#16
Re: pic: 1625's swerve module (better pic)
With such an effective drivetrain, it's no wonder you guys went undefeated at Colorado. I love the way you guys keep the robot chassis facing forward through the match, but still have the swerve function to put you back into position. That's very innovative.
Keep up the hard work and military-like competing guys. |
#18
That module looks very simular to our initial idea, except we were putting the motor/transy inside the module itself.
It's very nice looking =D |
#19
This guy weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
#21
Is there a girl module? ![]() |
#22
Hm, you should switch to Kevlar belting and aluminum pulleys. Then this setup would be truly frighteningly light. Out of curiosity, how many teeth does your steering sprocket have? I'm currently designing a bottom support crab, so I can finally post one that doesn't get hit with the "you're not supporting it right" complaint.
#23
Yes i have but during the season i was too busy to find a supplier or someone to have them made.
#24
Aren, do you have a white paper on this, or at least a picture of the other side of this assembly showing the bevel gears?
I got to see this up close at IRI, & was very impressed. Not only did it perform great on the field, but it was relatively lightweight for what it consists of. I'm trying to convince my teammates to experiment with as many drive trains as possible over the summer with our upcoming test chassis, & want to show them this one as a great example of swerve assembly. |
#25
I myself do not own a camera, and if i did wouldn't have time to take pictures.
The module structure (alum parts) is almost all waterjetted parts, then welded onto a 3x3x1/8th wall tube that had bearings holes CNC'd into it. it will have some revisions for next year if we continue to do swerve, such as better bearing support at the top. (right now 1/2" bearings are taking the thrust load....). I'm considering copying 148's wheels so we dont have to worry about retreading and steering the wheels would be easier |
#26
here is a cad of them i don't have a good picture. ![]() |
| pic: Team 148 Robowranglers: Swerve Module and Motors | Brandon Martus | Robot Showcase | 27 | 02-24-2008 10:29 PM |
| pic: 1625's arm control | Aren_Hill | Extra Discussion | 9 | 10-15-2007 11:55 AM |
| pic: stangs swerve module | Aren_Hill | Extra Discussion | 8 | 04-23-2007 08:15 AM |
| Swerve Module Question | adlai | Technical Discussion | 8 | 04-03-2007 09:20 PM |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 07-09-2006 07:57 PM |
