Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 31-03-2008, 15:01
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
IR Board Programming/Wiring Problems
Alright, so our team wired up the IR to digital ins, saw the lights flash on the board. But the outputs we got were very wierd. no matter what we did, it always said command 1,2, and 4 were 0 (being used), and 3 was 1 (not being used). We wired to IR to ground, a 12V supply, and each cmd line to a signal on the microprocessor. In bench testing, this worked fine. We used WPILib and used the default and such and saw the lights on the OI light up along with the board when we hit buttons. Any help with general setup/use using the first four digital inputs would be great.
CRUD Name: Windows
Alumni to Team: 350
Electronics Board Wiring Concern SpaceOsc Electrical 7 13-02-2008 12:15
Wiring The IR Board joesmomh00haha Sensors 2 12-02-2008 15:30
IR board wiring Brandon_L Electrical 1 11-02-2008 15:14
Wiring IR board DarKCroNo Sensors 3 09-02-2008 10:20
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
