Go to Post Come on guys, its not like it's rocket surgery or anything. - hallk [more]
Unread 05-04-2008, 21:05
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Drivetrain Issue
Hey all, we are competing at NYC regionals and our drivetrain is acting a little funny
when we try to drive straight, our robot swerves to the left
after the matches, our left motors are BURNING hot and our right motors are cold
any suggestions to what's wrong?
btw, we dont think the motors are fighting each other...at least on the left side
Unread 05-04-2008, 21:08
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: Drivetrain Issue
Check your PWM's to the right side motors
Check polarity of the left side motors/right side
check for mechanical problems in the gearbox
Basically, do an entire "overhaul" on the gearboxes and see what is wrong, more then likely the polarity is reversed, or there is a big burr or something on a gear clogging the system up.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 05-04-2008, 21:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We had a similar problem on Sat. @ MN. The first thing I would do is put the robot up on blocks (so it can't drive) then fire it up and push your sticks all the way forward so the Victors should be getting a full signal. Look at the LEDs on the Victors with the sticks still forward. They should all be green. If they aren't you have a problem with your code or PWMs. If they are all green then it is a mechanical problem or electrical problem with wiring other than the PWMs.
To check motor polarity you can unplug the PWMs from your Victors and plug in one at a time and run them full forward and see which way the wheels spin.
Unread 05-04-2008, 23:13
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
It sounds to me like you may have an increased load on the left side of the drivetrain. I suspect one of the gearboxes is binding up.
Try to spin the right-side drive wheels by hand.
Now spin the left-side drive wheels by hand.
Is it significantly harder to spin the left wheels than the right? If so, try to find out why.
That is my best guess.
Good Luck!
John
Unread 06-04-2008, 00:46
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
The aforementioned insights provided are probably your most likely bets, but also check to make sure that your burning hot motors have intact o-rings around the ends of their casings (places where the black painted portion of the CIM meets it's two cast endcaps).
Missing or damaged o-rings can allow fine particlates into the interior of your motor and degrate or destroy the brushes in your motor. From there, it's possible that you rmotor could be partially or completely shorted out.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-04-2008, 00:56
Cal Cal is offline
Unregistered User
FRC #2456 (Recycle-It)
Team Role: Electrical
Cal is an unknown quantity at this point
Send a message via AIM to Cal
Also, have your programmers check your code, a typo could be the cause of all of that.
Unread 06-04-2008, 01:44
Valley Raider Valley Raider is offline
FRC #0955
Valley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really nice
what kind of transmissions are you using. We had custom one and on one side the output shaft got bent and it added a lot of binding problems. If you using the kit of parts ones then check the pwms we had lot of problems with that.
Unread 06-04-2008, 18:14
Jack Murphy Jack Murphy is offline
Jack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really nice
[quote=JVN;731180]It sounds to me like you may have an increased load on the left side of the drivetrain. I suspect one of the gearboxes is binding up.
Good Luck!
John
Welcome BACK, My Friend.
Unread 06-04-2008, 18:34
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
what kind of gearbox are you using? Check the motor polarities as well as for burrs in the gearbox on the left side.
-Vivek
"we don't build robots, we build people"
Unread 07-04-2008, 00:36
Jared Russell's Avatar
Taking a year (mostly) off
If it turns to the left, then the right side is going faster.
If the right side is going faster even though both sides are told to go the same speed, then the left side has more resistance.
If the left side has more resistance, then:
1. Check any chains for alignment and tension (not TOO much tension!)
2. Make sure there is grease in the gearboxes.
3. Listen to each side independently. If they sound different, there is a mechanical problem most likely in the gearbox (alignment or debris).
4. Make sure all electrical and mechanical connections are TIGHT!
5. Sanity check yourself by removing the motors and seeing if they seem to match in speed when not loaded.
Unread 07-04-2008, 01:01
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
1726 experienced a similar problem during our early build season testing. A victor had burnt out forcing the remaining motor on that side not only to move the robot, but also to back drive the other motor. We discovered this when a student noticed that one motor was much hotter than the other. If both your motors are the same temperature then this is probably not the problem, but it's probably still worth checking.
decoder issue TEAM1949 Programming 10 07-03-2006 14:34
html issue musicgal Website Design/Showcase 12 02-02-2006 22:32
validation issue VenTurA Website Design/Showcase 5 29-01-2006 17:29
Software Issue patTeam241 Programming 0 28-01-2005 17:12
Important Issue! archiver 2000 7 23-06-2002 22:37
