Go to Post You're part of what makes FIRST so special. - Matt Krass [more]
Unread 29-03-2008, 07:27
beefy23 beefy23 is offline
beefy23 is an unknown quantity at this point
Question Problem in Pneumatics programming
I have a problem trying to cause the piston going forwards and backwards.
What I`ve tried to do is to move the piston backwards when the user clicks on the joystick`s trig and to move the piston forwards when the user get rid of the joystick`s trig.
I had a problem which seemed ambiguous for me and I couldn`t find the error, it compiled successfully.
I made sure the spike is plugged in the proper relay, and the joystick is plugged in the proper port.
Here is the code:
if(p1_sw_trig)
relay1_fwd = 0;
relay1_rev = 1;
else
relay1_fwd = 1;
relay1_rev = 0;
but it doesn`t do anything .
Unread 29-03-2008, 08:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Problem in Pneumatics programming
Here is the code:
if(p1_sw_trig)
relay1_fwd = 0;
relay1_rev = 1;
else
relay1_fwd = 1;
relay1_rev = 0;
Your software is entirely correct. Unfortunately the connectors on the Spikes are very finicky, so you might try plugging them in a few times. But, before you do that, I suggest taking a volt meter or an led and seeing if the fwd and rev pins are being set/unset. If they aren't, you can test it at the pin too. If it isn't working there, check with dashboard to see if your button is working and is showing up where your software thinks it should be.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 29-03-2008, 11:28
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Qbranch is correct. Your code is not the problem.
In addition to what Qbranch said about verifying the connections, you may need to verify you are connecting the solenoids correctly to the Spike.
For this code to work, you need to have the positive (red) lead from each solenoid connected to either the M+ or M- on the Spike (one lead per side). You also need to have both negative (black) wires connected to ground, preferably at the distribution block.
If the piston functions backward from your intent, swap the two red leads on the Spike, or, swap the two pneumatic lines on the valve assembly.
Unread 29-03-2008, 11:40
Where did you put your code? The default code also messes with the relays, so if you put your code before the default code, the default code would overwrite your settings.
Unread 30-03-2008, 13:18
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
after checking the voltage on it, also make sure that your solenoid isn't the problem either.
Unread 30-03-2008, 13:40
Un Luchador's Avatar
Un Luchador Un Luchador is offline
Electricity is my pastime
AKA: Gustavo
FRC #2543 (TitanBot)
Team Role: Electrical
Un Luchador is an unknown quantity at this point
Send a message via MSN to Un Luchador
Have you checked the pwm cable connection? One problem we kept getting was that the Spikes' long port between the controller had a tendency of bending the pins and sometimes slipping out quite easily. We had to resort to taping them down with electrical tape.
Unread 30-03-2008, 17:51
AKA: Alex
Actually, when i said FWD and REV pins I was specifically referring to the logic level (5VDC) outputs from the controller to eliminate the spike from the system at first. If you're getting the 5V signals, then you can work down the chain of command from there (5V signal -> spike -> solenoid -> piston -> mechanical action).
-q
Unread 30-03-2008, 18:52
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Not to be contradictory -- but I guess I may be. I had to dig out our last year's pneumatic code to check how we did it. In autonomous, the routine was called with variable Position either 1 or 0:
   if (Position==1)                          //Open pinchers/release tube?
      relay1_fwd= 1;                         //Pressurize to open
      relay1_rev= 0;                         //This always zero
   else if (Position==0)                     //Close pinchers/pinch tube?
      relay1_fwd= 0;                         //Depressurize to open (release tube)
The relay1_rev was always zero, and only relay1_fwd switched between one and zero. I always thought it was odd, but hey, it did work.
But another place was in user_routines.c/User_Initialization routine -- make sure your digital_io was set to INPUT:
  digital_io_18 = INPUT;  /* Used for pneumatic pressure switch. */
We also had a slightly different way with the joystick trigger, to click it each time to reverse state:
   if (p2_sw_trig != SqueezeTrigLast)           //Trigger changed state? (squeeze/no squeeze)
      {                                         //Yes:
         if (p2_sw_trig == 1)                   //...Trigger pressed
            SqueezeState= 1 - SqueezeState;     //Toggle state 0 to 1 to 0
         //printf("SS=%d  fwd=%d  rev=%d",SqueezeState, relay1_fwd, relay1_rev);
        // Part 2 Open... or... shut???
         if (SqueezeState==0)                   //Is state to be OPEN?
         {                                      //Yes:
            relay1_rev= 0;                      //This stays zero
            //printf ("OPEN\r\n");
         else                                   //State is NOT OPEN
            //printf ("SHUT\r\n");
         SqueezeTrigLast= p2_sw_trig;           //Save trigger state for next time check
This way you don't have to hold the trig button.
And yes, because programmers are always perfect, have the hardware guys make sure they did everything right.
________________________________
Every revolutionary idea seems to evoke three stages of reaction. They may be summed up by the phrases: (1) It's completely impossible. (2) It's possible, but it's not worth doing. (3) I said it was a good idea all along. RIP Arthur C. Clarke
Unread 30-03-2008, 21:28
The code necessary depends on the type of solenoid used and the method of wiring.
The code you posted is correct for a double solenoid (two red and two black wires) if the two red wires are wired to the spike and the grounds connect to ground elsewhere.
A single solenoid has one red and one black wire going to the spike and is controlled by (as in Roger's example):
if(p1_sw_trig)
relay1_fwd = 1;
relay1_rev = 0;
else
relay1_fwd = 0;
relay1_rev = 0;
Unread 31-03-2008, 07:43
FRC #1153
Rookie Year: 1900
So I have to call out the "it all depends" escape clause? I'm glad I wasn't wrong -- it did work -- but I'm also glad I wasn't saying Qbranch and billbo911 were wrong, either. Now I know why relay1_rev never gets set to one. I guess this is what happens when I don't pay attention to the hardware end of the robot...
Unread 31-03-2008, 10:30
AKA: Alex
*chuckle* Ok, I guess we all jumped the gun and assumed you had a double acting/double pull solenoid. Glad you got it working... now I have a question for you:
What is this mysterious piston for?
-q
Unread 31-03-2008, 14:37
FRC #1153
Rookie Year: 1900
Sorry, I meant our last year's code did work on our (Team 1153) robot. I don't know if beefy23 got his/hers to work, or what solenoid type it was. It was a loooooong weekend....
programming pneumatics problem program1 Programming 4 18-02-2008 17:35
Pneumatics Rookie Problem Squishylizard Pneumatics 4 06-02-2007 17:30
pneumatics coding problem (or technical) wildabyss Programming 2 22-02-2005 22:16
pneumatics coding problem (or technical) wildabyss Pneumatics 2 22-02-2005 22:16
Pneumatics Problem + possible fix Srkasner Pneumatics 4 24-02-2004 10:39
