Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 03-04-2008, 15:08
Re: MK Battery Problems
Mitch,
The spec is 11mOhm nominal so I wouldn't be too worried even up to 15 or 20 mOhm. However 5 ohms is way too high. I know the construction of this battery does make it possible to damage the terminal inside the red/black coating at each terminal. Picking up by the wire is a guaranteed failure.
Unread 03-04-2008, 15:42
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Just to reiterate, team 125 had 2 bad batteries go down on us at the boston regional.
One was from 2007 KOP the other from 2008 KOP. Other than that I dont have the exact details from them, however when put under load (with a load tester) we got a reading around 9 V for both of them.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 03-04-2008, 16:51
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Brandon, when you use the load tester on an "in working order" battery, what is the "regular" reading you would get?
-Michael Dessingue
Unread 03-04-2008, 17:14
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
Our 2 batteries from the 2007 KOP act like they have take a charge then when you put them on the robot the voltage immediately drops. I haven't load tested them, but we just don't use them now. They went dead while we were using them on our 2007 bot to practice in the fall. They've been charged on both a NAPA charger and the new Schumaker.
Unread 03-04-2008, 18:57
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
To test the theory of a bad batch of batteries, here is the lot number for the bad batteries that SparX had.
Lot Number: 061009D
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 03-04-2008, 19:23
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
We dropped one of our batteries from last year. The little plastic strip on the top of the battery came loose, giving access to the cells. Later, that battery tipped over somewhere, and the acid poured out of it. When this happened, it still has 12V on the posts, but when we tried to move, it would reset the controller. Obviously, if there is a problem with a battery, then its either the posts or one or more of the cells.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 03-04-2008, 19:51
Please do not continue to use a battery that has leaked. Please.
Unread 03-04-2008, 20:40
Gdeaver Gdeaver is offline
FRC #1640
Team 104 had battery problems at the NJ regional. The 2 2008 and 1 2007 batteries failed on Thurs. They would charge but would be down half way through a match. Any battery that was charged on the 2008 charger failed. We made it through the regional on a 2006, 2007 battery and the 2006 and 2007 chargers. We are sure the common mode of failure was the 2008 charger.
Unread 03-04-2008, 20:53
RyanN's Avatar
RyanN
We didn't realize that it leaked until we pulled it off the robot and I tried to figure out why it wasn't working. I knew the plastic plate on the top was loose, but I did not know the black rubber plug had come lose. I'm not sure if it leaked or it evaporated while charging. We disposed of the battery properly, and it is now in the battery graveyard.
Controls Mentor
@rnazaretian
Previous teams:
Unread 03-04-2008, 21:04
metR metR is offline
AKA: Ben
FRC #2589 (The CodeBandits)
metR is an unknown quantity at this point
At the boston regional we had some trouble with our charger. We would plug in one of the batts to charge, and come back later and the red "Check" light would be on. Unplugging the battery from the charger and charger from the wall solved the problem, but it did this at least twice. This caused trouble when we thought the batteries were charging, but were just sitting instead. We have the 2008 KOP charger and batteries.
The only thing better then having common sense is knowing when not to use it.
Unread 03-04-2008, 21:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We had 2 of our 2007's fail. We did not use the 2008 charger, our batter cart has 6 of the old style chargers on it.
BTW 2006 batteries were illegal for competition this year.
Unread 03-04-2008, 21:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
THe new chargers are a bit tricky, you have to make sure the voltage is set correctly, and current is set correctly after you connect the battery.
Unread 03-04-2008, 21:50
Chris Fortmeyer's Avatar
Chris Fortmeyer Chris Fortmeyer is offline
FRC #0358 (Team 358)
Chris Fortmeyer is an unknown quantity at this point
Originally Posted by fatjoe3833 View Post
Mark, was the second battery from spare parts okay? Maybe there was a problem with the chargers at SBPLI. I saw the spare parts people charging the extra batteries troughout Saturday. Maybe the batteries were abused or mishandled at another regional.
-Joe (Elimnation Match Spare Battery Guy)
Joe,
I am actually the member of the drive team that noticed the bad battery from Spare Parts. The robot was continually resetting and not staying on long enough to even get a voltage reading on it. The second battery from Spare Parts seemed to work fine, even though it was not fully charged at the beginning of the match.
Unread 03-04-2008, 22:17
FRC #1640
We were not the only team having battery problems. Yes we were aware of the need to set the battery charger. I can't prove the 2008 charger was the problem. All I can say is that the batteries that were cycled on the 2008 charger failed. The ones which were not worked fine. As to the 2006 battery legality. We used what we had. We were not the only ones.
Unread 03-04-2008, 22:24
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Originally Posted by squirrel View Post
Just to keep things interesting, I'll mention that we discovered that the Andersen connectors this year are made differently from past years, and that we could get the power to the robot to go on and off by merely wiggling the Andersen connector with the new batteries, but it would stay working with the old batteries (which have the old connectors).
What was different about the connector ? Were the pins inserted into the shell correctly ? I'd like to see this thing ? Going to Atlanta ?
Ed Barker
Battery Terminal problems Zack Briggs Electrical 11 05-03-2008 12:14
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Battery to RC problems hedgehogger Control System 1 28-01-2005 16:26
Battery To RC PROBLEMS hedgehogger Control System 1 26-01-2005 18:43
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
