Go to Post The pen [may be] mightier than the sword, but the bandsaw can chop them both. - Marc P. [more]
Unread 02-04-2008, 07:46
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: How do the Shooters work?
Originally Posted by Sam N. View Post
Pneumatic pistons by themselves (directly pushing a ball) are not enough to get the ball over the overpass when firing from the ground.
Hold on a minute! Here is a quote you should heed:
Originally Posted by Arther C Clarke
When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong.
I don't know how many time I heard on this very forum all through January and February that "so-and-so will never work" or "This mechanism cannot do that".
Two examples I heard over and over involve the use of vacuum to acquire and hold the ball, and pneumatic cylinders (thats the proper term, the piston is the part inside the cylinder that moves) used to shoot. I read numerous posts that said things like "you can't pick up a ball with vacuum", "the cover is too porous", "you can't develop enough holding force" as well as comments like the one you just posted.
I believe that, while well intentioned, these comments discourage innovation, and prevent people from trying new approaches. Just because you haven't figured out how to make something work doesn't mean it's impossible. If you read my earlier post in this thread, and visit the links there, you will see that not only can pneumatics alone "get the ball over the overpass", they can do it very well.
I think this point is so important, I should start a new thread.
Here is a true story that illustrates what people can do if you don't tell them it's impossible.
A young college student was working hard in an upper-level math course, for fear that he would be unable to pass. On the night before the final, he studied so long that he overslept the morning of the test. When he ran into the classroom several minutes late, he found three equations written on the blackboard. The first two went rather easily, but the third one seemed impossible. He worked frantically on it until, just ten minutes short of the deadline, he found a method that worked, and he finished the problems just as time was called. The student turned in his test paper and left. That evening he received a phone call from his professor. "Do you realize what you did on the test today?" he shouted at the student. "Oh, no," thought the student. I must not have gotten the problems right after all. "You were only supposed to do the first two problems," the professor explained. "That last one was an example of an equation that mathematicians since Einstein have been trying to solve without success. I discussed it with the class before starting the test. And you just solved it!"
http://www.snopes.com/college/homework/unsolvable.asp
Former Mentor Team 1771
Former mentor Team 4509
Unread 02-04-2008, 08:32
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I always love reading quotes like this, since Team 95's robot does exactly this, with quite a bit of margin:
Yes, we use six cylinders in a two-stage arrangement, and it took more than a little tweaking, but we are "directly pushing on the ball" with nothing but pneumatic pistons. We could get even better performance if we triggered the two stages separately at staggered intervals, but we called this setup good enough.
Unread 02-04-2008, 18:30
cwood's Avatar
cwood cwood is offline
AKA: Chris Wood
FRC #1629 (Garrett Coalition)
cwood will become famous soon enough
team 1629 uses two cylinders and two springs to fire the ball.
First the cylinders are charged to extend the springs and lower the scoop (fancy curved catapult) it is then latched with 1 small cylinder. At this point the only force is the springs but as we begin the firing sequence the opposite side of the cylinders is charged (applying force in the same direction as the extended springs) and when the latch is released up the scoop, and what ever may be on it, go. This arrangement gives us gives us the ability to hurdle from ranges back to the end of the lane dividers, as well as the ability to launch diagonally from one homestretch to the other.
Its was a tricky arrangement to control until we discovered that it was much easier to let the programming do the timing required to be efficient.
if you have any other questions you can message me or stop by our pits in atlanta
what do you mean its too expensive?
-visit http://www.team1629.com
Anyone play tribalwars message me on w11 name is wooc3860
Unread 02-04-2008, 20:31
ttldomination's Avatar
Sunny
We do nothing too complicated. We have a fork lift which take the ball in. and then we use surgical tubing and tie our shooter to a bar on the robot. Then we use a wench to pull the shooting platform back...and bam.
