Go to Post It seems ironic to me that a robotics competition would come down to human error, which is precisely what the field of robotics attempts to prevent. - David8696 [more]
Unread 06-04-2008, 12:42
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
pic: 1024's Fix-It/Practice
Unread 06-04-2008, 12:48
AKA: Alex
Re: pic: 1024's Fix-It/Practice
Here's a video of our robot running in non-lane-change race mode for autonomous: http://www.youtube.com/v/-q4NTcanElE ...amazing the difference a spiffy new gyro and a few hours to work with the robot can do.
While the robot just crosses 6 lines in autonomous in this video, our competition robot is considerably faster and should be able to make seven lines on a good battery.
Unfortunately, we have no video of the robot lane-changing, but if you have any comments/questions about it let me know and I'll see what I can do.
-q
p.s. A little later in the evening some people got to pushing the robot around: http://www.youtube.com/v/7IszxvWliPA The improved collision recovery software still kept the robot on track. No video of recovery during arc interpolation, but yesterday we also tested that the robot can continue after being completely blocked in a turn. GO TEAMS, and see you all in Atlanta!!!
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-04-2008, 13:19
run the trap!!!
Team Role: Human Player
-q
I would be worried about driving that close to the lane divider. For one thing, your bumpers are probably going to rub on the sides slowing you down slightly, which will create a discrepency between how far your robot thinks it has traveled and how far it has actually traveled.
There's also the problem of running into other robots that are stuck on the lane divider (seems to happen a lot).
-Philip J. Fry
Unread 06-04-2008, 13:25
AKA: Alex
The turn radii can be adjusted easily if need be... they were much wider at midwest and other regionals, true, and if there is a problem with rubbing then we'll make them wider again. The arc interpolation on the turns is not a lookup-table based operation, it's done formulaicly in real time, so changing the radii just means changing the radus for the turn in question in the autonomous script.
Why would the robot have a discrepancy between how far it thinks it has gone and how far it actually has gone if it runs into a robot/rubs the lane divider (not that that's the plan)?
Thanks for the comments!
-q
Unread 06-04-2008, 14:05
run the trap!!!
Well I know on our robot we're using encoders to measure distance. Whenever we started on the side closest to the divider, and rubbed it, the robot would turn too soon and miss the turn.
But when we started from the middle position we never had any problems.
I guess if you get really clever with the gyro you could use it to sense deceleration.
-Philip J. Fry
Unread 06-04-2008, 17:09
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Thats looking good. Kicking the robot in auto is fun isent it. (its one of my favorite activities, right behind starting it in funny positions to see if it can recover )
hope we play each other in Atlanta so we can race...
(we did the same thing with our practice bot (aka Swampthing 07))
http://www.twzdesigns.com/MOV02281.MPG
Unread 06-04-2008, 18:14
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Looks good... knew you guys still had some tricks up your arm.
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 07-04-2008, 07:41
AKA: Alex
Looking good! Is this your 2007 robot in the video? 2008?
If it's your 2008... it would be fun to watch a race!
-q
Unread 07-04-2008, 11:53
AKA: Jonathan
-q
its our '07 bot modified and weighted to match our '08 bot so all speeds and performance are the same.
pic: 1024's Toughened Toughbox Qbranch Extra Discussion 3 19-02-2008 21:01
pic: Shifter Fix Qbranch Extra Discussion 5 06-02-2008 16:32
pic: Q in arctic - nah just in indy - 1024's stompin ground Qbranch Extra Discussion 13 06-02-2007 17:29
pic: Quick fix Ryan Albright Extra Discussion 5 14-03-2005 12:57
pic: FIRST in CT, fix #2 CD47-Bot Extra Discussion 4 28-06-2004 20:40
