Go to Post ...we are all winners when people come out of this program and strive to make the world a better place. - Patrick Wang [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 29-03-2008, 23:40
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Is the qualification match robot randomizer really "random"
The problem I have with this 'random' match schedule, is that it can be redone if they feel there are 'too many repeat'. By doing this it is no longer a random schedule. While I don't think this is likely, it leaves the door open for someone to rerun the program because of an unfavorable schedule.
Unread 30-03-2008, 00:11
Except that the scheduler is run by volunteers who are mostly under major pressure to get the match list printed (on a printer that only works about one in four tries) and distributed to dozens of anxious teams as soon as possible. We don't give a big furry rat what the match list is as long as it will finish on time and print the first time. Carefully scrutinizing the match list to give one or another team a huge advantage is so far from being important that -- well, analogies fail me. We want to run a fair tournament that finishes on schedule. The volunteers, for the most part, have zippy-de-doo-dah interest in who actually wins. I, for one, could not even tell you who won Seattle, and I watched every single match from about four feet away. I can tell you that every team I talked to was happy about the venue, the officiating, and the volunteers. That's a win to a volunteer.
The idea that we would keep re-running the match list to meet some competitive profile is something I literally never considered until you suggested it. I know for sure that my scorekeeping partner and I would have laughed at the idea. (Although, as I posted elsewhere, we did redo the match schedule once to give a particular team an early match to meet the needs of the television coverage.)
Unread 30-03-2008, 11:07
Dreadfrost's Avatar
Dreadfrost Dreadfrost is offline
AKA: Graham Fraser
FRC #1305 (Ice Cubed)
Dreadfrost is an unknown quantity at this point
Last year i was determined that it wasn't random at all because at the Greater Toronto Regional, waterloo regional and curie division qualification match we never played 1114 until the finals at the regionals and quarter finals in curie. However this year we played them at waterloo and then not at Toronto. Therefore I've come to the conclusion that its all luck.
Unread 30-03-2008, 11:51
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
While this is possible, it is not likely. For one thing the Scorer, FTA and Field Supervisor are all likely to be present and all will have different ideas about just what an "unfavorable" schedule is. For another it takes about 15 min. to generate a new schedule. We just don't have time to generate more than 2 or 3.
The auditing screen gives the following information about each team:
Number of unique partners - this should be #of rounds x 2 and generally is
Number of unique opponents - ideally this would be # of rounds x 3 but there is some variaition here. This is the number checked most closely.
Number of matches as Surrogate - should be no more than 1 and not many of those.
Teams played and number of times - listed in numeric order, not by what match they are in. # of times played should be no more than 2 for any one team, unless the event is really small and there are lots of matches, in which case there should be lots of 3s not only one or two.
None of this gives very much information about the difficulty of the schedule for a particular team. To figure that out you have to go over the schedule itself which would be very time consuming. Then if you cause the schedule to be re-generated, the schedule you have will disappear. So you are taking a very significant risk that the new scedule will be even worse that the one you just blew away, and you have to do all the analysis all over again to find out. The costs outweigh the benefits very quickly.
In practice, you run the scheduler once and check the output against the criteria above. If it passes you go with it. If not you change one parameter and try again. Once you get somehng that is "good" you lock it and attempt to fire up the printer. But that is a whole different story...
Christopher H Husmann, PE
"Who is John Galt?"
Unread 30-03-2008, 12:41
XaulZan11's Avatar
FRC #1732
To answer this thread's title, no the qualification matches are not random and never were intended to be random. In order to be random, every team needs to have an equal chance of being in every match. Thus, a team can be in multiple matches in a row. Since having a team play 3 matches in a row in not desired, perameters were set so allow time inbetween matches. Within the certain perameters, however, the matches are random (if they don't redo the match list). There is nothing wrong with it not being random, but it shouldn't be called random because its not.
Unread 30-03-2008, 12:52
Mathematically you are correct. In this context, however, I'm guessing that most people would equate "random" with "not biased in favor of a particular team or class of teams." It might be more valid to ask if the match scheduler produces a fair schedule.
Unread 30-03-2008, 13:33
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
First, sorry for saying "big-name", i meant to say "sucessful".
another problem was that in qualifications, if a team couldnt go on the field, there was a 2 VS. 3 match, which obviously favors the 3-team alliance.
~Philip
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 30-03-2008, 13:52
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
~Philip
That isn't something new. Teams have been missing matches for years now, if not forever.
The scheduling won't help the teams compete on the field...but YOU can. You have the match list at some point on Thursday, then you can go around to your alliance partners and make sure that their bot is working. If it isn't, then try your best to help them make your match.
Also, just because it's 2v3 doesn't automatically mean that it's a lock. I've seen plenty of matches where the alliance with 2 teams, win.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
Unread 30-03-2008, 15:52
GaryVoshol's Avatar
Cogito ergo arbitro
I saw a practice match on Rack-n-Roll where an alliance with zero robots won. The HP scored one ringer, and that was the only score of the game!