1648: 2013-2014
5283: 2015
Unread 02-04-2008, 20:32
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Most shooters took inspiration from the team that released their design rather early in the build period. Our team planned to build a shooter all along, and endeavored to make several prototypes before the real thing. This is what we learned.
Pneumatic pistons by themselves (directly pushing a ball) are not enough to get the ball over the overpass when firing from the ground. This comes from the fact that the pistons extend too slowly (the inherent problem of filling large chambers with small air tubes). While the pistons did provide enough force to move the ball, but they did not deliver that force quickly enough.
The question we were faced with is: what can deliver the same amount of force on the ball over a shorter period of time? To us the answer was clear: springs.
Huge springs, two of them. 240lbs of force combined. We used two 2in bore pneumatic pistons to extend these monster springs, and a small .5in bore piston to operate a latch that would release all this potential energy when retracted.
That's the concept. The actual construction was more complicated. We were faced with more problems such as: how can we extend the springs with the pistons, and then disengage the pistons from the springs when we wanted to fire. Keeping the pistons connected to the springs would lead to an unwanted decrease in firing speed.
I will post some pictures of our spring-loaded catapult later if I have time. Any questions are welcome.
Sam
Perhaps I seemed close-minded when I commented about using pneumatics to fire the ball over the overpass. Let me be more clear about our prototyping endeavors.
We found out that using two 1.5in bore pneumatics (directly pushing on the ball) only fired it around 6.5 feet high. That not being enough, we sought out other ways to shoot the ball higher.
So I was wrong when I said that using pneumatics to directly push on the ball wasn't enough to hurdle. I should have said that using two 1.5in bore pneumatics (directly pushing on the ball) wasn't enough to hurdle.
So I stand corrected because my original statement was vague. You certainly may use cylinders to push the ball directly if you have enough energy to do so. Many of the shooters (including ours) used compressed air for a reason, it was not my intention to discourage its use. (I'm also sorry if I ticked anyone off, everyone is proud of their own designs - for good reason too!)
Attached is a picture of our catapult in construction (left side of picture). Two pneumatics (as shown) are used to extend two springs of that size (only one was on the robot when the picture was taken). A small pneumatic controls a latch that releases the potential energy at operator command.
The 2in bore pneumatics are connected to the rotating structure that the latch cylinder is mounted to. When the large cylinders retract, the latch will hook on to the catapult structure. When the large cylinders extend, the latch will pull on the catapult until the springs are extended about 8 inches. When the latch disengages, the catapult will fire as the springs release their energy. The entire reloading process is automated.
It consistently shoots the ball 12 feet high.
Once again, sorry for coming off as close-minded,
Sam
Mitty Robotics Alumni
TKO 1351
Unread 02-04-2008, 20:56
martin417's Avatar
AKA: Martin Wilson
Nothing to apologize for, I don't think you ticked anyone off. Your comments just brought to mind something that had been bothering me for some time, and I decided to address it. As I said this type of comment is generally well-intentioned, (trying to prevent a team from wasting time on an approach that is destined for failure?) but if not done very carefully, can stifle creativity. I think it is OK to say that a specific design wont work (if you are absolutely sure, and completely understand the design) as long as you can point out alternatives. But making blanket statements about the unworkability of concepts should be avoided.
My 2 cents. (again)
Unread 02-04-2008, 21:23
PizzmasterP27's Avatar
PizzmasterP27 PizzmasterP27 is offline
Alumnus/Mentor
AKA: Pizzey
FRC #0027 (Team RUSH)
PizzmasterP27 will become famous soon enoughPizzmasterP27 will become famous soon enough
Lightbulb Re: How do the Shooters work?
You guys (MORT 11) are going to the champoinship. Feel free to come by the pits of team rush 27 and ask any of our members how the catapult works. A brief description is that we use an andymark gearbox as our winch and we pull back our catapult arm which has 400 lbs of surgical force. This force is distributed to 8 cartridges of 50 lbs each. more detail on motors, sensors and such can be provided in our pits.
