Go to Post I don't understand why it should matter if your robot is 100% student built, 100% engineer built or somewhere in between. As long as you are Inspired (I word again) FIRST is getting its point and primary goal across. - [more]
Unread 04-04-2008, 11:38
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
Cylinder Question
I need to know if putting the cylinders on the side the air passes out of the pressure valve will increase the speed of the pneumatics? currently they are all on the side of the compressor, like this
Compressor > 4cylinder > pressure valve > Pneumatics
if we switch it to this
Compressor > pressure valve > 4cylinder > Pneumatics
is it faster? does it make any diff?
2008 San Diego rookie all-star!
2008 Championship rookie inspiration!!
Thank you to everyone
Unread 04-04-2008, 11:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Cylinder Question
Having more working air on the low side can help improve your speed but you loose the storage capacity on the hi-pressure side.
I have seen some successful teams put a storage tank near their cylinder for the first time this year to increase speed but I certainly wouldn't put all my storage on the low-pressure side.
Unread 04-04-2008, 11:54
Rookie Team
so two on each side would be good?
Unread 04-04-2008, 12:14
Racer26 Racer26 is offline
It shouldn't really change alot, but if you're looking to maximize the speed of stroking, another team mentioned how they have a mechanical lock on the motion of their arm, they energize the piston, that has a clippard tank inline, thereby building lots of pressure to push with, and then they remove the mechanical lock, and it strokes quickly.
Unread 04-04-2008, 12:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
See if you can find the bottleneck in the system...it could be the solenoid valve. 39 used (I think) one tank before the regulator, 3 tanks after, and three solenoid valves feeding one cylinder. It works VERY well.
Unread 04-04-2008, 14:10
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
if you have multiple cyinders and the tank set up in the way you 1st explained you'll probably have dampened air flow because thats a lot of air going through one port. team 1086 has our pneumatic launcher (4 pistons) set up the 2nd way you explained. it gives us better air flow and we still get enough pressure to launch. if your usind 1 cylinder i dont think it'll matter.
Unread 04-04-2008, 21:54
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
another option to incease the speed is to not use pressurized air for the return action - just use a bungee or other light spring.
with out the restriction on the "exhaust" side of the cylinder flowing thru the fitting and solenoid, the actuation is extremely fast.
Note: this only works if you do not have a need to pressure-close the cylinder back to the original position.
Note: depending on which solenoid you use, you may have to make a tubing "loop" to close off the exhast port on the solenid to avoid leakage.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-04-2008, 11:38
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
will result in MUCH faster cylinder deployment. The regulator is a big restrictor to airflow.
We store our air in 4 Clippard tanks connected directly to 2 SMC valves, that are in turn connected directly to our piston. We designed it such that there is no tubing between the storage tanks and the cylinder, only high pressure fittings. The air flow we get with this arrangement is many times what we achieved by storing air at high pressure then feeding it through the regulator.
The downside is that we have no high pressure storage, only low pressure. This lengthens our shot-to-shot time. We added a pressure sensor so our shooter knows when there is enough air for a hurdle. (We have a second method of hurdling, so this doesn't slow us down much.)
Here is a shot of the height we get with this arrangement:
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Question about pneumatic cylinder connection itsme Rules/Strategy 10 16-02-2008 17:35
80 Inch Cylinder Question pakratt1991 Rules/Strategy 3 12-02-2008 13:35
Cylinder Weight Kmo Pneumatics 6 13-01-2008 13:02
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Cylinder weights Captain Rich Pneumatics 3 30-03-2005 16:08
