Go to Post If there's one thing that I love, it's a good scouting challenge! - wilhitern1 [more]
Unread 20-03-2008, 22:44
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Smile modified toughbox
has anyone modified the gear ratios to make them faster?
if so what did you do?
because team 1557 was thinking about new trains and we wanted to change the gear ratios from 12-1 to something lower
Unread 20-03-2008, 22:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: modified toughbox
We did this, by removing the second stage of gear reduction. It requires drilling some holes in the aluminum plate to clear the ends of the motor shafts, and playing with the end play spacing of the large gear, plus relocating the gear tooth sensors (if you are using them). For 4" wheels we used a 1:2 sprocket reduction ratio (12 tooth on the transmission, 24 on the wheels).
Unread 20-03-2008, 22:52
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Yes, we used a few gears from the toughbox and a few gears from the AM supershifters (both of which we had lying around, you can buy the individual gears online). We then simply CNC'd new front and back plates for use of the new gears to press the front and back plates into. Like the toughboxes, we used lexan for the motor side, and 1/4" aluminum for the mounting/output side.
The ultimate ratio was around 7.8:1, much higher than the toughboxes, and slightly higher than the high speed of the supershifters. They have worked perfectly without a hitch. They took an evening to design, 2 days or so to CNC 4 perfect plates, and another day to assemble and break in.
Do you have any specific questions?
Unread 20-03-2008, 22:58
gorrilla's Avatar
AKA: adam spears
well we were thinking about changing the gear in the back which is connected to the drive sprocket with a smaller one to bring the reduction to about 2-1 or maybe even 1-1 and then putting smaller sprokets on the wheels because this year we were very slow compared to the other teams at only 9-10 fps because our am 2 speeds were stuck in low gear wich sucked and we couldent put it in high and leave it or the chains would slip
Unread 01-04-2008, 18:29
gorrilla's Avatar
AKA: adam spears
update)(
weve done it we removed the second stage and given our gearbox a 1-3 (increase)?? by doing the math we have founs that one on each side with 2 cims would give us 23+fps or more depending on the sprockets on the wheels
Unread 01-04-2008, 19:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I do know for a fact the Team 1147 did exactly this. From the reports I had, it was really fast!
It did take some rework of the Toughbox to get the gears lined up, but it was worth it. I believe the final gear ration is 6.38:1.
I'll see if I can get one of the students to post up on how they did it and how well it worked.
Unread 01-04-2008, 20:50
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
update)(
How's the turning?
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-04-2008, 17:13
gorrilla's Avatar
AKA: adam spears
i havent tested it on the robot yet but as soon as i get a 6-wheel drive going i will
it will probobly be done sometime this month or next depending on how much time we work and what not
p.s. the 23+ fps mark was the speed one wheel would turn if we had to cims on each side so with 4 to 6 wheels and the correct sprocket size we should be around 20 to 26 fps...
Modified AndyMark Gearboxes Rob2713g Technical Discussion 4 18-02-2007 16:03
Problem with Modified Code Brigander Programming 14 31-01-2007 13:25
pic: A nikko RC car, modified Andy A. Extra Discussion 11 20-03-2005 11:59
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
can motors be modified ronnie_82 Rules/Strategy 2 18-12-2002 13:26
