Go to Post Hundreds of teams. Thousands of students. Countless memories. Infinite fun. You'll love it, I promise you that. - smurfgirl [more]
Unread 29-03-2008, 11:28
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Problem in Pneumatics programming
Qbranch is correct. Your code is not the problem.
In addition to what Qbranch said about verifying the connections, you may need to verify you are connecting the solenoids correctly to the Spike.
For this code to work, you need to have the positive (red) lead from each solenoid connected to either the M+ or M- on the Spike (one lead per side). You also need to have both negative (black) wires connected to ground, preferably at the distribution block.
If the piston functions backward from your intent, swap the two red leads on the Spike, or, swap the two pneumatic lines on the valve assembly.
programming pneumatics problem program1 Programming 4 18-02-2008 17:35
Pneumatics Rookie Problem Squishylizard Pneumatics 4 06-02-2007 17:30
pneumatics coding problem (or technical) wildabyss Programming 2 22-02-2005 22:16
pneumatics coding problem (or technical) wildabyss Pneumatics 2 22-02-2005 22:16
Pneumatics Problem + possible fix Srkasner Pneumatics 4 24-02-2004 10:39
