Go to Post Now I have yet another webpage that I will feel the need to constantly check - rachelholladay [more]
Unread 04-04-2008, 10:08
PookAir PookAir is offline
AKA: Chuck Shnitzel
FRC #1577 (Steampunk)
PookAir is an unknown quantity at this point
Amplify Remote control IR signal
Is there any way to amplify the IR signal that we get from our remote.?
We use a standard remote control
thanks alot Team #1577 SteamPunk Meet you all in atlanta
Unread 04-04-2008, 10:15
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Amplify Remote control IR signal
what we did was add like 5 more IR LED's to our remote and add IR recievers around our robot. so we have more range and 360 degrees of range. i didnt do this my self so i cant really tell you more details about it. but im sure another person can chime in and tell you how to do this.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 04-04-2008, 10:20
AKA: Chuck Shnitzel
Do you meen you have more than 1 IR board or you connected more recievers to that board? thank's alot
Unread 04-04-2008, 10:27
seanl's Avatar
you could have 2 recievers OR you you hard wire in more if those black things on the IR boards that recieve the lights. thats what we did.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 04-04-2008, 11:44
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
How did using the IR board work for you at your regionals? We planned on using it but never got the code and everything worked out. Did you have problems with interferience? or just not recieving the signal?
We are wanting to use it more in Atlanta, but dont really have time to rewire the thing or get another one so we have more coverage. So any suggestions on a simple way to increase the recievability of it? Or should just one IR board be fine if we aim the remote right at the thing?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 04-04-2008, 12:13
We use our IR receiver to tell the robot which position our alliance color's trackball is occupying on the overpass. It only needs to get a signal at the very start of the match, so we aren't worried about range.
But we discovered that the remote controls we are using have a relatively narrow beam width. If you're too close to the receiver, correct aim is incredibly important. We also discovered that the IR beam from the remote isn't necessarily pointing straight forward. One of our two remotes is skewed enough to the left to affect the aim significantly.
We determined this by using a camera phone to watch the IR LED on the front of the remote while waving the remote around. You can easily tell where the beam intensity is greatest.
Unread 04-04-2008, 13:15
We use regular TV remote, a couple of transistors, and a 12 volt battery to drive a big array of IR LED's.
We cut out the LED on the remote and used that signal to source the step up.
Unread 04-04-2008, 13:22
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
You guys should post a picture. It's a total beast.
Unread 04-04-2008, 13:24
Ok. I'll take a photo of the practice rig this weekend.
Unread 04-04-2008, 14:04
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
Our students built a 60 LED array with a magnifier all jammed into a 5-inch PVC pipe so that it looks like a bazooka. Sorry I don't have a picture handy but you can look for it at Nationals! They mounted the remote on top so it could be triggered like a bazooka too. BTW, it worked like a charm when we used it. We had to turn it off a few times because it was jamming our alliance partners too????
2003 - Pacific Northwest Regional-Seattle :Quarterfinalist
2004 - Pacific Northwest Regional -Oregon
2007 - Silicon Valley Regional
2007 - Atlanta:Galileo Field (5-2)
2008 - SVR finalist*, Engineering Inspiration Award
2008 - Hawaii semi-finalist, Team Spirit Award
2008 - Atlanta:Archimedes (3-3-1)
2010 - Hawaii regional quarterfinalist
2011 - Hawaii regional finalist, Engineering Inspiration, Innovation in control
2011- St. Louis Galileo Field (7-3) 14th seed, quarterfinalist
2012 - Hawaii Regional Semi-finalist, creativity, industrial design awards
Unread 04-04-2008, 15:55
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I've seen a couple of setups like this before, and I've noticed that sometimes they can cause interference and other adverse effects. Do you know what circuit your team used?
-Dustin Benedict
Unread 04-04-2008, 17:31
DonRotolo's Avatar
Back to humble
FRC #0832
I am also interested in the circuits that teams have used to pick off the IR drive signal and send it to several IR LEDs.
I have an idea to use an Op Amp, but surely there's a simpler circuit out there?
Thanks,
Don
Unread 04-04-2008, 17:47
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thanks,
Don
I believe it is called a MOSFET.
Seriously, take a look at the beacons from the 2004 KOP. Also, look at Kevin's 2004 page. Everything you need to know is there, including this schematic.
Unread 04-04-2008, 18:03
Curt_Bagne's Avatar
Curt_Bagne Curt_Bagne is offline
FRC #0573 (Mech Warriors)
Team Role: Electrical
Curt_Bagne is an unknown quantity at this point
Send a message via AIM to Curt_Bagne
My team was thinking about doing this exact same thing since when we make a left turn, the ir board no longer faces the robocoach and we loose communication. Is it as simple as soldering on more of those black receivers in parallel? Or did you have to design a circuit to amplify or isolate the sensors to prevent the signal that is supposed to go into the ir board from bleeding out of the additional sensors?
We would like to order parts and do this once we get to Atlanta so any pictures or details would be appreciated.
Thanks
Curt Bagne, driver and electronics leader
Team 573
2007 GLR Champions
2008 Pittsburgh semifinalists
2008 GLR quarterfinalists
Unread 04-04-2008, 19:24
mrbob1000's Avatar
mrbob1000 mrbob1000 is offline
I feel smarter already!
AKA: Stephen Johnston
FRC #2377 (CCompany)
mrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to behold
Send a message via AIM to mrbob1000
do like ti tv be gone kit and have 2 wide angle high power ir led's and 2 narrow angle high power led's
also, you can reduce interference by placing a roof over your ir sensor(s) this decreases interference.
New Infrared Remote Control Software Kevin Watson Programming 26 22-05-2008 16:02
Help me raise amplify some speakers mechanicalbrain Electrical 4 27-10-2005 21:46
Remote Control Rover Help Dominator_Legen Math and Science 7 12-02-2005 03:35
Remote Control Car SUCCESS!! arpus maximus Control System 77 10-12-2004 20:30
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
