Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 13-03-2008, 10:05
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: FIRST FRC Game Simulator for the HL2 Engine
I like what I'm seeing so far! I wish I could help out in some way technical, but programming has never been my forte. If you guys need a public relations or whatnot, don't hesitate to contact me.
As mentioned above, both simulations could be useful. The HL2 version as a "marketing" tool for FIRST, getting the word out. The XNA version maybe to use "internally" as a training and strategic tool for teams.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 13-03-2008, 21:24
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by Caio View Post
If you can explain how to convert an inventor file to the file type you need, I can see if I can make a model of our '06 robot and convert it for you....
and the same would go for other teams. I'm sure a lot have them in inventor, and they'd probably be happy to convert it for you.
I'll answer your question converting at the bottom of the post as it applies to both.
Originally Posted by lachoneus8 View Post
XNA has the benefit of being free for everyone to develop for, and is based off of C#, which is relatively easy to learn. Halflife 2 of course benefits from one of the most advanced graphics and physics engines in the 3d market.
I think both FIRST simulation engines can have their place. There are many ways that these applications can be used, and each can focus in a different direction. These simulations could be used for spreading FIRST to larger markets through an online game, helping teams plan their strategies early in the build season, teambuilding excercises, etc etc.
What model formats does the Halflife engine support? If people produce their robots in a common format both engines could use, that would help both simultaneously. XNA reads in only Autodesk FBX and DirectX .x formats, but with Blender (3d modelling software) I can import from 3DS, OBJ, and a bunch of other formats. 3DS might be the best format all around seeing how common it is.
I could see about exporting our 3 models into 3ds if you would like, cbale.
Dave
The Half Life engine supports it's own format VMF (Valve Model Format), however 3Ds Max is capable of both exporting to this format, as well as creating collision meshes for it (Might require a free extension, I have to get a few more details from a friend).
So basically anything in a format 3Ds Max can read would be ideal, (unless someone wants to be REALLY helpful and just convert them to the Valve format, not a big deal though).
I have found several things related to converting Inventor Files to 3Ds Max.
The first seems to be a feature for 3Dsmax that comes with Inventor if you have both installed on the same PC:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3943
The second one is more of just a plugin for 3Ds Max 9 (which doesn't help me any since we're still using version 7 because we don't have the godlike system requirements to run 9).
http://usa.autodesk.com/adsk/servlet...112&id=9093251
Thanks allot you guys, glad for the help!
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 13-03-2008, 21:42
lachoneus8's Avatar
lachoneus8 lachoneus8 is offline
AKA: Dave
no team (5th Gear - First Robotics Simulation)
lachoneus8 is an unknown quantity at this point
Here's a few questions:
1) What are the capabilities of Garry's Mod as it relates to Aim High? How about networking?
2) How easy or difficult is it to articulate a robot with moving parts?
3) What would it take to get this to the public? Being a Half-Life mod I would imagine it would take Halflife2 (heavy system reqs right?), plus Garry's Mod, plus whatever additional Mod info you've written for scoring, anything else?
4) What are your plans with this after you complete your senior project?
Don't think I'll be able to make the Atlanta finals... make sure to take plenty of pictures and video once you get it up and running
5th Gear: Multiplayer 3d simulation of Overdrive
Here it is in action:
http://www.chiefdelphi.com/media/photos/30906
http://www.chiefdelphi.com/media/photos/33219
http://www.youtube.com/lachoneus21
Mentor for the Marsteller MS robotics club
Unread 13-03-2008, 23:33
cbale2000's Avatar
AKA: Chris Bale
1. Garry's Mod is a sandbox mod that allows you to use various effects, such as physics and constraints and apply them at will to spawnable props and such. You can create your own scripted entities using one or more models (with animations if needed). It is fully compatible with online mode on Steam.
2. If needed, models with various moving parts can be implemented as several different models that just work together. Smaller features such as wheels could be done but would probably be easier (and less laggy) as animations. The other reason I picked Aim High was because most of the robots used spinning parts as opposed to arms and mechanisms that changed positions, this is a lot easier to script.
3. As far as distribution of the mod goes, I have an SVN server setup for hosting the files relating to my modification, currently it is just private access for me and my partner but it could easily be modified to share publicly. As a Half Life 2 Mod, the only thing it would require is one of the Half Life 2 Related Source programs (like HL2, CSS Source, ect.) this in it of itself is not very system intensive. Garry's mod is a cheap addition to HL2 and hopefully is only temporary for use for the Senior Project, after that is done I would like to make it into it's own Stand-alone HL2 mod so it would remove the need for Garry's mod. This mod itself would likely be less system intensive as it would not need to utilize all of the Physics and graphical effects that HL2 and Gmod use.
4. As mentioned above, after the senior project is complete (and I have a bit more free time) I would like to make the mod into it's own separate HL2 mod which would remove the need to have Garry's Mod installed as well as eliminate some of the higher level system requirements. The coding would also be converted to C (or it might be C+, haven't read the documentation in a while) to allow for this.
