Re: [FTC]: Technical Question
You really think that? If so, then why are there huge arguments about Gracious Professionalism and about mentor/engineer built robots? If its made ina factory should you be allowed to use it? Would you use a prebuilt arm for FRC if you were allowed to? And if yes (unless you can't afford to build your own) then I think that that's really just sad. Also, what if a team can't buy the VEXplorer kit due to a small budget such as most FVC teams? Frankly, I don't see why using it should be allowed. I'm with fredliu on this one. Last edited by Akash Rastogi : 06-04-2008 at 16:56. |
A set of small omnis is $20 -- the same as the claw. Let's ban those. Let's also ban the large omnis($25), the shaft encoders ($20), extra servos and motors ($20 each), aluminum parts ($100), rack and pinion gears ($30), tank treads ($30), the tank tread upgrade kit ($25), extra wheels ($30), chains and sprockets ($30), the larger chassis kits ($21 to $34) and the ultrasonic range finder ($30). Allowing the use of these extra parts is not fair to the teams that cannot afford them, either -- and they cost the same as or more than the claw. I don't know why you are picking and choosing what should and should not be legal?
uhh sorry guys for the misunderstanding. I'm mentoring VEN's team. The reason I said not to use the claw was because I didn't think it would work well given the design of our robot.
yea but its pre-made. That's really the only thing that bugs me. We didn't use it because we thought it would make other teams mad or something, so its not that I didn't consider it either. But yea, i see your point and I'm sorry for sounding a bit rash on that. its not like i'm going around sayng "no" to people who used it and giving them negative rep. or anything. Just saying that it seems kind of unethical.
But in this case..yea "to each his own." |
I love the claw not for being a claw (I would never use it as a claw) but for what you can get out of it. Anyone that went to the New York FTC regional and watched our robot could see some vexplorer claw in use in the beginning of every match.
#8
To each his own... 575 abandoned the claw idea just because it didn't work very well for their design.
#9
My team used a claw in our robot, but we built it ourselves. It worked pretty well, we used some rubber for gripping. I actually never heard about the VexPlorer arm/claw until a couple of months ago. I learned yesterday at NYC/discovering team 546 on youtube that for what we wanted to do, it was more effective to design a ring stacking system, but in the midst of the competition, we learned that our robot was very good at controlling the hexes, which helped us greatly in the matches, especially when we realized who our best driver was.
From what I have seen, the vexplorer claw looks too big to take control of the hexes and not effective in grabbing pvc rings. But yea, to each his own. It probably just hurts the team on the innovate award. Last edited by thatguy : 06-04-2008 at 21:32. |
#10
My point was that all things being legal, if you were develop a design that requires a certain function (I'm dropping the arm so we don't get bogged down in that), and you have a choice between a commercial product that fits your needs and budget or making something yourself that is of equivalent ability, most engineers will go with off the shelf and put effort into other areas where custom parts are required. This argument goes out the window though if you intend to or can develop something that performs better. Or if for some reason you can make it cheaper. Engineering is a balance between best performance, best cost, and best use of time. |
#11
I saw a couple teams using the VEXplorer claw at the San Diego and Vegas regionals. A LOT of the teams using it were inexperienced rookie teams who didn't have the knowledge, resources, or time to build anything better. It allowed them to function okay, but most of the teams who built custom claws did a better job of grabbing rings. Personally, I think the VEXplorer claw is a great resource for beginning teams, but any other team would be better off building their own.
#12
I don't have a problem one way or another, but I do admire teams that take the time to build their own claw. Take Vexellent - their claw looks excellent, much more suited to Quad Quandry than the Vexplorer claw, I think. (http://www.vexforum.com/gallery/show...1196&catid=12)
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| [FTC]: Non-technical topics during interview | ManicMechanic | FIRST Tech Challenge | 0 | 28-12-2007 00:53 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
| Technical question about ramp balancing | archiver | 2001 | 5 | 23-06-2002 22:29 |
