| Thread Tools |
Rating:
Display Modes |
#196
Re: Intentionally blocking traffic in Hybrid
You are right that untested autonomous modes are a potentially dangerous situation, but, well, even tested ones are. (See this shining example of what happens when one of your encoders is just chilling rattling around in you're robots belley pan instead of being coupled to a shaft.) 48: You guys are running a timed autonomous? Wow you all must have some pretty consistent batteries! -q |
#197
See? All that "newfangled" technology just gits ye young whippersnappers in trouble, I reckon. The wedged (wait, I better change that to "angled" before some misinformed person complains ) front end does wonders for correcting various navigational errors . Most of the time.....we did go clockwise once due to a collision from an errant partner. One day we may hook up the Super Shifter encoders. One day.... Last edited by Travis Hoffman : 03-09-2008 at 08:55 PM. Reason: Laconic Modifications... |
#198
ours is timed too. and we can get three lines consistently
yay for no sensors!! |
#199
-q |
#200
At the Kettering Rookie tournament, many teams would either not move at all, or would manage to move at least beyond the finish line and then get hung up down at the other end of the field (if they even attempted to make the turn). We did have a robot or two that managed 3 or 4 lines.
However, we had several robots that might have blocked Hybrid if this was a hard and fast rule. They managed to move away from the wall, but would stop short of the finish line - maybe they just didn't move far enough, or maybe they veered off to the side and tangled with the wall or lane divider. Either way, they fell into the category of, "The accidental creation of obstructions on the Track during Hybrid Period may be unavoidable and will not be penalized." (Q&A 1/24/08) No calls for hybrid blocking were made. As Update #15 stated, "We think there is enough distinction between the two alternatives that teams will understand the difference." The GDC has given their interpretation of the matter. Can we decide to get on with it, live with it, and let this matter drop? |
#201
We're undefeated this season... and so are other teams.
#202
This may not be in the right place but i think you should get pentilized if you see some one caught on the overpass and you are sending your robot signals and you hit the team and cause them to fall you should get pentalized and also if back up 5 inches or mabey less you still get pentalized i think there should be a little distance you should be able 2 back but like i said this is probobly in thee wrong place
#203
At the time of the post you quoted, I believe that 148 was the only team who was undefeated. Granted that several other teams hadn't played yet due to later regionals.
#204
2 quick things to keep in mind:
1st, G40 clearly states that a robot is not IMPEDING if there is a clear “passing lane” around the ROBOT. This means that if there is room to drive around, the robot is not by definition, impeding. (if this was said before, I apologize - this is a long post, but people still refer to the drive forward 3' robot as necessarily impeding). 2nd, Our auto has a "Pause" function. I highly recommend it for these teams getting so many lines. If your robot is driving at extremely high speeds around the track and you do not have direct control I would say that it is negligent to think it is not going to ram into something. I think some of the better teams are using pure auto and are not dependent on the IR, and if that is the case, add a safety stop to your functions to avoid these penalties! Just because your code goes fast and its not your fault that people "get in your way" does not mean that you can absolve yourself of the responsibility of keeping in check a machine that will have high speed collisions under normal field conditions. |
#205
As far as being blocked in hybrid mode I know how you feel, Speed Racer 1519s robot was blocked a few times at BTB because we could score up to 9 lines in hybrid giving us a good average for our scores of the day around 48-54 points a match.
| G22 Direction of Traffic Hilarity | Kevin Sevcik | Rules/Strategy | 16 | 01-17-2008 10:30 PM |
| Intentionally tipping and disabling your own robot FTW... | Mr. Lim | Rules/Strategy | 30 | 01-14-2008 01:35 PM |
| Traffic and Weather? | indieFan | Championship Event | 7 | 01-30-2007 03:30 PM |
| Week 2 Regional Traffic Jam | Koko Ed | Regional Competitions | 6 | 03-07-2006 10:11 PM |
| Site Traffic Chart | archiver | 2000 | 2 | 06-23-2002 10:01 PM |
