Go to Post It'd be nice to have some more data to look at, I like data - Aren_Hill [more]
Unread 06-04-2008, 01:11
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
pic: Problem with IFI Wheels
Unread 06-04-2008, 01:14
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: pic: Problem with IFI Wheels
This happened to one of our drive wheels as well.
Seems like 5052 is not durable enough to take the load.
If IFI uses 6061 the wheel would work much better.
-Borna Emami
Team 0x27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How were the 3 screws around the bearing installed? Did you have the plastic washers between the screw heads, and the side plate?
Unread 06-04-2008, 01:20
BornaE's Avatar
We did
-Borna Emami
Team 0x27
Unread 06-04-2008, 01:30
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by richardmcc2 View Post
did you press a bearing into the sprocket itself?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 06-04-2008, 03:58
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Since IFI produces a lot of their their aluminum products using CNC sheet metal fabrication machinery, it would not make sense to use 6061.
5052 (along with many of the 5xxx grades of aluminum) are much better suited for CNC turret/punch and bending machines than 6061, which is less malleable and more prone to cracking during cold rolling operations.
You can't do much cold bending of 6061 and hope to achieve a bend radius equal to the thickness of the material, which is possible with several different 5xxx grade aluminum up to about 0.125" thick.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-04-2008, 10:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Was the sprocket itself supported by a bearing or the axle? We're using 6" IFI wheels and the flat AM aluminum sprockets. The sprockets have a bearing pressed into them and are bolted into the pattern on the IFI wheel (who woulda known they use the SAME bolt pattern?!). We also are using 1/8" plastic spacers between the wheel and sprocket on each of the 6 bolts. We've had some tug of wars and a bit of side bumping in matches but have yet to see a problem.
GitHub
Unread 06-04-2008, 10:49
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Many, many thousands of IFI wheels have been sold. I have not heard of many complaints.
We've run probably 20 of the wheels without any problems at all. Many of them are multiple-season use.
I'm curious - were you using chain? If so, what gauge? Was the chain aligned properly from front to back - i.e. was it perfectly perpendicular to the shaft the wheel was running on, or was it pulling at an angle? How tight did you have it?
Unread 06-04-2008, 11:08
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
We had the same problems in 2006 when we used them... After Florida that year we made nylon bearings that fit inside the wheel and spanned the entire width of the wheel. These worked well and we didnt have any more problems with the bearings buring the next 2 competitions.
We don't use these wheels any more. For something like $60 each I would expect something far stronger, especially since it was designed for FRC teams.
Also, we found that the IFI sprockets were too thin for #35 chain which allowed for slop made it easier for the chain to pop off.
I have seen a number of teams that use these wheels and never have a problem, but i have also seen an equal number that have had problems with them.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 06-04-2008, 11:17
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
We've been using them for 2 years now and we have never had any problems with them. We have a practice robot that gets driven to death and we have one yet to fail. I personally like these wheels and I would use them again, IFI has a good product.
-Josh Murphy-
Unread 06-04-2008, 12:31
Engineering Mentor
Yes.
No, but this sounds like a very good idea, never thought about that. Maybe we will try this next year.
We were using #25 chain and it was aligned from front to back fairly well, and was pulling perpendicular to the shaft until the wheel started to deform. Once the wheel was wobbling though, the chain just popped right off. It did have a fairly good amount of tension in it as well.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Last edited by Richard McClellan : 06-04-2008 at 12:32. Reason: added last sentence
Unread 06-04-2008, 13:58
Aren_Hill's Avatar
Build Nifty Things
Yes.
so wait...how many bearings did you have between the wheel and the axle? because with 2 bearings supporting it i don't think this situation has a likelihood of occurring.
A guy who likes robots.
Unread 06-04-2008, 16:00
Engineering Mentor
We had two bearings - one on each side of the wheel itself, and yes, it did still happen. I think if we had had a 3rd bearing (like suggested above) on the sprocket itself, it could have solved our problem.
Unread 06-04-2008, 16:10
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
It is a great idea, IT WILL KEEP THIS PROBLEM FROM EVER HAPPENING!!!
PLEASE TEAMS, PRESS A BEARING INTO THE SPROCKET!! (sorry for the caps I have to tell at least one team a year this, three this year)
I'm not suggesting that this might fix your problem, this WILL ELIMINATE THIS ISSUE (THIS IS NOT JUST FOR IFI WHEELS EITHER) skyways, AndyMark, colson....if you are bolting a plate sprocket to the wheel with some kind of spacer in between those two elements you should spend the dollar or whatever for the extra bearing for the sprocket. You might get lucky and nothing ever happens to your wheels, but just be cautious and throw that bearing in there, it is much cheaper than a new wheel.
Unread 06-04-2008, 16:41
mark johnson's Avatar
mark johnson mark johnson is offline
FRC #3175 (knight vision)
mark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud of
You must doing something wrong because we have been using them for the past two years and there industructable. Last year we competed in six competitions between first and off season events . also before the off season events we loged many hours of pratice time for the new drivers and not one failure.
K.I.S.S.
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
pic: What do you do when you don't have enough money to buy 6 IFI wheels? Arefin Bari Extra Discussion 1 14-02-2006 01:14
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
pic: Team 229's Anodized IFI Wheels Adrienne E. Extra Discussion 11 23-01-2006 17:55
problem loading code with ifi loader psych0gambit Programming 7 25-02-2005 20:43
