Go to Post Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... - Rich Kressly [more]
  #91   Spotlight this post!
Unread 06-04-2008, 14:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Defensive Strategy - cornering opponents ball
Originally Posted by Shadow503 View Post
I guess this is where our opinions split. I believe a team with a half-done robot should not be able to effectively compete.
Teams like us have spent too many hours building a powerful bot to have our scoring potential neutralized by a half-done box bot ("defensive bot"). The game creators intended to reduce pinning. This can be found by the lack of any 90 degree corners in the track. Unfortunately, teams are still able to pin a ball.
If your "powerful bot" can be neutralized by a "half-done box bot" then I put forth that your bot isn't all that powerful.
More likely, the fact is your team did not take into account defensive strategies ... so now you are crying foul.
I've done the math and I have a counter pinning strategy: high speed ramming. If I can get our 120lb bot moving at 20 ft/s we should be able to disable/dislodge the defensive bot/track ball. A single lap w/ hurdle will be sufficient to cover 10pt penalty. After this, one of four things happens:
A) The defensive robot has been damaged and is no longer able to play defense
B) The defensive robot is still working, but we are able to keep control of the ball
C) The defensive robot, while still working, has realized it is in their best interests to not pin the ball
D) The defensive robot, still working, pins the ball after we come around the track again. We repeat the ramming maneuver and hurdle (with no net point loss) and hope for conditions A),B), or C) next time around.
1> High speed ramming is against the rules
2> Strategies designed to damage other bots or the field will get you DQ'd
3> Most defensive bots I've encountered are built stronger than their offensive counterparts because they 'expect' contact.
Have fun with your strategy. I'll be there to assist the other guy putting his robot back together while your team goes home after being DQ'd
Most defense bots are weak KOP bots, so I have a feeling condition is A) is the likely outcome.
Please show me your evidence that defensive bots are weak KoP bots.
Yes, it might not be the most GP solution, but neither is pinning. Pinning was not in the intent of the game creators and promotes laziness in bot design and construction. Pinning will lead to boring, low scoring matches. I intend to change that. I encourage other teams with competitive robots to do the same to keep this years game interesting.
See you at Nationals!
Please show me your evidence that pinning was not the intent of the game creators. My guess is that they knew some teams would try this strategy and a few would actually get good at it.
If you try to destroy others robots and encourage others to do the same ... don't be surprised when it happens to you.
Have fun at the nationals
___________________
- Tennyson, Ulysses
  #92   Spotlight this post!
Unread 06-04-2008, 15:02
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
I'm hearing yet another echo.
I think the concensus is that if you can be stopped by a defensive bot then it is your problem to deal with, not complain about. ( or at least not ours.)
  #93   Spotlight this post!
Unread 06-04-2008, 15:39
Shadow503's Avatar
Shadow503 Shadow503 is offline
printf("\r\n Moo!");
Team Role: Human Player
Rookie Year: 1991
Shadow503 will become famous soon enoughShadow503 will become famous soon enough
I'm curious how you suggest teams take into account for defensive strategies. If a ball is pinned against a wall, what can a team do besides ignore it and do laps? My point is that any offensive bot can be neutralized by this technique.
If a ball is pinned against a wall there is nothing even the best bot can do about it. That is the biggest thing that separates pinning from previous defensive strategies. In previous years, a defensive bot had to be robust and have a solid drive train. This year, the rules protect a pinning bot from contact so a cardboard box with wheels could effectively carry out this "strategy".
Yes, and a single hurdle + lap will eliminate that penalty.
If they are built so robustly then they have nothing to worry about. I don't intend to damage the robot. I simply wish to dislodge the ball. If the robot gets damaged, then so be it. A yellow card is just a warning, and it also disappears once the finals start.
Originally Posted by s_forbes
but there are always going to be teams that cannot complete the task and end up with a half-done robot that can't run fast laps or hurdle the ball. I think this was anticipated, and so no rules were made to stop these teams from intercepting/playing keep away with the other alliance's trackballs.
