Go to Post GP and the Scout Law are high ideals that only the best will achieve and live everyday. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 29-03-2008, 18:41
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Change Of Match Schedule
Chances are the reason why the match list changed was b/c there may not have been enough time between matches (or too much) OR they inputted the wrong start / lunch / end times OR the sequence of teams / matches and what not didn't even out the right way.
At LI, I think they re-did the schedule twice.
HOWEVER the LI Regional used a different part of the system where the match lists and times you recieved would update on the pit display w/ new times for matches to start. Basically if you looked at your sheet and thought you were ahead or behind time you were wrong b/c the pit displays were updating on a match to match basis w/ new times so that the event would / will run smoother.
Aside from that - chances are it was an error and the FTA felt that it was significant enough to have to re-do the entire list. Not like it matters all that much anyway since it doesn't effect when pits open or close or ceremonies etc.... Match times constantly change anyway through out the day so you shouldn't really be looking to start and finish each match within a certain time since so much could go wrong, Field Equip failure, Score Equip Failure etc... (Things that will always hold you up) All that list does is serve as a general template which can and will change w/o notice and no way of avoiding it.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Anybody have a NASA/VCU Regional Match Schedule SteveJanesch Regional Competitions 3 07-03-2008 09:54
Robocoach functions that change as the match progresses?? kylelanman Programming 13 11-02-2008 15:16
UC DAVIS MATCH SCHEDULE bhsrobotics1671 Regional Competitions 6 20-03-2007 23:46
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
