Go to Post it's flattering, but a little scary, because I don't know if I'm ready to be an inspiration! - MissInformation [more]
  #91   Spotlight this post!
Unread 27-03-2008, 16:09
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
Re: surefire ways to break you robot
show optimism
  #92   Spotlight this post!
Unread 27-03-2008, 17:33
mgreenley
Posts: n/a
1. Bring every part you can to the field just in case (ATL). Murphy's Law dictates that the one gear you don't have a replacement for is the one that will break.
2. Forget to tighten loose bolts. Realize later that part of your frame is only staying together because being hit so often (Ramp Riot, it was a pretty contact-heavy year with the King of the Hill bit) bent two pieces of the 80/20 together...and that there are no tightened bolts on that corner of the robot.
2b. Fix that. Something worse will go wrong (see 1).
3. Wire a battery backwards. (Thankfully we caught this when we were checking our batteries in the shop before we tried to use it).
  #93   Spotlight this post!
Unread 27-03-2008, 20:39
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
Use the old KOP BaneBots transmissions. Let's just NOT go there.
Madness?
THIS IS F.I.R.S.T!
  #94   Spotlight this post!
Unread 27-03-2008, 21:00
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Get picked by a good alliance.
nuff' said.
  #95   Spotlight this post!
Unread 27-03-2008, 22:33
Alalea Alalea is offline
AKA: Heidi
FRC #1688
Alalea will become famous soon enough
Dropping a ball on it. Directly on it.
Atlas...*tear*
I love deadlines. I like the whooshing sound they make as they fly by.
- Douglas Adams (DNA) 1952 - 2001
  #96   Spotlight this post!
Unread 27-03-2008, 22:41
afi419 afi419 is offline
afi419 is infamous around these partsafi419 is infamous around these parts
short from the battery across the frame.
  #97   Spotlight this post!
Unread 27-03-2008, 22:58
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Originally Posted by boiler View Post
Look across the field to see 1024, 111, and 1114 on the other alliance. Your robot may not break, but your drivers will.
TOO TRUE !
Originally Posted by XXShadowXX View Post
Walk to the snack bar and spend more then $5, you will be intercepted on your way back to pits by 2 or more team members looking for you. After fix is done, your food will be missing.
I've had something similar happen often back when I was with the vol. fire dept. I'd be settled in watching a movie with a big bowl of popcorn... a alarm would come in which would be a not a big deal, by the time I'd get back to the station ... my movie would be done, pop corn gone, soda gone and someone would ask if I had any more popcorn... never failed
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
  #98   Spotlight this post!
Unread 28-03-2008, 08:09
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Just don't do our work (building/breaking) for us, OK?
Uhmmm... I know I'm not the only programmer that makes parts too...
Plus... I'm sure I'm not the only programmer that has fixed hardware problems with software...
Yep... I had a pizza disappear when I went to drive once at BMR... apparently, the person who ate it disappeared too.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #99   Spotlight this post!
Unread 28-03-2008, 14:53
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Let it roll off the table. (Yes they did happen and oddly enough it was nothing more than a box frame with four wheels.)
  #100   Spotlight this post!
Unread 28-03-2008, 20:14
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Is now an engineer thanks to FIRST.
  #101   Spotlight this post!
Unread 28-03-2008, 20:15
XXShadowXX's Avatar
They call me Cody.
more way to break your robot
weight reduction
rounding off corners with metal file
  #102   Spotlight this post!
Unread 28-03-2008, 21:05
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
The other coder and I found a great way to break the bot.
For absolutely no reason whatsoever, IFI loader decided to change the file it was downloading to the bot to last years competition code. We didn't figure this out until after our next match. Before that match though, we were really freaking out. The lift wasn't responding at all, when the driving joysticks were pushed the full speed, two of the motors would reverse with for no apparent reason (we never did figure that one out). Luckily, we used mechanum wheels both years, so driving below max speed worked relatively well. No autonomous (thank god they hadnt gotten to that last year by the time they compiled this version). No lift, and no green light underglow either
Its all good now
Team 2052- KnightKrawler
Mentor and volunteer
  #103   Spotlight this post!
Unread 31-03-2008, 12:27
CalvinDude1 CalvinDude1 is offline
FRC #1511
CalvinDude1 is an unknown quantity at this point
- Run hybrid mode with tether or programming cables plugged in (Seriously, I have no idea why, but it screwed up our hybrid every time we did it)
- Try to program with a homemade cable that happened to have one of the wires get yanked from one of the pins (You have never seen the RC flash so many error messages and strange patterns of lights)
- Make your own field, get gripper caught in lane divider (We didn't have any lexan/plexiglass/whatever over the bars) and then turn your robot in an attempt to get it unstuck
- Tweak the values for your hybrid code "Just a little bit"
- Build a cart that doesn't have anything to prevent the robot from just rolling off
- Run your hybrid code without first resetting the gyro
  #104   Spotlight this post!
Unread 21-12-2008, 15:00
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Originally Posted by A_Reed View Post
Upon entering FIRST you immediately apply Murphy's Laws.
ONE OF OUR COACHES TRIPPED ON OUR FTC BOT
THAT'S RIGHT MR. GRIMES, I'M PUTTING YOU OUT THERE
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
  #105   Spotlight this post!
Unread 21-12-2008, 16:43
Chris/Fish Chris/Fish is offline
FRC #0449 (Blair Robot Project)
Chris/Fish is an unknown quantity at this point
Forget to secure the battery so it falls out of its holder...and onto the main breaker.
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
pic: strange ways you test stuff out? DarkFlame145 Robot Showcase 1 13-01-2008 15:10
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" Mr MOE General Forum 6 09-02-2007 08:40
What do you do when its time to take a break from building?? Leo 1529 Chit-Chat 23 13-02-2006 00:26
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 3 15-02-2005 11:38