As i said, feel free to come and ask any member. We are trying to get everymember involved in answering questions for people too.
Unread 03-04-2008, 15:00
Yup, I'll be dropping by a couple pits to scout anyway. I'll make sure I'm the one scouting your robot
Unread 03-04-2008, 16:10
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
We evaluated a number of different piston configurations, some of extreme throwing distance and some that were too weak. All of them are completely pneumatic, including the one that's actually on our robot right now.
We ended up using a four small bore piston shooter mounted high atop our robot, as near to the overpass as possible. We used this lower-power-requirement/output shooter configuration because it was faster than a huge pneumatic shooter. With the fast grip/lift on the front and the relatively low air usage shooter on the back, we arrived at the fastest recharge time system we could think of.
Feel free to come by in atlanta, any of our guys would be more than happy to answer any questions... we're easily locateable by the highlighter yellow numbers and robot.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 03-04-2008, 22:48
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
Well 384's and 1086's shooter uses 4 Bimba Pistons (i dont remember the technical information but you are welcome to drop by in Atlanta if you are coming to the nationals) that are supplied by 4 Clippard Tanks filled up by our compressor. We have set up our pistons as the hypotenuse of a triangle, the base we adjusted until we got the best horizontal and vertical distance. If you want a pic of the set up check out this link:http://virginiafirst.org/FRC/2008/pr.../target50.html
(You could see the bimbas and the clippards)
Unread 04-04-2008, 02:11
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Our shooter is really rather simple, but it seems like every time I try and explain it without it available (and even sometimes with) as a visual aide it takes a while to get the idea through to people. It's pretty much a metal "plunger" (flat end on a section of square extruded aluminum) inside of a slightly larger shaft of aluminum, tensioned with surgical tubing, using a linkage setup connected to the center of a decent sized sprocket with a catch on it. The sprocket is powered by a fisher price motor through a dewalt tranny in 1st gear. The linkage is grabbed by a catch on the sprocket on its way by. When "loaded", the linkage is doubled back to about 1/2-1" before crossing center. When the fire button is pressed, the rollers spit out for a second, while the sprocket merely cranks the linkage past center, releasing the potential energy of the surgical tubing in the direction of the ball. Thus propelling it in an upward fashion towards the overpass. Please stop by our pits in Atlanta to see for yourselves. If you didn't grasp the idea from my attempted description. It's really quite simple and elegant. Can't wait to see everyone else's designs!
Unread 04-04-2008, 11:37
GaryVoshol's Avatar
Cogito ergo arbitro
But you've got to see (and hear) it on the field too - it has such a great "WHOOMP!" sound to it. Last year's crashing ramps, this year's shooter - Rush is the team to listen for.
(since 2004)
Unread 04-04-2008, 15:51
Brandon Holley's Avatar
We too have a nice "SLAM!" sound as the robot releases teh ball...thast what 300+ lbs. of spring force will do for you.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-04-2008, 16:33
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Our shooter makes a sound quite like a pneumatic impact wrench when it goes off.
It sounds quite bit like this, but louder.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 04-04-2008, 22:53
The Farmer The Farmer is offline
Not a just a caveman
AKA: Jason Farmer
FRC #0191 (X-cats)
The Farmer will become famous soon enoughThe Farmer will become famous soon enough
Send a message via AIM to The Farmer
While the robot our team built this year doesn't implement a shooter, I did see a very interesting shooter that did awesome at the FLR regional. It was by the Cyber Crusaders (I think), and instead of using pneumatics, it used a kind of electro-magnetic catapult. Try and hunt down one of their members if you can for photos and stuff.
Linear Shooters - How did you do it? Leav Technical Discussion 19 10-03-2008 17:20
How many shooters do we have??? Kevin_547 Scouting 18 20-02-2006 11:05
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
How do the servos work? tml240 Motors 25 18-02-2004 07:47
How does the IR setup work? phrontist General Forum 1 02-02-2004 21:34
