Re: pic: Problem with IFI Wheels
No, but this sounds like a very good idea, never thought about that. Maybe we will try this next year. Quote:
Last edited by Richard McClellan : 06-04-2008 at 12:32. Reason: added last sentence |
We had two bearings - one on each side of the wheel itself, and yes, it did still happen. I think if we had had a 3rd bearing (like suggested above) on the sprocket itself, it could have solved our problem.
further more, if you at look both the sprockets available from ifi and am.biz, you'll notice that they both are made to accept a 3/8 in bore flanged bearing. |
I noticed some similar wear on one of our IFI wheels from last year (the 6"x1" version), but it wasn't worn that badly. Also, the wear seemed more like it came from the bearing turning against the wheel rather than being wollered out due to a deformed wheel plate.
...My theory is that the bearing wasn't tightened down enuogh when our wheels were put together. The supporting evidence: when I was playing with one of the wheels that was laying around the shop, I noticed that one of the bearings was actually able to turn against the wheel! The screws seemed tight enough, but it was still able to turn. It's my guess that the little white standoffs that go between the plate and the screws were too thick and didn't allow the screws to clamp down tightly on the bearing. I didn't think much of it at the time, but it's my guess that this is what happened to your wheels (though I may be wrong...). We've never had any deformation of any kind on our plates, and we were using the 6"x1" wheels last year (we were being pushed sideways for a good part of our matches, too). |
having the sprocket bolted to the wheel with both bearings in the wheel does create a high stress cantilever that i can see being enough to round out that whole, especially if there were any nonconcentric sprockets in the drive to pulse the chain from tight to really tight. putting a bearing in the sprocket should stop it because if relieves the cantilever |
#7
PLEASE TEAMS, PRESS A BEARING INTO THE SPROCKET!! (sorry for the caps I have to tell at least one team a year this, three this year) I'm not suggesting that this might fix your problem, this WILL ELIMINATE THIS ISSUE (THIS IS NOT JUST FOR IFI WHEELS EITHER) skyways, AndyMark, colson....if you are bolting a plate sprocket to the wheel with some kind of spacer in between those two elements you should spend the dollar or whatever for the extra bearing for the sprocket. You might get lucky and nothing ever happens to your wheels, but just be cautious and throw that bearing in there, it is much cheaper than a new wheel. |
#8
You must doing something wrong because we have been using them for the past two years and there industructable. Last year we competed in six competitions between first and off season events . also before the off season events we loged many hours of pratice time for the new drivers and not one failure.
#9
Well, he forgot to mention that the wheels were rotating at about 1000 rpm. To do this with #25 chain means that you could play a tune with all the tension we have on the chain. We put bearings in the sprockets and haven't had any problems since.
| Problem with easy c pro and mechanum wheels | pbrules15 | Programming | 9 | 03-02-2007 20:38 |
| pic: What do you do when you don't have enough money to buy 6 IFI wheels? | Arefin Bari | Extra Discussion | 1 | 14-02-2006 01:14 |
| TO much traction??? (ifi wheels or AM wheels) | Heretic121 | Technical Discussion | 9 | 04-02-2006 12:09 |
| pic: Team 229's Anodized IFI Wheels | Adrienne E. | Extra Discussion | 11 | 23-01-2006 17:55 |
| problem loading code with ifi loader | psych0gambit | Programming | 7 | 25-02-2005 20:43 |
