Re: Banebots 42mm - No Longer Availible!
So much for being a COTS supplier.
Shouldn't there be a clause that a supplier can't do something like that half-way through the season if a company decides to partner with FIRST? That would be like the Trackball supplier phasing out the balls, and saying they aren't going to make them anymore. While a few teams will have problems with lack of Banebots, just wait till a company does this to something that every team uses/needs. Then it'll just go from an inconvienence to some teams, to a huge problem. |
| Banebots 42MM 36:1 Gearbox Ratios | Madison | Technical Discussion | 11 | 26-02-2008 19:42 |
| Banebots 42mm gearbox: Recommendations for use | Joe Johnson | Motors | 61 | 01-04-2007 15:28 |
| REQUEST: Banebots 42mm 256:1 at LoneStar | Kevin Sevcik | Motors | 0 | 27-03-2007 22:07 |
| Banebots 42mm grease? | Kevin Sevcik | Motors | 2 | 23-03-2007 19:23 |
| BaneBots 42mm Gearbox Pinion | Gary Bonner | Motors | 1 | 31-01-2007 13:44 |
