Go to Post Sorry [the easy button] does not exist in robotics :D - Arkorobotics [more]
Unread 06-04-2008, 23:53
Jared Russell's Avatar
Taking a year (mostly) off
Re: Programming n3wb needs help
You can use an ultrasonic ranging sensor, like the one recommended above, or an infrared proximity sensor (I recommend the Sharp GP line, available from a number of retailers if you google "sharp infrared sensor").
The easiest solution is to put one sensor looking to the left, one sensor looking to the right, and one looking dead ahead. Alternatively, put one sensor looking forward and to the left, and the other forward and to the right (both on 45 degree angles). You could also put a single sensor on a servo and scan back and forth, but this is a bit more complicated.
Now all you have to do is write code to turn right when an obstacle is to the left, turn left when an obstacle is to the right.
If there's an obstacle in front of you, you can turn either way, or reverse (up to you!).
You can make this as simple or as advanced as you want. It could be as easy as what I described, or as hard as making a closed-loop control function to always keep you a certain distance away from the wall.
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
Programming Help TravisE Programming 1 01-02-2005 19:00
Programming Help hedgehogger Programming 10 19-02-2004 12:11
programming help ronnie_82 Programming 2 10-02-2003 13:50
