Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 02-04-2008, 10:58
Barak Shelef's Avatar
Barak Shelef Barak Shelef is offline
FRC #3316 (D-Bug)
Barak Shelef will become famous soon enoughBarak Shelef will become famous soon enough
Help with Roller chains
Hey all you Inventor Gods,
Well, im trying to use the Design excellerator to create roller chains for the robot design, but I don't know how to use the chain pins and rolls of the KoP (the ones I downloaded from FIRSTBase - a single pin and a single roll models).
Plus, I'm having some trouble using the sprokets, I understand there are the iMates that should help me align all the stuff, but after I align the two sprokets the design excellerator says somthing about needing a 'sliding sproket' and because im using existing sprokets I can't make them 'sliding sprokets' .
Finally, when I do render somthing it's a strange blue semi-transparent continious chain :S how can I switch that blue stuff to my actual chain parts?
Anywho, generally I need a tutorial for making chains, since I saw you guys have a proper chain, maybe you could give me a hand in this ?
Thank a lot,
Barak Shelef
Inventor dude
FRC#2230
Unread 02-04-2008, 18:26
Aceanuu's Avatar
Aceanuu Aceanuu is offline
FRC #1477 (Northside Roboteers)
Aceanuu will become famous soon enoughAceanuu will become famous soon enough
Re: Help with Roller chains
As far as I know, there is no system to make a chain automatically (like one you'd see on a bike or something), all I think Inventor can make is a semitransparent loop.
The chain I made is not very adaptive, so make sure you've got the dimensions right for the chain before you make it, heheh.
To make my chain, well, it took a while... lol. Basically, I made the sprockets i needed with the design accelerator, copied the sketches of the outline of the gears, and pasted all the sketches of the gear outlines in one file. I then made one figure 8 thing with two circles in the middle of each end (the link and the two pins bascially). The key to this part is to make the two pins the little dots at the center of the arcs of two adjacent teeth on the sprocket. Then make the figure 8 shape between those two pins. However, don't extrude anything till you are totally done. Well now that you have the two pins and the one link done, simple circular pattern this around the center of your sprocket sketch, you'll have to adjust the angle of the iterations so that the chains wrap around the sprocket as far as you want them to. Then simply copy one of the links and angle if from the sprocket to the other sprocket and rectangular pattern them in the line. This is basic concept I used.
I know thats confusing, but it should be pretty simple if you get the concept.
Unread 03-04-2008, 00:23
FRC #3316 (D-Bug)
Ok thanks man, I'll try that Any other suggestions :O ?
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Roller chains generator Daniel_H Inventor 5 14-01-2008 19:50
chains sburro Technical Discussion 13 07-10-2004 11:37
chains in 3ds tinsLee123 3D Animation and Competition 4 17-02-2003 00:14
chains enjoiwheels Inventor 0 08-02-2003 19:33
