Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 07-04-2008, 22:04
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
3 1/2inch CIM motor info
I need to find the RPM of it aqnd how much energy it puts out.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 07-04-2008, 22:44
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 3 1/2inch CIM motor info
My wife always accuses me of being a pack rat... I've no idea what she is talking about.
Mark
Brick walls are for other people. - Randy Pausch
Unread 07-04-2008, 23:05
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
The motors curves are on page 5 of the 2008 FIRST Guidelines, Tips, & Good Practices.
Like all motors the RPM's depend on the torque load. Since you can power this motor from at most a 40 amp breaker, if you want to run continuously your torque load will need to be about 100 oz-in and your RPM with that load will be about 3800 RPM. Your mechanical power will be about 280 watts with an efficiency of about 59%. Your motor will produce about 200 watts of heat, same as two 100 watt light bulbs.
Energy is POWER x Time. So the energy produced (really converted) by the motor is a function of how long you run it. Since 1 Watt is 1 Joule per second, the mechanical energy you can get is about 280 joules per second.
The motor has a maximum power of 337 Watts but at that level you would be drawing 68 amps and pumping .8 kilowatts 1/2 of which will come out as heat. Since this would be a 170% load on the breaker, you could probably do this for maybe 5 to 10 seconds before popping the breaker. You will see max power on this motor with a torque of 172 oz-in and with that load your RPM will be about 2670 until your breakers pop and it drops to zero.
All of the above are at 12V, roughly equivalent to fully charged battery and minimal other loads. Since a 68 amp will pull down the battery voltage, you will not likely get much more than about 280 watts from a single CIM.
SORRY - ALL OF THE ABOVE IS FOR THE CURRENT YEAR CIM. You do know that the big CIM's from last year are not
legal for competition.
The "PIMP" CIM's will draw 40 amps with a torque load of 230 oz-in and with that load will turn at 1500 RPM. This equates to 255 watts and an efficiency of about 53%.
Unread 08-04-2008, 06:41
That guy
AKA: Dennis
thank you very much, this is exactly what i needed. See we are going to use one to make a peddle power generator, if it's worth using to charge batteries at our local Relay for Life. Also it will show off new energy (although this is not very practical =P)
Unread 30-04-2008, 18:24
motosaurus motosaurus is offline
motosaurus is an unknown quantity at this point
Did you build that pedal powered generator?
How did it work, I am thinking of one for an electric bicycle-like thing.
John
Unread 30-04-2008, 18:32
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Well... if I were you I'd take that acusation as a compliment. I lost my copy of this PDF somehow and... *plays Reunited* well, I'm glad we're back together.
Thanks Mr. Gearhead! Amazing what you run in to when you aren't looking for it...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 30-04-2008, 21:15
kramarczyk's Avatar
Need the missing DeWalt trans CAD or some old kitbot documentation? I can't seem to find that 20 minutes of the Nixon tapes though.
Mark
Unread 30-04-2008, 21:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
It was 18.5 minutes, and I can't find 'em, either.
Richard Wallace
since 2003
Unread 01-05-2008, 08:56
kramarczyk's Avatar
Mine was a copy, so it must have had some extra on it.
Mark
CIM motor heatsink Woody1458 General Forum 7 20-02-2008 11:09
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
CIM Motor Count Tobaby817 Motors 2 27-01-2006 11:58
I Need Brackets For Cim Motor .....anyone who can provide me any info .. ? monal_pa Kit & Additional Hardware 2 25-10-2004 14:16
