread 28-03-2008, 00:12
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
You sure its the breakers tripping and not the robot simply resetting due to a lack of battery power? keep your batteries in order
I cant imagine that you would have the motors under so much stress that their breakers would pop in a 2 minute match... im thinking something else is wrong. did this ever happen in practice?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Tripping breakers GMKlenklen Technical Discussion 13 19-12-2006 09:43
Tripping 120Amp Andy144 Electrical 26 01-04-2003 09:28
Circuit Breakers: Tripping Al Skierkiewicz Electrical 7 10-04-2002 12:40
tripping breakers/burning motors Ben Mitchell Motors 16 04-02-2002 13:31
