pic: What Happens When You Go Too Fast...
Re: pic: What Happens When You Go Too Fast...
Is that a 2007 or a 2008 wheel? (It's hard to tell the difference with the lighting.)
Ha ha...wow- when we used those in 2006, they broke on us a couple times- not fun to fix. Glad you had spares.
Edit// Err... i was wrong. Last edited by Alex Cormier : 31-03-2008 at 09:16. |
This was a 2007 wheel so we weren't surprised when it happened. I had heard tales of 330 going through these like candy, so we were prepared.
#7
The 2007 wheels don't usually break like that when you go too fast. They break like that when you suddenly go sideways. Swerve drives were especially hard on them last year.
(The spoke redesign for the 2008 wheels appears to have worked as intended. None of the new wheels have broken on our practice 'bot, and all of the old ones have.) |
#8
We destroyed a few of these with our swerve drive this year, but nowhere as many as last year. Last year at WMR we once broke 3 during a single match >.<
#9
They failed in exactly this way, too. All six spokes would break right at the hub and we'd have no wheel. Mostly on the practice robot, but we did lose one or two to fractures in competition. And yes, it was sideways force that broke them. |
#10
#11
we broke two during the florida regional going over the high spot in the track
#12
We added wooden inserts between the spokes and other modifications to strengthen all of our '07 wheels. They worked quite well. This year, we've only destroyed 1 '08 wheel significantly (the bearing that we pressed into the hub shook itself loose and destroyed the hub)
#13
That wouldn't happen if you had a decent field coach
#15
That's not from going too fast. Most likely you lifted one drive side of your robot off the ground and held it at full throttle. When it came back down the momentum in the drive train tried to put all that energy to the wheel and snapped the spokes. In race cars when you hop a tire at WOT you can blow a rear-end, drive shaft, axle shaft or transmission. Even when I used to race RC Trucks, when you came off a jump you had to let off the throttle or you would shatter titanium axles as you hit the ground. It comes down to driver error when this happens.
| pic: What happens when you mess with 709 | Priyadarshy | Extra Discussion | 2 | 22-03-2007 17:47 |
| pic: Whoops... What happens when you change 6v FP to 12v FP? | team222badbrad | Extra Discussion | 2 | 21-02-2005 10:06 |
| pic: What Happens When You Work In Rural New Hampshire | Petey | Extra Discussion | 9 | 13-02-2005 10:38 |
| pic: This is what happens when you don't win in NYC | CD47-Bot | Extra Discussion | 5 | 07-04-2003 18:10 |
