Go to Post I admit that it isn't practical...but it sure is fun. - Crebb [more]
Unread 02-04-2008, 16:17
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Not Compiling
Our team recently got a laptop from our high school to use mostly for programming. I just installed MPLab, the C18 Compiler and IFI Loader.
Then I tried to compile my program and I keep getting an error saying that ADC_16ANA cannot be found. I tried trracing the problem it looks like its coming from adc.h, which I do not have the source code for.
Anyone had a similar problem or can help me solve it?
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 02-04-2008, 16:48
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
Re: Not Compiling
I would double check to make sure you had the right versions of MPLAB with the C18 compiler.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 02-04-2008, 17:09
Re: Not Compiling
What version of C18 did you install and what baseline code did you start with?
You'd better have adc.h, otherwise I'd say the C18 installation failed.
It should be in mcc18/h
Unread 02-04-2008, 18:15
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Not Compiling
Did you have administrative rights on the computer when you installed, and are you running with administrative rights? (Is it XP?)
Ours gave us a whole host of wierd errors when we installed under the admin account and used another one to compile.
Unread 02-04-2008, 21:11
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
Re: Not Compiling
You should make sure that MPLab is linking to the correct library and the correct compiler.
Unread 03-04-2008, 14:55
popnbrown's Avatar
AKA: Sravan S
Re: Not Compiling
Well, I wanted to get the compiler working yesterday, so I spent some time. I read through the Kevin Watson's thread on his C18 3.0+ and I found out that adc.h was messed up on C18 3.15+. So I upgraded MPLab to v8 and then re-installed C18 Compiler 3.10. It still was looking for the variable. I then installed the C18 Compiler that was given to us on the 2008 Microchip CD and I guess it either overwrote the 3.16 and it now works.
Thank you for your replies but the problem has been solved.
I got a little worried that it might not work and posted before completely finishing my investigation of the problem.
thanks again,
sravan
Compiling Files Gherkinman Inventor 4 19-02-2008 21:55
ADC_CHO not compiling in Kevin's code Hazmatt Programming 2 13-02-2008 20:29
Compiling problem Anime-niac_2.9 VEX 4 19-10-2006 16:13
compiling in MPlab Greg Needel Programming 2 16-12-2005 12:43
Compiling Help!! ajsetter Programming 14 13-10-2005 10:38