Originally Posted by lukevanoort
I don't think anyone is proposing building your robot with this as its sole purpose. If your [mechanism] breaks and you're up against a couple of good hurdlers, this might be a very useful strategy in your repertoire. You could drive in circles for a couple points a lap, or you could pin the ball and reduce one of your opponents' scoring ability from ten points per lap down to two. That seems like a useful backup strategy to me.
Ok, maybe not KOP bots, but many people are suggesting that defense be used by defective/half-finished bots.
135 degree angles on the walls. A right angle would be much more easily manufactured, but the GDC still chose to use 135 angles (which make it more difficult to pin). If you also look at the other rules, they discourage defensive play this year. I'm pretty sure the GDC doesn't want four bots to park themselves in the corners pinning balls while the other two remaining bots run laps. That leads to very dry gameplay.
I don't encourage the destruction of other robots, I'm simply suggesting a way to prevent a loophole from ruining this years game. And as you've previously stated, defensive bots are built strong, so they should have no problem holding up to our attempts to bring the track ball back in to play.
See you at nationals!
  #94   Spotlight this post!
Unread 06-04-2008, 15:53
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I think you're forgetting the diversity that occurs every year.
  #95   Spotlight this post!
Unread 06-04-2008, 16:01
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Very simple, push them out of the way. There is nothing to prevent bumper to bumper contact. If we had chosen to use our drive train from last year we could have pushed any of the defensive bots out of the way, very easily. We could even have pushed other bots sideways in some cases. Also, you could simply not let them pin in the first place. Part of the game this year, I would almost say the most important part, is ball control. You must be able to pick up quickly and reliably and a team that does this can make it so another team never has the chance to play defense in the first place.
Finally, I direct you to the eliminations at GLR. There you can see a very fine showing of counter-defense between us (910) and the Thunderchickens. Above all else teamwork can prevent defense from shutting you down.
Also the 135 degree walls are likely there to give the track a somewhat oval appearance, to simulate a race track. Not for any specific anti defense reason.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
  #96   Spotlight this post!
Unread 06-04-2008, 16:02
in between teams
AKA: Luke Van Oort
Alex, I'll be honest with you, I think that your argument is baseless. Defense is a valid strategy, and as an offensive robot, you must play through it or lose. Also, if defense-oriented robots were so weak and flimsy, you should have no trouble dealing with them unless your robot is similarly weak or flimsy; all you have to do is push them out of the way. In addition, a strategy that has severely damaging or destroying opposing robots as one of its main goals has no place in this game, and I would hope the refs would DQ any team trying such a foul strategy. A side note, calling other robots "half-finished" or "defective" is just bad manners, and is very rude.
Team 1219: 2009 - Mentor
  #97   Spotlight this post!
Unread 06-04-2008, 16:08
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Who said anything about running laps. Our bot, in low gear, drives @ 5' per second and has 175+ LB pushing force. Very few "half-done box bots" won't be pushed by us. And we don't need to ram.
Design for defense ... because it will happen once you prove yourself a scoring threat.
Planning on high speed ramming will get you DQ'd under <G37>
ROBOT to ROBOT Interaction - Strategies aimed solely at the destruction, damage, tipping over, or entanglement of ROBOTS are not in the spirit of the FIRST Robotics Competition and are not allowed.
This is the most un-GP statement I've ever seen, and shows that you are far more interested in winning than in doing what is right.
135 degree wall sections proves nothing other than it's different from years ago ... not that the GDC did not want or expect pinning of the trackballs. At best it's your estimation of what the GDC wanted. And your opinion is biased because your "powerful bot" was unable to compensate for this "simplistic" defense (in fairness, my opinion is probably just as biased even though we built a lap bot this year).
Also think that your arm / gripper / manipulator very well could be outside the bumperzone and any interaction with that will give you another 10 point penalty and may get you disabled / Yellow carded / DQ'd.
