Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 08-04-2008, 17:16
drewjones13's Avatar
drewjones13 drewjones13 is offline
drewjones13 is an unknown quantity at this point
Festo Wiring with a spike
Hello I have a question about the wiring of the white festo to a spike. I have it wired where the positive goes to the M+ and the negative goes to the M- and I do have it wired correctly according to the festo diagram. I have the positive wired to positive and the ground wired straight to ground. Is there anything that I am doing wrong? The spike clicks as if it works properly yet the festo wont work.
Unread 08-04-2008, 17:38
dtengineering's Avatar
AKA: Jason Brett
Re: Festo Wiring with a spike
This might help. Although it sounds like you already have the references that you need.
I am assuming you are using the valve with a pressure greater than 30psi? (see note 1 on linked page). I also assume that you are using the spike in the forward and off, as opposed to forward and reverse settings. (Although doing the "direct to a battery" test kind of takes care of that issue...)
Aside from that... I have had good luck with these valves over the years so I don't have a lot of trouble shooting suggestions, sorry.
Jason
Unread 08-04-2008, 19:58
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
We had the same thing happen to us, the spike was good, it was getting powered, and it worked manually. A lot of people have had bad luck with Festos. We got another one at the MN regional from St. Anthony High School I think (can't remember the number) and it turned out that one had failed too.
To sum that all up, it could be just a bad festo.
Unread 08-04-2008, 20:43
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
"I have it wired where the positive goes to the M+ and the negative goes to the M- and I do have it wired correctly according to the festo diagram. I have the positive wired to positive and the ground wired straight to ground."
I'm not sure what the "festo diagram" for FIRST has in the way of wiring (I guess I could look it up), but when linking most power coils to a relay such as a Spike, you should include a diode across the terminals of the valve coil. Back EMF from firing the coil can actually produce a momentary static voltage higher on the negative side that will not let current flow so the pilot valve in the Festo won't actuate.
If you install the diode across the terminals, make sure the white line on it is on the "+" terminal. For that valve, the coil is very small, so any of the small
diodes at Radioshack will work fine.
If this doesn't help, the valve may be bad, but that is doubtful, FESTO are very high quality products.
BOB
Unread 08-04-2008, 20:44
pitzoid's Avatar
AKA: BOB
posted twice
Unread 08-04-2008, 20:55
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Our team had very bad luck with Festo valves. The valve worked manually, and when we hooked it up to a spike, the light came on, but nothing happened. So we sent it back and got a replacement. The replacement didn't work either.
You'll have much better luck with the SMC valves.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 08-04-2008, 21:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I may be that your tubing is hooked into the valve incorrectly, therefore the valve does not have enough working pressure to work.
For us, the input is "1"
"3" and "4" go to the pneumatic cyllinder.
You never know, someone may unhooked it then accidentally hooked back up incorrectly. Charge the pneumatic system to 60 psi, then test. If not, then try a new spike.
GitHub
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Team 1523 had an issue with the Festo values at FL Regional. It turns out that the relay coil was open inside the valve,
Measure the resistance between the coil pins, We got three defective solenoids from parts supply before getting a working unit from another team.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 09-04-2008, 09:05
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Originally Posted by lasereyes View Post
.......... The valve worked manually, and when we hooked it up to a spike, the light came on, but nothing happened. So we sent it back and got a replacement. The replacement didn't work either.
I have seen this also. I took the Festo wiring connector off and tested each pin on the valve with a + and - wire straight froma battery. You need to have air connected and greater than 30 psi. When I found the combination that caused the valve to operate, I rewired the connector to match. Sorry, I did not check to see if it matched the official wiring diagram.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 09-04-2008, 11:25
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
You may wish to refer to this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=66171
Unread 10-04-2008, 07:29
2175 College Mentor
AKA: Alex Miller
There should be a little light on the festo that will light up when activated. See if you can see that.
2 FESTO valves on 1 spike bhsrobotics1671 Electrical 12 08-02-2008 13:37
Using a spike with a VEX controller? AdamHeard VEX 2 20-11-2007 10:26
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
trouble with assembling FESTO valve geo Pneumatics 15 02-02-2003 09:28
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
