Go to Post work hard, think hard, and have fun doing it. - ebarker [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 07-04-2008, 01:34
Material search
I'm looking for a material that meets the following criteria:
--can take 87lbs load force (or more)
--no turbulent friction between aluminum and pavement
It should also be light and relatively cheap.
This is for a non-FIRST application. If anyone can point me in the right direction, please do so.
Unread 07-04-2008, 01:43
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Material search
It all depends on how it's used... If you describe your project, we may be able to help you out a little better.
Unread 07-04-2008, 01:44
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Re: Material search
A carbon reinforced composite can hold a lot of force (depending on the size) and is VERY light. There isn't that much friction either. (Well, I'm not positive, but it's about the same as a metal). A perfect example would be a hockey stick. (Look at team 20, for example! )
Hockey sticks also run a variety of prices, depending on the quality, but can be pretty cheap. (Usually aluminum is cheapest, going all the way up to the expensive graphite ones)
If you need any more help, please let me know!
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Unread 07-04-2008, 01:47
Re: Material search
The idea is to coat an R/C aircraft's landing gear with this material.
My Aero team uses a material now (sorry, I don't know what it's called) that has a tendency to tear off the wheels under high-stress situations like landing with 32 lbs aboard an 8 lb plane. It sticks together in a tire shape, but leaves the wheel. After two near-DQs today, we're looking for something better.
We know about carbon fiber. The problem is, we'd need a LOT of spares--crash landings can take their toll.
Unread 07-04-2008, 08:48
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Material search
Try using PEEK (poly-etheretherketone). It's an extremely crystaline plastic and you should be able to machine it to shape easily. It's used as a bearing material and in many aerospace components.
If you design it properly out of PEEK it will take the load.
Thank-you 294 & 67
www.bobcatrobotics.org
SEARCH SYSTEM hiimcristhian General Forum 3 19-01-2008 20:36
Mentor Search lam Finding A Team 5 13-11-2007 21:25
Sponsor Search Klake General Forum 1 26-09-2007 18:30
EasyC search SgtMillhouse648 Programming 1 05-02-2007 20:33
Pi -Search :D Arkorobotics Math and Science 20 19-03-2006 18:25
