Go to Post And the only thing that can really measure that is when you look a kid in the eye, say "We've got a problem..." and you see them smiling, "Bring it on." - dtengineering [more]
Unread 31-03-2008, 12:28
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Offensive Power Rankings for 2008
Could you help me make sure I understand the linear algebra involved?
I understand that p is what we're looking to find, or the average number of points a team contributes per match. s and M we can calculate from the results coming from each regional. Since Mp = s, we can conclude that p = (M-1)s (where M-1 denotes M inverse). It seems to me from thinking about it that M is symmetric, and as such M = M-1. Is that actually the case?
I'll probably try to write a program to take a csv dump and spit out rankings if I understand the math.
Unread 31-03-2008, 14:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
M is indeed symmetric. M[i][j] indicates how many matches team i played with team j. Therefore, it makes sense that M[i][j] = M[j][i].
I don't think the inverse of a symmetric matrix is necessarily symmetric. The transpose of a symmetric matrix M would be equal to its non-transpose, but I don't think that carries for symmetry. To prove that M-1 is not necessarily equal to M for a symmetric matrix, just think of the symmetric matrix 2I, where I is the identity matrix.
If (M)-1 = (M) for symmetric matrices like you are proposing, and we know MM-1 = I for any matrix and its inverse, then (2I)(2I) must equal I, but this is not the case.
I didn't have to write the matrix solver myself, I used a library I found online. If there are any tricks it used, I'm not aware of them.
Unread 31-03-2008, 14:44
You're right. For some reason, I was thinking of the transpose rather than the inverse. I'll see how I handle the inversion of the matrix when I get there. In the meantime, I'm working through the easy stuff: reading the csv and making and populating s and M.
Unread 31-03-2008, 15:05
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
M is symmetric, but that doesn't mean M = M inverse.
Symmetry means that M = M transpose (flipped along the identity axis), which is different than M inverse.
It's easy to confuse the two (I remember doing that plenty of times, thank Ms. Martin).
Here's an example where M = M inverse, and you quickly see that M is definitely not symmetric:
|   9   5 | |   9   5 | - |   1   0 |
| -16  -9 | | -16  -9 | - |   0   1 |
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 31-03-2008, 16:50
MCarron MCarron is offline
FRC #0343
MCarron has a spectacular aura aboutMCarron has a spectacular aura aboutMCarron has a spectacular aura about
Just an FYI...all of the match data is NOT included from the Peachtree regional. The scoring system failed so all of the elimination matches and many of the qualifying matches from Saturday are not included. As an example...team 343 finished 12-4 at that regional. We are still shown as 5-3 on the Blue Alliance. That means there are eight matches not accounted for on us alone. That would/could be the same for many of the other teams who attended Peachtree.
Is there anybody that has that manual data? Can it be manually entered into the Blue Alliance?
Thanks,
Mike Carron
Team 343
Unread 31-03-2008, 17:00
See here: http://www.chiefdelphi.com/media/papers/2102
Unread 31-03-2008, 17:33
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
Originally Posted by Joe Ross View Post
but...was anyone planning on putting this manuel score on tba... b/c i have no way to do it...
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Unread 31-03-2008, 22:23
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
if there was a normally very high scoring team that happened to malfunction in a match where they were in your alliance, or was defended a lot in your particular round, wouldn't your score be highly skewed?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 31-03-2008, 23:04
Kyler's Avatar
Kyler Kyler is offline
FRC #1625 (Winnovation)
Kyler has a spectacular aura aboutKyler has a spectacular aura about
Okay, I have created a basic program to make the n X n matrix as defined in the post that sort of explains the rankings but what do I do from there? I am only in trig and we have definitely not learned that stuff with matrices. Can somebody give me an example of "M(k1)p(1)+M(k2)p(2)+...+M(kn)p(n) should equal s(k)" or clarify that please? Thanks!
Unread 31-03-2008, 23:18
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
We were hevily defended all through GLR hurdling only 2-3 times a match where we usualy hurdle 4-6 times and at Detroit we were broken 3 of the matches, but we are still high on the list . That shouldn't effect it much.
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
From there you need to invert M and multiply it by s. The are libraries doing the first all over the internet - however, I do not know the algorithm they use. I know how to do it manually, but that would take way too much time for anything this scale.
Then you need to multiply M inverse by s. What you're looking to get out is another column vector, or list of numbers, similar to the one you have in s, although with different numbers. To do that, simply multiply each element in a column of M inverse (with a fixed row) by each element in the corresponding row in s (which has only one column). For example, to find the 10th element of p, or the average number of points contributed by the team in the 10th row, add up M(10,1)*s(1) + M(10,2)*s(2) + M(10,3)*s(3) + ...
Doing that for each row in M will get you p, the vector you're looking for.
If this didn't make much sense, look at http://mathdemos.gcsu.edu/mathdemos/matvec/matvec.html or http://en.wikipedia.org/wiki/Matrix_multiplication
Unread 01-04-2008, 00:46
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I added Peachtree missing matches to the database. I'll do another database dump after the NYC regional is finished. Thanks for pointing me to the data!
Unread 01-04-2008, 03:11
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Looks like the system is working well, but I think if we add a little to it it would work much better.
Right now it is set up to calculate the average points contributed to an alliance by one team. This method does not take care of the defence.
you guys who did the calculations, can you add defence to it as well.
so example:
Red Score = RedA_O + RedB_O + RedC_O - BlueA_D - BlueB_D - BlueC_D
then solve for Team_O which is the average points added to their alliance, and Team_D which is the average points one team take away from their Opponent's alliance.
-Borna Emami
Team 0x27
Unread 01-04-2008, 07:58
Kyler's Avatar
Just a few questions left but the post above helped a bunch. Do i want M inverse or transverse? Also, do I want it to equal s and multiply by p or the other way around? Lastly, M(10,1)*s(1) + M(10,2)*s(2) + M(10,3)*s(3) Means to take whatever value is in the matrix at (10,1) and multiple by s and by 1 right? thanks!
Unread 01-04-2008, 11:52
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Hey Kyler:
Do you want me to send a slide rule with Nathan tomorrow to help you out?
Nesher
Do not panic! All is well!
- Kevin Bacon in Animal House
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
Offense/Defense rankings for 1043 teams Bongle General Forum 21 06-04-2006 19:58
best offensive play thatphotochick General Forum 6 04-04-2006 20:35
Defensive or offensive? (to you) Andrew Blair Rules/Strategy 17 23-03-2005 15:09
Best Offensive Round archiver 2000 10 23-06-2002 22:37
