Go to Post Look at the problem and find the simplest solution. Don't look at a solution and try to find a problem to solve with it. - apalrd [more]
Unread 31-03-2008, 01:55
gwatton's Avatar
gwatton gwatton is offline
AKA: Gabriel
FRC #0973 (Greyhound Revolutionary Robotics)
gwatton is an unknown quantity at this point
Send a message via AIM to gwatton
Re: Drive Trains
Drive Trains can be broken down into the parts they include (excluding crab drive):
Motors: There are not too many choices for drive motors in FIRST. Most teams use 2-4 CIM motors for drive, depending on the weight available, and the power needed. Some teams will supplement with geared fisher-price motors. If you are going with a tank-drive style, two CIM motors per side is usually the way to go if you have the weight for it.
Gearboxes: FIRST supplied the AndyMark toughbox gearboxes in the kit this year. These will accept one or two motors stock, and are simple and easy to use. One thing that these don't provide that many teams desire is more than one speed. To achieve this, you can either go with a prebuilt shifting gearbox, such as those manufactured by AndyMark, or a custom design. AndyMark makes the supershifter model, which can be operated with servos or pneumatic pistons. This is a simple option, but somewhat expensive ($360 each plus pneumatics)Other options are available for single speed, such as planetary gearboxes from banebots or andymark, but they are used much less for drive systems.
Wheel type/arrangement: As mentioned above, the 6 wheel drive with a center wheel offset is the most common system. This has worked extremely well for us, and for many other teams as well. This system is usually paired with a set of traction wheels, either bought or custom machined. One type that has been gaining popularity are the Mecanum wheels. These wheels enable the robot to travel in directions other than forward and backward, through strategically reversing rotation direction. One downside to these is they usually provide diminished traction. Omni wheels are also being used frequently. This would be used on a robot to improve the ease of turning. Like Mecanum wheels, these also provide less traction.
Drivers: The final part of the drive train is the driver. The driver is not what it is all about, but a poor one can make bad use of a great robot. A great drive cannot make a robot good, but a bad driver can sure make a drive train terrible.
We (973) have been using the six wheel drive, center wheel offset design for 4 years now, and it has worked it greatly to our advantage. We custom machine wheels. We have experimented with both one and two speed gearboxes, finally using the AndyMark Supershifters, with pneumatic shifting. We use two CIM motors per side.
-Gabriel
Las Vegas Regional Finalists - 2008
Unread 31-03-2008, 02:09
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: Drive Trains
I was the driver for 2207 this year and I really liked our drivetrain. We had mecanum wheels and they were very helpful with easily moving around the field and getting around obstacles since we could move sideways. I also got us out from being tangled up with a robot that fell on top of us and having the mecanum wheels helped alot. They also helped in making a very easy Hybrid mode as we could move sideways to cross the second line, since we don't have to turn it was very easy from a programing point.
Any ways Drivers are a key along with the drive train and wheels. We used the AndyMark 8" wheels with the AndyMark Toughbox gearboxes on all of them
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Drive Trains-help bookworm2011 Technical Discussion 5 21-12-2007 02:48
VEX Drive Trains 2007 Akash Rastogi VEX 23 13-12-2007 11:06
paper: FIRST Drive Trains and Structures Madison Extra Discussion 18 04-12-2007 17:37
Drive trains Jared Rillings Rules/Strategy 2 10-01-2007 13:17
Drive Trains?!?!?!!!!! archiver 2001 0 23-06-2002 23:08
