Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Go Back   Chief Delphi > Competition > Regional Competitions
View Poll Results: Do you like the Serpentine alliance selection process
I like the Serpentine selection process 68 53.54%
I don't like Serpentine selection process 42 33.07%
Undecided 17 13.39%
Voters: 127. You may not vote on this poll
Unread 30-03-2008, 00:59
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Serpentine Draft Alliance Parings, Like/Dislike
well searched for this and surprisingly no results...
here is a simple question
Do you like the Serpentine Draft system or would you rather go back to the old draft alliance parings?... if you feel like it, explain why
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 30-03-2008, 01:09
ReaperGoat's Avatar
ReaperGoat ReaperGoat is offline
Volunteer
AKA: Ruth Toomey
FRC #0319
ReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud of
Send a message via AIM to ReaperGoat
Re: Serpentine Draft Alliance Parings, Like/Dislike
I find that I both like and dislike the serpentine draft. I definitely like the idea that it helps to even out the eliminations field a lot, in some cases. However, I find that I dislike it, because it seems a higher ranked alliance captain becomes much more likely to pick from withing the top 8, and the likelihood of a juggernaut first alliance becomes that much greater. (Although, it does tend to make for very interesting finals! )
I think it might be interesting to see a reverse serpentine draft, with the 8th alliance captain picking first, then going up to the first alliance and then back down. If FIRST is going with a serpentine draft with the goal of leveling the field, this might possibly be one option.
Team 1735 Student (2006), Mentor (2008, 2009)
Team 190 mentor/mascot (2007, 2015, 2016)
Team 319 Mentor (2016-present)
FIRST Volunteer (2009-2016)
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Oh wow, could have sworn this was discussed before. I've been a heavy opponent of this style since it was first instated. It just gives the lower seeds a larger advantage over the higher seeded teams. MOST higher seeded teams earned that spot to pick first/second/third and should get all the spoils for being in that position. I'd rather see a team that earned their right to pick an amazingly dominant team than an 8 seed upset the 1 seed in the first round because they were able to make a better rounded team. Then again, sometimes my reasoning is flawed by high seeds still forming dominant alliances.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Sorry, this is my 2nd year..what was the old selection process? I want to know before I judge. Thanks.
Unread 30-03-2008, 01:11
Go VOLS!!
AKA: Budda648
no team (QC Elite)
1-8, 1-8 instead of 1-8, 8-1.
Do The Tyler!
Unread 30-03-2008, 01:14
This years serpentine because it keeps the "juggernaut" alliances closer to the the others' level. But I like the idea above, of letting the 8th alliance pick first, although that may defeat the purpose of teams trying to win each match lol.
Unread 30-03-2008, 01:16
http://www.chiefdelphi.com/forums/sh...ght=serpentine
http://www.chiefdelphi.com/forums/sh...ce+selectio n
It's been a few years.
Unread 30-03-2008, 01:21
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
A poll conducted shortly after kick-off '06, when the rule was first released.
http://www.chiefdelphi.com/forums/sh...ad.php?t=41298
Unread 30-03-2008, 01:48
AKA: Nawaid Ladak
I stand corrected then
when i searched i used the word serpentine thinking someone would actually put that in one of those threads/posts, but i guess it wasn't there
maybe this is can be a "how do you like it now" type of thing, seince those threads were done 2 years ago... maybe sort of like a follow up
Nawaid Ladak
Contact me
Unread 30-03-2008, 03:07
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I don't like the serpentine system. I'm with Jeremiah. Top seeds should get top picks. Sure the matches wouldn't be as interesting, but at least they would be fair.
Jacob
Unread 30-03-2008, 03:14
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
I like it because it gives a lower-placed team (theoretically, the 24th-best team) a chance to win a regional if they can make a contribution to their alliance, because not even two "juggernauts" can usually win against the well-balanced alliances serpentine selection usually generates. It emphasizes that robots need to work together to emphasize their strengths, not just gather the three best teams in the building (or the two best and the 9th best... whatever)
Does anyone else remember when TBA signatures actually worked?
Unread 30-03-2008, 03:31
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
it depends on the game also.
I think the current selection process worked to even out the alliances in '07.
You pick 7 or 8 and you could get the best ramp/bonus point bot on the go around.
Unread 30-03-2008, 08:48
Steve Ketron's Avatar
Steve Ketron Steve Ketron is offline
FRC #1528 (MTR (Monroe Trojan Robotics), formerly iPirates)
Steve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to all
I think the serpentine drafting is fair. With the qualification pairings of the last couple of years, being the number one seed doesn't actually mean you are the best robot. I think depends a lot on whole you are matched with. Perfect example is the Detroit Regional this year. My team got to compete against the top four seeds but had one of them as a partner once. We were the number nine seed after qualifications and think that if some of those teams were on our team we might have been able to go with one loss instead of 4. That would have made us a 1-3 seeded teaM (BIG DIFFERENCE)
Unread 30-03-2008, 09:32
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
This selection process isn't so good for this game this year. I would love to see it go 8-1, 1-8. That I think would make the elims so much more interesting.
Unread 30-03-2008, 10:23
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
The draft seems to work pretty well at regionals with a lot of depth. This year we went to MWR, WMR, and GLR. These were all crazy tough regionals with a lot of depth. 910 was the 24th pick at GLR and that was a great machine. I understand people's reasonings for wanting even more level of a playing field. That being said I often compare FIRST to other Motorsports. There are only a few strange specialty races that put the fastest qualifier at the back of the pack. I would not be a fan of the 8-1 then 1-8 as that would lead to strategic dumping in final matches.
Best Alliance in the Alliance Era of FIRST Corey Balint General Forum 28 05-09-2006 20:14
Alliance Selection 2005- Like it? OneAngryDaisy Rules/Strategy 42 14-03-2005 14:59
Yet another reason to dislike Abercrombie... Firewolf Chit-Chat 46 14-06-2002 14:39
Anyone dislike the way the comp this year is scored? Greg Perkins Regional Competitions 11 08-04-2002 19:30
