Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Unread 02-04-2008, 17:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Extendable PWM Cables?
Does anyone where I can purchase extending pwm cables similar to the extending air hose that came in this year's KOP. My team's getting a little close to weight because of a new mechanism we want to add for The Championship and I know that in Philly we used some super heavy wire for a sensor and it weighted alot. If anyone can point me in the right direction it will be greatly appreciated.
-Dustin Benedict
Unread 02-04-2008, 18:23
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: Extendable PWM Cables?
Wow you must be on a SERIOUS weight loss plan to be going to thinner wire....
I usually get mine a the local Hobby Shop as they are used for rc stuff as well but here is some online places:
http://www.ifirobotics.com/accessories.shtml
http://www.robotmarketplace.com/prod..._adapters.html
Unread 02-04-2008, 18:24
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Well we arent sure how much the new piece will weigh and right about now we are about 119.5
Unread 02-04-2008, 20:48
thefro526's Avatar
Mentor for Hire.
Umm yeah we used about 24 feet-ish of 12 gauge wire wrapped in tape so my guess is that going to a normal pwm cable will save weight. I need something coiled though because a normal cable is a little fragile. Is there anywhere where I can buy coiled wire from and make my own?
W00t 400th post
-Dustin Benedict
Unread 02-04-2008, 21:07
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Just use a four conductor telephone handset cable, ignore the fourth cable, and splice on PWM bodies onto the ends.
If you have two sensors, you can share the Vcc and Ground between the two, and use the remaining two wires for the signal wires.
Either that, or use a bunch of the iGUS cable chain and run all your wires and/or pneumatic air lines through that.
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-04-2008, 21:20
thefro526's Avatar
Mentor for Hire.
I think I'll give the telephone headset cord a try it's gotta be lighter than what we have.
-Dustin Benedict
Unread 02-04-2008, 22:06
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
For long distances and multiple PWM cables, we use cat5e. I think this year we ended up running up 3 cat5e cables. We try not to share the ground and the power, even though we can, it's hard to splice into the middle of a cat5e cable and have it work okay. =p
But yeah. That's how we run PWM cables long distances. Not sure how it affects weight.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 02-04-2008, 23:18
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Then you must be using some really heavy wires, that telephone cable is surprisingly heavy - keep that in mind!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 03-04-2008, 00:40
dgitz dgitz is offline
FRC #2219
dgitz is an unknown quantity at this point
It depends on what kind of sensor you're using, but you might be able to get away with wire-wrapping wire (24 AWG I think). Now that stuff is light. Can't handle much current though, so be warned. We've used it on a PING module before. You really have to worry about it being in a spot where it could be broken too.
Unread 03-04-2008, 01:08
Colin's Avatar
Colin Colin is offline
FRC #0254
Colin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond repute
On 254 we make our own PWM cables, they help to clean up the wiring and especially make long runs such as the one from the rc to the flag holder much easier. This year we used crimps from Hansen Hobbies, http://www.hansenhobbies.com/, these crimps can also be obtained from such suppliers as Jameco. As for the wires themselves we used cat5 cable on the electronics board and used 24 gauge wire from McMaster for the long sensor runs. A simpler solution for the wire would be to just use the servo wire Hansen Hobbies sells, it is the same as the kit PWM cables. From what I have heard the economy wire works better, the deluxe wire is of a higher gauge and does not fit in the housings well.
Unread 03-04-2008, 08:19
I think the telephone cords are a good way to handle this. I caution teams that use CAT cable as this cable is made of solid copper conductors which break when you need them the most. Solid conductors are not meant for moving devices and require additional thought in strain relief and wire management.
Unread 03-04-2008, 10:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Seconded! Our electrical team used CAT5e for wiring part of our operator interface. Poor strain relief lead to a broken 5V wire lead to our lift stuck at mid extension for an entire match and our robot stuck in one quadrant since we couldn't clear the overpass.
Unread 03-04-2008, 13:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We use stranded CAT 5 to avoid this.
2001-2004: Team 100
2006-Present: Team 254
custom PWM cables bruss6 Electrical 6 16-02-2007 08:33
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
