Go to Post But I suppose friendly reminders to read the manual are much better than sarcastic ones. - dtengineering [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 29-03-2008, 21:10
zim2411's Avatar
zim2411 zim2411 is offline
AKA: Peter Harris
FRC #1727 (Rex 1727)
zim2411 is a jewel in the roughzim2411 is a jewel in the roughzim2411 is a jewel in the rough
Wireless Router Issues
At Philadelphia we had our scouting system up and running for everyone to use. We constantly ran into issues with our router crashing however. We used a Linksys WRT54G with dd-wrt firmware. Stock settings are to hand out 50 dhcp addresses, which we hit midday Thursday I think. I upped it to 250 maximum users, but we started running into issues with the Wi-Fi just dropping out of existence (no one's device could find it). We had a few things hardwired into the router, and they continued to function normally. We had about 70-80 DHCP entries around this time.
Is the issue with the router handling too many DHCP users? Would running the DHCP server on a computer behind the router, thus making the router function only as a access point/switch? Or can a WRT54G absolutely not handle this traffic load?
Is there any wi-fi system that is more powerful?
Unread 29-03-2008, 21:58
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: Wireless Router Issues
hmm.. dd-wrt, means you are using a v5 router which has only 8mb ram and 2mb flash?
You'd be better off with an older one which has more flash ..
But if you are thinking of serving a whole arena of users (probably > 250) I think you will be better off with a linux box giving out serving DHCP on class A or B subnets, with the router merely bridging your wireless and wired interfaces (i.e. disable internal dhcp).
The number of requests / flows may also be maxing out its ram.
| jamesyong.net |
FVC2007, FTC2008
Unread 29-03-2008, 22:23
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Generally, more than about 25 associated clients on a single access point will start to lead to problems. This is true for higher-end AP's as well. The number of DHCP entires or MAC entries are unlikely to be limiting factors.
You might see a somewhat greater number of simultaneous users if you run in G only mode.
If you want to increase the number of connected clients, you could run 3 access points on the non-overlapping channels 1, 6, and 11, and route them on the WAN side of the 3 WRT54G's.
Unread 08-04-2008, 22:08
zim2411's Avatar
AKA: Peter Harris
Yeah.. but running in G only mode limits the range. If you are far away enough that it drops to even 36mbps, the router won't serve you anymore. (Or that's what my testing in the past proved)
I have a v2 WRT54G, so it is with 16mb of RAM. I just upgraded to dd-wrt v24 RC 6.2, and I'm going to try and disable as many functions as possible. It's impossible to test until we get to an event though
Unread 08-04-2008, 22:54
While I was reading the Championship Essential Information I noticed that it asks people not to set up wireless networks at the Championship.
Unread 09-04-2008, 02:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I <3 the DD-WRT firmware. It does wonderful things traditional router firmware cannot. I've used it on a WRT54G v7 and it would use up about 94% of the memory just idling. So, perhaps you are hitting the upper limits of your memory?
Unread 09-04-2008, 12:52
deus ex programmeur
AKA: James Yong
FTC #0747
Tomato firmware rocks too
| jamesyong.net |
FVC2007, FTC2008
Unread 09-04-2008, 14:18
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
You can try wiring a second router behind the first router to ease the load instead of having a computer.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 09-04-2008, 15:10
zim2411's Avatar
AKA: Peter Harris
Bad link. In the past I know teams have setup their own access points at Championship. The manual explicitly says not to arrange for Internet access while at an event... could you find where it says no wireless networks?
I'm going to try using a gigabit switch with two wireless access points connected, and either a computer or a wired router giving out DHCP addresses. This way, all wireless connections are split between the access points, and all traffic goes through the switch - which should be more than capable of the load.
Unread 09-04-2008, 15:27
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Wireless Networks
Teams will not be allowed to set up their own wireless networks at the Championship. While we certainly
appreciate the positive potential team-created wireless networks could represent, there is a chance such
wireless networks could interfere with planned activities during the event.
I am similarly disappointed by this, as The Blue Alliance was going to have TBATV installs set up in each of the divisions to provide hopefully seamless coverage in the pits.
Team 177 - Bobcat Robotics
Unread 09-04-2008, 15:32
zim2411's Avatar
AKA: Peter Harris
Do you know if this is for the stands, the pits or the entire event? This really kills our scouting system then...
Unread 09-04-2008, 15:47
Although I believe this 'rule' covers the entire event (Stands + Pits), I don't see where you would get power to run one in the stands anyways, as I am pretty sure there is no AC easily accessible.
That being said, I don't think they would mind an ad hoc wireless network being run in the stands, which ought to work for a scouting system.
Unread 09-04-2008, 16:02
zim2411's Avatar
AKA: Peter Harris
Yeah that should work in the stands for match scouting, but for team scouting we rely on a server in our pit with clients connecting + entering info.
Unread 09-04-2008, 16:15
Yes they would! An ad hoc system is equally "disruptive" as one based around a router. Also, the stands are probably worse than the pits for such activities, as they are closer to the fields.
I'm not sure why they are showing negative love for the WiFi, but please respect their decision.
Unread 09-04-2008, 16:30
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
This could be because maybe FIRST is doing a frequency study for the new control system.
If FIRST decides to go with 2.4 Ghz for the new control system, it could spell the end for all team owned WI-FI networks at events.
"One day you will come to a fork in the road. And you're going to have to make a decision about what direction you want to go." Boyd raised his hand and pointed. "If you go that way you can be somebody. You will have to make compromises and you will have to turn your back on your friends. But you will be a member of the club and you will get promoted and you will get good assignments." Then Boyd raised the other hand and pointed another direction. "Or you can go that way and you can do something for your country, your Air Force and for yourself. If you decide to do something, you may not get promoted and you may not get the good assignments and you certainly will not be a favorite of your superiors. But you won't have to compromise yourself. You will be true to your friends and to yourself. And your work might make a difference. To be somebody or to do something. In life there is often a roll call. That's when you will have to make a decision. To be or to do? Which way will you go?"
[IMG] code is Off
Bypassing router Mark Rozitis IT / Communications 17 13-12-2007 18:06
Wireless Gamepads lazyxninja Control System 1 27-01-2007 15:35
Help with VPN router Scott L. Technical Discussion 4 10-07-2006 13:33
2 Wireless routers MattK Chit-Chat 7 02-06-2004 20:46
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
