Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Go Back   Chief Delphi > Other > VEX
Unread 06-04-2008, 19:33
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Some electrical questions
Hi guys. I would like to use some motors I pulled off an RC car with my vex controller, picture below:
The battery for the car was 6V. I'm assuming the motor would draw the most current when it's stalled, so I "stalled" the motor by holding the gear with a pair of pliers and the current was a little over 1amp.
Is it safe to use the two said motors? I don't want to let out the magic smoke
Thanks in advance,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 06-04-2008, 19:38
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Some electrical questions
The VEX controller outputs are PWM outputs, so you are gonna need a speed controller. You can buy those at hobby shops, and plug it in to the Vex controller.
-Borna Emami
Team 0x27
Unread 06-04-2008, 19:44
Nathan's Avatar
My grand plan was to take the speed controllers off two vex motor modules I have, and then wire a 6V battery to the speed controllers. I assumed this would work.
I found something interesting out. I just did my same "stall" test with a vex motor module and it drew almost 1.4A. I find that surprising since on the vex website it says "Current Draw (+) Power pin 5mA to about 1 Amp. at stall per Motor."
Nathan
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Unless the goal was just on/off/backward, in which case you could use a Digital output. I'm pretty sure there's some kind of power safety, like on the IFI RC, to prevent you from drawing too much current (i.e. imagine a short.)
Jacob
Unread 06-04-2008, 20:05
Nathan's Avatar
Jacob
Nope, I need fine control over the motor speed. PWM is the only way I know to do this, there's no such thing as an analog OUT is there? That would be kind of cool.
Nathan
Unread 06-04-2008, 21:23
AKA: Jacob Komar
Nathan
You could build one, using some resistors (wiki R2R ladder). Then you could have the resolution of 2 ^(how ever many digital outputs you could spare).
That isn't very viable though.
Speed controller sounds the best.
Jacob
Unread 06-04-2008, 21:32
Nathan's Avatar
Well, I connected the signal wire (white) on the vex motor module to my vex controller, hooked up a 6V battery to the positive and negative connections and attached the motor in the above picture but the motor didn't turn and the speed controller got really hot.
Guess that plan is blown
Unread 06-04-2008, 22:50
Nathan's Avatar
I just realized why this won't work. Forgive my stupidity, I'm not an electronics guy.
The motor's speed controller has three inputs, black, red and white. I was hooking up a battery to the black and red inputs and the PWM signal from the vex controller to the white. I now realize that this setup won't work because the PWM cable doesn't have it's reference to ground, is that correct?
Is there any way I can give an alternate source of power to the motor with just these three inputs?
Thanks for the help,
Nathan
Unread 07-04-2008, 11:45
Nathan's Avatar
Alright, common grounded it and victory has been achieved. TY for the replies.
Unread 07-04-2008, 15:46
AKA: Jacob Komar
Glad to hear it!!
Unread 07-04-2008, 20:05
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
http://banebots.com/pc/ELECTRONICS/BB-0309
although i havnt used these before, thay should work for what you need.
Unread 12-05-2008, 20:31
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
I realize I am reviving an old thread, but I was wondering exactly how to connect a vex motor module to a standard pwm off an rc receiver. It only has a output of up to 40ma so I definitely need to wire it up to the battery.
Unread 12-05-2008, 22:13
tseres's Avatar
probably what you just said. i havnt done it before, but i'd splice the motor cord, hook up the power, and then hook the ground and pwm wires to the corresponding ones on the radio reciever.
Unread 12-05-2008, 23:16
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Since pictures usually help me, here is what you need to do:
Also, for those of you that want a laugh.. MS Paint!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 13-05-2008, 10:39
FRC #1595
Thank you. I will try that today.
Rookie Electrical Questions varunsrg Electrical 25 02-02-2008 12:19
two electrical questions mechanicalbrain Electrical 9 11-07-2005 09:41
Lots of Electrical Questions Allison K Electrical 18 18-02-2004 11:49
A Few Electrical Questions GregTheGreat Technical Discussion 16 30-10-2003 20:42
4 Controls/Electrical Questions Mr. Mac OCCRA 1 08-10-2003 05:53