If you have any other questions feel free to ask, I have to go get some sleep now though, don't want to be late for the regional tomorrow.
Unread 14-03-2008, 14:35
lachoneus8's Avatar
AKA: Dave
With the advanced physics and great graphics, HL2 could make for a highly realistic simulation of FIRST games.
Sounds like the HL2 FIRST mod will be a veritable playground of fun! Perfect for testing of mechanisms and ideas during build phases. I can see this effort being a great way to bring others in the gaming community to see the fun of FIRST.
IThe coding would also be converted to C (or it might be C+, haven't read the documentation in a while) to allow for this.
Ahh, so your senior project will be purely written in Garry's mod scripts? That's one powerful mod, to allow all of that just in scripts!
Unread 14-03-2008, 22:32
cbale2000's Avatar
AKA: Chris Bale
Yes, that was my feeling on the concept as well.
As far as customization goes (in addition to adding other own robots), one could also make their own maps to recreate different venues and make the experience more realistic. The map I'm making is just a simple, generic kind of stadium (for now anyways), but you could easily expand upon that and add things like moving lights, pit areas, and stuff like that. I should also point out that I plan on using some of the sound effects from FIRST matches (music, buzzers, bells, crowd cheering, ect.), maybe even throw in some announcer statements too.
Garry's Mod uses a modified version of LUA code, it is written using a C style, so generally it is very similar to C, though a bit more strait forward.
Unread 15-03-2008, 08:30
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Originally Posted by commodoredl View Post
I think 174 (The Arctic Warriors) did something like this with Overdrive. I was able to download a map for this year's arena from their site. They had some code available if anyone wanted to see it, so if you can find them you might want to check it out.
Looks very cool otherwise, now I wish we used Inventor for our robot designs.
Yea. I don't know much about it, but the guys who worked on it are really cool and will make a joint effort with you guys if you ask.
Here is the Overdrive Simulation from the website and the guy's email is at the bottom:
http://snobot.org/snobot/Pages.aspx?page=Simulation
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 15-03-2008, 13:31
lachoneus8's Avatar
AKA: Dave
When it rains, it pours Years without a 3d simulation of a FIRST game, and now they're sprouting like weeds.
Team 174's work looks sweet!
Unread 17-03-2008, 16:53
cbale2000's Avatar
AKA: Chris Bale
Wow, that looks great! Almost exactly like what I'm working on, but a different year. I would be thrilled if we could work together on this!
Unread 17-03-2008, 16:56
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
seems to me the finish lines are in the wrong places, shouldn't the red one be moved up, as well with the blue?
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 03-04-2008, 12:54
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
I'll look into making a model of Pandora, Team 540's bot. What are the polygon requirements you're after?
What other things are you in need of? (textures, models, etc.)
I've got The Orange Box and relevant Source SDKs, but not Garry's Mod (for now... plan on getting CS:S with Garry's Mod soon), so if there's anything I can help with, I'd like to give it a try.
-Jake Alexander
Unread 03-04-2008, 21:31
cbale2000's Avatar
AKA: Chris Bale
I believe there is like a 150k poly limit in Source, but I don't really see anyone coming close to that. To be honest, I really don't have any preference as to how many polys so long as it looks decent.
Right now I'm trying to get the FIRST logo as a texture so I can apply it to the field. That and I'd like to try and get a new skin for the red lights so the blue alliance can have indicator lights on the player stations.
If you are familiar with converting graphics to textures, that would be the most useful thing right now.
Also, to those of you who offered models, I'm at a point now that I could use a few to work with so if any of you have a model available that you could email them to me or something it would be very much appreciated.
New Screenshots coming soon (If I can get the latest version to compile sometime this year).
Unread 27-04-2008, 15:43
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Folks,
A link to a YouTube video of the Overdrive simulation Lockheed Martin folks whipped up this Spring (mentioned in other messages in this thread) is available in the first post in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?p=743349
The specific message containing the link is here:
http://www.chiefdelphi.com/forums/sh...89&postcount=1
Blake
Unread 11-05-2008, 16:49
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Folks,
As these simulation threads pop up I am trying to keep track of them and supply us all a road map of URLs that will let us pool our talents when/if we ever want to do that. Here is my list so far:
Blake
**FIRST EMAIL**/FRC Game Hint #2 Gamer930 FIRST E-Mail Blast Archive 699 04-09-2008 17:29
**FIRST EMAIL**/The Autodesk FIRSTbase site has re-launched for the 2008 FRC Season! Mark McLeod FIRST E-Mail Blast Archive 0 20-11-2007 09:20
**FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams Goobergunch FIRST E-Mail Blast Archive 1 06-01-2005 09:29
FIRST Video Game: Choosing an engine Astronouth7303 FIRST-related Organizations 11 16-06-2004 22:48
