Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 26-02-2008, 12:27
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Connecting custom sensor to RC dig I/O
Here's a question for you electrical gurus:
We made a signal sensor that outputs around 2.9 volts until a signal is received at which point the output goes up to around 3.8 volts. We didn't get a chance to hook this up to the RC before ship, but we are wondering what we need to do to make this output work with the digital inputs on the RC. The RC manual says that the input pins expect a 0v or 5v signal, so how do we make our tweener signal work?
Unread 26-02-2008, 14:36
Re: Connecting custom sensor to RC dig I/O
Dan,
It would seem that hooking this up to an analog input and adding a little software would do nicely. You just need to write some code to check that input. If the input rises above your set point then trigger your desired result.
Unread 26-02-2008, 14:53
AKA: Dan
Dan,
Aha! Thanks Al, that solution should work great. And keeps us from having to do any more soldering. Shouldn't take much work at all to implement this during day one of our regional.
Unread 06-03-2008, 14:29
Mike.Allen Mike.Allen is offline
FRC #2092
Mike.Allen is an unknown quantity at this point
We too have run in to the same problem. Could you please explain the "the exrtra software!"
-thanks
Unread 06-03-2008, 14:46
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Mike.Allen View Post
We too have run in to the same problem. Could you please explain the "the extra software!"
-thanks
A simple comparison function should do it.
char a;
if (rc_ana02 <= 615)
    a = 0;
else
a = 1;
This just looks at an analog input and assigns a value of 0 to a variable if the input is less than a threshold, otherwise the variable is set to 1.
I chose 615 because the analog inputs to the RC are 10 bit, or, 1024 values. 615 is 60% of 1024, the same as 3 volts is 60% of the reference 5 volts.
Unread 06-03-2008, 15:17
AKA: Dan
Yes... As an update on this we put together a gadget that responds to visibile light...uh in light of the IR problems being reported We tested it per Al's suggestion and it works great in bright ambient light using code similar to what billbo posted although polling the analog port directly gave strange values. We used (for testing) Get_analog_port (port#) from some OLD code that either originated from the default code or Kevin Watson's code.
Unread 31-03-2008, 12:08
Un Luchador's Avatar
Un Luchador Un Luchador is offline
Electricity is my pastime
AKA: Gustavo
FRC #2543 (TitanBot)
Team Role: Electrical
Un Luchador is an unknown quantity at this point
Send a message via MSN to Un Luchador
What does this gadget accomplish?
Unread 31-03-2008, 12:25
AKA: Dan
Well, as suggested in my previous post, we made the visible light sensor to use instead of the IR sensor in hybrid mode. We used 4 sensors spread apart in a diamond pattern on the back of the robot and handed a 2 million candle power flash light to our robocoach. The sensor module would detect whether a light sensor was receiving a signal then pass it along to its respective analog port (as described above). In accordance to the rules, the robot would respond in a repeatable manner to each sensor. We weren't super ambitious as our programmer mentor (not me this year) was reluctant to make use of the full array of sensors we had installed. So in default, our robot attempted to run laps. One light sensor said "continue autonomous", another said "strafe right", third "strafe left", and the last "pause autonomous".
Problems we had:
Field lighting was brighter than pit lighting, so we had some trouble adjusting the sensitivity of the sensors. In a few practice matches the robot would begin OK then apparently drive to a slightly brighter portion of the field and begin strafing left and right. By qualifying matches we had the sensitivity adjusted fairly well except for one match. Normally we wanted to start with the robot against the Robocoach fence, but in one match we started against the driver station wall closest to the lane divider line. Evidently light reflected off the diamond plate and hit the strafe left sensor, so our robot promptly violated G22 before the Robocoach was able to give it a pause signal.
Unread 31-03-2008, 12:34
AKA: Gustavo
That's smart, I didn't even know we were allowed other communication devices between the robocoach and the robot besides the remote control. Thanks for enlightening me, this should open quite a few doors for us during hybrid mode and sorry if I repeated a question, I wasn't sure if I completely understood what you meant.
Unread 31-03-2008, 12:51
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
As suggested, I would definitely hook it up to an analog port and do the comparison as shown. We tried to use a homemade IR sensor two years ago that had similar on/off voltage ranges and apparently the "off" wasn't off enough for a digital input. The reading from the sensor never changed when connected to the digital port. We ended up not using the sensor as it was a last minute thing and we didn't think to hook it up to an analog port and try it that way.
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 16-04-2008, 16:30
dgitz dgitz is offline
FRC #2219
dgitz is an unknown quantity at this point
If you need the room for an analog i/o or just want to do it a different way, you can use a comparator and calibrate it to cut off on when your signal reaches the higher voltage.
Dashboard with analog and dig inputs Andrew Schreiber National Instruments LabVIEW and Data Acquisition 1 13-02-2006 22:48
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
Connecting Switch to RC Mr. Steve Control System 2 28-01-2005 22:37
Edubot-sensor wiring & connecting cadets Electrical 2 08-01-2004 10:01
hey Battlecry-goers.. who's up for shin-dig after?! archiver 2000 0 23-06-2002 23:07