(since 2004)
Unread 30-03-2008, 16:51
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
I thought the "big names" had every bit as tough a road through the qualifications as anyone. Sean's post shows that pretty well. Second, not only is the algorithm not a secret, it's entire testing and development is well documented right here on CD. Third, I thought our (1712) schedule was a lot more balanced this year than it was last year. Last year, because the algorithm was way too stringent, we wound up with a "big name/low number" partner in nearly every match. Thanks to the help of 272, 341, etc we had a great match record in Philly last year. This year we only saw top tier partners a few times and it certainly made our road to Saturday afternoon a lot more difficult, but albeit more fair.
You also need to realize that if you desire to win, you'll have to best the "top tier" anyway. Eight of us on 1712 spent our entire lunch break repairing a claw just for the privelege of going up against the 103 alliance - and I do consider it a privelege.
Next, be careful as to what you perceive about teams and their funding. This is a year when 357 lost a major sponsor. Ask 272 about their major funding and they'll point to a tune up FLL event they run to fund a regional entry fee. All of the time and energy spent on that event takes away time that could be spent on prototyping for the season. 103 seems to be a juggernaut with their number of events and facilities, etc but if you talk to their leadership you'll find two people that started the team with absolutely nothing some 10-11 years ago in the middle of the woods. Every relationship and piece of hardware that exists in Kintnersville is because of hard work and persistence.
Even suggesting that something is "fixed" here is truly unfounded. With a 44 team event (very small) a match schedule with 6 on the field at a time can only look so many different ways.
-Rich
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 30-03-2008, 19:24
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
-Rich
I'm going to hijack this thread for a second to thank Rich and 1712 for giving 1391 the chance to share in that privilege of going up against 103's alliance. I thought 1712, 1391, and 381 put up an excellent fight against a very competitive alliance (even if we did get eliminated in QFs).
I also want to echo that match pairings and distribution have been MUCH better this year than in my previous experience. This algorithm is a huge step forward in generating good, distributed matches.
//Dillon
www.metalmoose.com
Unread 30-03-2008, 19:32
coalhot's Avatar
AKA: Phil
Since we all are getting off-topic, ill do too and give a plug to Metal Moose. So good hurdler they could throw it out of the ring (literally). Great 'bot. And 304 had a match against them, and almost lost were it not for a good matchup. Ill look for you guys in the Atlanta vids!!
~Philip
Unread 07-04-2008, 01:33
Knippschild's Avatar
Knippschild Knippschild is offline
Website Dev Alum
AKA: Jonathan Knippschild
FRC #0357 (Royal Assault)
Knippschild has a spectacular aura aboutKnippschild has a spectacular aura about
I was a scorekeeper for the Philadelphia Regional. I was present when the match schedule was generated (by the lead scorekeeper).
The FMS (the event management software) uses a very complicated algorithm to generate a completely RANDOM schedule. When FMS calculates who should be paired with whom, and who should be pitted against whom, it has no knowledge of the team's "big name"ship nor of that team's standings at other regionals.
The match parings take about 3-5 minutes to generate. Last year's algorithm only took seconds to generate... this one is definitely a lot more random by definition.
Also, once a match is generated, it is impossible for a human to edit the schedule and rearrange the pairings to fit some sort of side agenda.
I assure you, the Philadelphia Regional's schedule was generated once, and that was the official schedule used for the qualifying rounds.
Bayou Regional 2007 - Best Website Award
Unread 07-04-2008, 13:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
As previously noted, the match pairings are anything but random. Rather, it is a highly constrained process, with many factors influencing how the pairings are established. As outlined in Section 9.3.2 of The Manual, there is a specific set of criteria that are used by the match pairing algorithm to generate the match list. The match pairings generated by the algorithm are evaluated for a "best fit" against these criteria as the list is generated, and adjusted mid-process if necessary. So, by definition, the resulting list is NOT random. Nor would you ever want it to be random. A truly random list will have a significant probability of having teams playing back-to-back matches, being allied with or opposing the same teams, or having uneven numbers of matches. All of these are situations that we clearly want to avoid.
-dave
Unread 30-03-2008, 18:57
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
It happened at least twice at SVR 08; the fact that an alliance starts with 24 points really helps.
As for the original topic-can anyone figure out what the minimum match separation was? I'm far too lazy to page through that schedule, and teams that were there probably can figure it out pretty quickly.
Does anyone else remember when TBA signatures actually worked?
no "teasers" here, its really our robot Stillen General Forum 5 28-01-2008 15:01
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
"Random" match Schedules Ben Piecuch Regional Competitions 211 23-03-2007 08:36
"Random" Match List Generation Sean Schuff Regional Competitions 32 01-04-2006 21:26