Again, have fun with your strategy at the championships.
___________________
- Tennyson, Ulysses
  #98   Spotlight this post!
Unread 06-04-2008, 16:30
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I gotta say, it seems like we are going in circles with this one. I'm gonna run out ways to reword what I've already said.
  #99   Spotlight this post!
Unread 06-04-2008, 17:12
GaryVoshol's Avatar
Cogito ergo arbitro
Then why didn't they simply outlaw it? Reduce <> prohibit.
So to counteract a strategy that is not prohibited in the rules, you will employ a strategy that deliberately breaks the rules. And you're questioning the other team's GP?
But a second yellow card results in a DQ. And each and every one after that results in a DQ. You won't be racking up many wins in qualifying matches that way. And who would choose a robot in an alliance that might get the whole alliance DQ'd in the eliminations?
And it would be easier to hurdle if the overpass was only 4.5 feet tall, not 6.5. I guess that means the GDC didn't intend us to hurdle, else they wouldn't have made it so difficult.
Some kinds of defense are outlawed. How do you jump to the conclusion that this discourages all defense?
If they had not wanted that, why didn't they say so in the rules? There's been no Team Updates since Week 2. Don't you think they would have changed the rule if that's what they really wanted?
(since 2004)
  #100   Spotlight this post!
Unread 06-04-2008, 17:34
Shadow503's Avatar
printf(&quot;\r\n Moo!&quot;);
Rookie Year: 1991
Originally Posted by lukevanoort View Post
Alex, I'll be honest with you. Your argument reminds me of one you would hear from a spoiled rich kid with a sports car who gets pulled over for speeding.
Geez, has our discussion really regressed to personal attacks? I care little for how you interpret my arguments.
You're sending mixed messages. At first you say that offensive bots should have no problem dealing with defense bots if they are weak. Then immediately after that you condemn damaging opposing robots. I'm not sure I understand exactly what you propose offensive bots do.
I'll clarify my previous statement. The goal of my strategy is to simply dislodge the ball. The last thing I want to do is to destroy another teams robot. Herodotus suggested pushing, and I agree with him. This will allow competitive bots with a good drive train to move the pinning bot. Yes, my suggestion for high speed ramming may have been blunt. Pushing is a more reasonable solution.
I'm only using words that were used by supporters of pinning in the past few pages. Is it really rude if I haven't actually named any robots? Please consider your own personal attacks when you wish to point fingers about being rude.
  #101   Spotlight this post!
Unread 06-04-2008, 17:42
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I really don't like the way this thread is going,
how about we have some hot chocolate and heatedly discuss, rather than argue, about it eh?
Really, words do not peirce hearts, people do. So no, it is only the usage and implications of said usage that render words poisonous.
-Jesus
Edit. Or Lemonade.
  #102   Spotlight this post!
Unread 06-04-2008, 17:55
Shadow503's Avatar
Rookie Year: 1991
Yes, lemonade would probably be a better idea right now!
  #103   Spotlight this post!
Unread 06-04-2008, 18:03
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Lemonaid sounds real good
___________________
- Tennyson, Ulysses
  #104   Spotlight this post!
Unread 06-04-2008, 18:13
in between teams
AKA: Luke Van Oort
Alex, I apologize, I did not mean to attack you, just your argument. On a second reading, I see how easily that difference is missed, and so have modified the line.
Now, lacking lemonade, I'll go play some guitar.
  #105   Spotlight this post!
Unread 06-04-2008, 18:16
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I can only play real guitar so-so, so onward to Rock Band.
Cool defensive strategy.... Salik Syed General Forum 8 06-01-2009 21:41
Can you knock a ball out of a opponents hold... kE7JLM Rules/Strategy 6 20-01-2008 14:25
Ball Collection By Defensive Alliance ewankoff Rules/Strategy 18 11-01-2006 19:21
Defensive Strategy Alex Minot Rules/Strategy 5 09-01-2006 14:12
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
