Re: Material search
It all depends on how it's used... If you describe your project, we may be able to help you out a little better.
Re: Material search
The idea is to coat an R/C aircraft's landing gear with this material.
My Aero team uses a material now (sorry, I don't know what it's called) that has a tendency to tear off the wheels under high-stress situations like landing with 32 lbs aboard an 8 lb plane. It sticks together in a tire shape, but leaves the wheel. After two near-DQs today, we're looking for something better. We know about carbon fiber. The problem is, we'd need a LOT of spares--crash landings can take their toll. |
Re: Material search
Try using PEEK (poly-etheretherketone). It's an extremely crystaline plastic and you should be able to machine it to shape easily. It's used as a bearing material and in many aerospace components.
If you design it properly out of PEEK it will take the load. |
| SEARCH SYSTEM | hiimcristhian | General Forum | 3 | 19-01-2008 20:36 |
| Mentor Search | lam | Finding A Team | 5 | 13-11-2007 21:25 |
| Sponsor Search | Klake | General Forum | 1 | 26-09-2007 18:30 |
| EasyC search | SgtMillhouse648 | Programming | 1 | 05-02-2007 20:33 |
| Pi -Search :D | Arkorobotics | Math and Science | 20 | 19-03-2006 18:25 |
