Go to Post Car Nack called. He said get off his lawn. - Taylor [more]
Unread 05-04-2008, 14:10
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
[FTC]: Technical Question
Are we allowed to use VEXplorer MECHANICAL parts for FTC?
Thanks
Unread 05-04-2008, 15:14
Overyourhead's Avatar
Overyourhead Overyourhead is offline
Josh
AKA: Josh
FTC #0154 (Renegade)
Overyourhead is a jewel in the roughOveryourhead is a jewel in the roughOveryourhead is a jewel in the rough
Send a message via AIM to Overyourhead
Re: [FTC]: Technical Question
You are allowed to use the metal, just not the motors.
Unread 05-04-2008, 15:43
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Yes, but please don't use the vexplorer arm for our claw =.=
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 05-04-2008, 16:18
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
who said anything about the vexplorer claw
Unread 05-04-2008, 22:43
Josh
AKA: Josh
As good of an Idea as it is to use the claw (trust me I wanted to use it on our robot) I think using a rebuilt claw is "cheating". I know it's not against the rules but it's a cheap way out. If you want to use a claw. BUILD IT. We chose not to use it because we felt it isn't fair.
Unread 06-04-2008, 00:45
Billfred's Avatar
Billfred Billfred is offline
Sometimes, however, the cheap way out is the best way out. From the FRC side, we could've spent the better part of our six weeks and a few hundred bucks finding means of machining two-speed gearboxes and doing so, but it worked better for us to shell out a bit more for the AndyMark Super Shifter, an off-the-shelf gearbox. It met our needs better, so the fine folks in Kokomo got our business.
Unread 06-04-2008, 02:06
It's certainly your prerogative to use whichever parts you want, but I'm with Billfred, if it's functional, priced right, and legal, I'll do that. We bought a Vex claw, but didn't use it because it didn't work that well. If it had, it would still be on the robot. Another good comparison would be omni wheels. How would you justify using factory omni wheels?
Not a knock on your opinion, but I would have been happier if you had just said something like, "we built our own claw because we thought it would be more fun (or it would work better)." You seem to imply that a team using the Vex claw would be cheating, and I strongly disagree with that.
Unread 06-04-2008, 16:34
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
Hmm, honestly I disagree with this. Engineering isn't about reinventing the wheel. It's about doing things effectively, efficiently, and with the best design to meet the needs.
My feeling is that if it meets the needs and it is cost effective then use it. Spend the time you would have done making another part of the robot better, developing better code to control the arm, or working on more sophisticated strategies.
Most highly complex systems are currently build from a majority of of off the shelf parts with a minimal amount of custom parts and software to tie it together.
Using it and figuring out to best use it are two different skills.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 06-04-2008, 16:51
Happy Birthday! Akash Rastogi Akash Rastogi is offline
You really think that? If so, then why are there huge arguments about Gracious Professionalism and about mentor/engineer built robots? If its made ina factory should you be allowed to use it? Would you use a prebuilt arm for FRC if you were allowed to? And if yes (unless you can't afford to build your own) then I think that that's really just sad.
Also, what if a team can't buy the VEXplorer kit due to a small budget such as most FVC teams? Frankly, I don't see why using it should be allowed. I'm with fredliu on this one.
Unread 06-04-2008, 17:17
A set of small omnis is $20 -- the same as the claw. Let's ban those. Let's also ban the large omnis($25), the shaft encoders ($20), extra servos and motors ($20 each), aluminum parts ($100), rack and pinion gears ($30), tank treads ($30), the tank tread upgrade kit ($25), extra wheels ($30), chains and sprockets ($30), the larger chassis kits ($21 to $34) and the ultrasonic range finder ($30). Allowing the use of these extra parts is not fair to the teams that cannot afford them, either -- and they cost the same as or more than the claw. I don't know why you are picking and choosing what should and should not be legal?
Unread 06-04-2008, 17:18
Billfred's Avatar
Good question, one probably for another thread.
Depends--would it meet our needs better than the alternative of building our own?
To each their own.
Rick beat me to it.
Unread 06-04-2008, 17:28
fredliu168's Avatar
uhh sorry guys for the misunderstanding. I'm mentoring VEN's team. The reason I said not to use the claw was because I didn't think it would work well given the design of our robot.
In 2006
In 2007
Events:
Unread 06-04-2008, 17:41
yea but its pre-made. That's really the only thing that bugs me. We didn't use it because we thought it would make other teams mad or something, so its not that I didn't consider it either. But yea, i see your point and I'm sorry for sounding a bit rash on that. its not like i'm going around sayng "no" to people who used it and giving them negative rep. or anything. Just saying that it seems kind of unethical.
But in this case..yea "to each his own."
Unread 06-04-2008, 19:56
Josh
AKA: Josh
I 100% agree. I understand that it is not illegal to use it. I just feel that it's a cop out because of the fact that it's so much pre-made. If you are going to use a claw, which I feel is a good idea, build one. Dean Kamen always likes to see innovation. I claw well built will be more innovative rather than just sticking a pre-built think on a fully unique robot.
Unread 06-04-2008, 20:02
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
I love the claw not for being a claw (I would never use it as a claw) but for what you can get out of it. Anyone that went to the New York FTC regional and watched our robot could see some vexplorer claw in use in the beginning of every match.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: Non-technical topics during interview ManicMechanic FIRST Tech Challenge 0 28-12-2007 00:53
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
