| View Poll Results: You Make The Call | |||
| 20 points. Great job! |
6 | 10.91% |
| 18 points. Not quite in time, but a lap nonetheless! |
5 | 9.09% |
| 16 points. Better luck next time! |
44 | 80.00% |
| Voters: 55. You may not vote on this poll | |||
YMTC: Redabot completes an autonomous lap
Thank you 2008 GDC! You Make The Call (YMTC) is a series of situations where you are the official and make the call.
Please reference specific rules when applicable. The results of YMTC are not official and are for educational purposes only. Welcome to the inaugural Dogwood Regional. Redateam has created one of the fastest cornering robots that the FIRST community has ever seen. On Thursday, Redateam’s autonomous code, designed to send Redabot racing around the track and across at least five “lines,” was giving them a serious headache. Redabot was bashing into wall after wall after wall. By Friday morning, however, Redabateam had their autonomous code seemingly ready to roll. As Redateam’s first match of the Dogwood Regional begins, Redabot shoots out of the gate, screams across the Red finish line, and makes the first turn in hair-raising fashion before slamming into the outside wall in the Blue Home Stretch. Still moving, though at a noticeably slower pace, Redabot zips across the Blue finish line, down the Blue lane, and comes crashing into the Red Alliance Station Wall. With time running out, Redabot crosses into the Red Home Stretch, makes a turn, and limps toward the Red finish line to try to score that fifth line. As the buzzer sounds, Redabot’s front wheels have only just reached the finish line. Redabot then coasts to a stop nearly seven feet beyond the line as Redateam erupts into cheers for their rambunctious robot! How many points has Redabot scored for Redalliance? Based on the 2008 Rules, YOU MAKE THE CALL! |
Re: YMTC: Redabot completes an autonomous lap
By the rules, a robot must have completely crossed the line when time expires in order for the points to count. Redabot scores 4 lines, for 16 points.
16 points. <G04> gives us the basic 4 points per line.
Team Update #13 says, "determine the scores contributed by the Robots based on where they are when the clock reaches zero." So even though Redabot coasts way across the line, that 5th line doesn't count. |
Depends on if they get penalized for ramming the Red Alliance Station wall or not.
Are we assuming a penalty free Hybrid Mode here? Because that wasn't specified this time in the description. And yes, it has happened in the past. Teams have gotten penalties for ramming the Alliance Station walls in Hybrid. (Good or bad, it is what it is, and needs to be defined before I can agree with the previous posters) |
you can't score 18 points in auto... lol I'm on to your games!!!
![]() ![]() ![]() (the answer is 16 points, our robot did this time after time.... and only once did it manage to score the fifth line lol, its weird how timers work sometimes lol) NO SENSORS FOR THE WIN!! Last edited by T3_1565 : 01-04-2008 at 16:36. |
One point of clarification might be helpful in the scenario.
16 points IF (a big one, too) most likely it can be assumed that the CLOCK reached zero, at the same time as the "buzzer sounded". But just to be clear, the rule is when the time reaches ZERO, not when the Buzzer sounds. In the past, the time and the sounds being used weren't always in sync. I haven't watched closely enough this year to hear if the sound of the buzzer, was sync'd up with the time reaching zero - perhaps someone else can tell. Mike |
#7
I guess the issue here is: Redabot has completed a lap, but it doesn't count in hybrid. Should it's completed lap then be counted in teleop? I would guess that it just wouldn't be counted at all for the sake of following the rules consistently, but still...
#8
I see where you are going with this: Redabot would have been better to stop before line 5 and thus get a lap in the beginning of tele. It is unfortunate that they have lost those 2 points from the lap, but that is the way it goes. I have never put much stock in the fifth line even though my robot is fast enough to get it (if it was just running laps or maybe only knocking the inner track balls). Instead of a close race to the fifth line the bot makes sure it gets the fourth line by not turning as much. I know the finish line will be 2 points in tele, and the homestretch is a better starting position for acquiring trackballs that may be near the finish line or not successfully knocked.
#9
The CROSSING does not occur during hybrid, so no points can be awarded under <G04>. It also does not occur during teleoperation, so no points can be awarded under <G06>. Their score at the beginning of teleop is 16, and Redabot has to complete almost a full lap to score their next two points. Should have set those Victors to brake!
#10
And as they coast underneath the overpass, they contact a red trackball as the buzzer sounds, and as redabot coasts to a stop the trackball falls to the ground.
Bonus or no? Jason |
#11
I hope this is a rule IRI fixes.
All robots scored when they come to rest Simplifies the officiating and is easy to understand. |
#12
I love it when people point out odd loopholes in the rules. I'm actually going to go with 18 points. The reasoning:
I don't see any question here. This has been one of the most consistent calls that I have seen in all of the regionals I've attended and watched.
At time zero, the robot has crossed 4 lines, and thus earns 16 points. Also, the robot receives a warning for slamming into the opposing wall and will receive a yellow card the next time it occurs. At the beginning of teleoperated, the robot is considered to be in the quadrant immediately following its home stretch for the purposes of the game (G22...), and will have to go around the field to get points for a lap. If I were this team, I would either speed up the autonomous or stop before the finish line so I receive the most points for my effort. Do I think this interpretation is asinine? Yes. Is that relevant to how the rules have consistently been called? No. Does it confuse the audience? Of course. Will the GDC change the rule? Doubtful. Will IRI change the rule? One can hope... but I digress. 16 points. End of story, and no argument. |
| YMTC: Redabot Disrupts Ringers | Natchez | You Make The Call | 13 | 16-01-2007 23:34 |
| YMTC: Bluabot Caps Redabot | Natchez | Rules/Strategy | 4 | 15-01-2007 09:47 |
| YMTC: Redabot grabs rail | Natchez | You Make The Call | 10 | 10-04-2004 12:16 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
