Go to Post The kit of parts is a hundred yards of denim. - StuartV. [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
So you want to stall a Globe Motor...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/17/2000 6:55 PM MST
I have just performed an experiment that I had intended to do before I published the Applicaton Notes, but ran out of time.
Basically, I have a recomendation for teams that want to stall a Globe motor but can't do it with the stuff in the kit.
Here is how.
Use a Ruland Rigid Coupling to connect the short Globe motor shaft to a longer 1/4 inch dia. shaft. Then use TWO Trantorques to connect ONE sprocket to this extended shaft. The combination of the two Trantorques provide enough grip to the 1/4 inch shaft to stall the Globe motors.
This trick can be used any time you want to provide more twist to a 1/4 inch shaft than a single Trantorque can provide. I was surprised at how well this worked.
What you do with that extra torque is up to you.
Good Luck.
Joe J.
P.S. I will put a picture of my experimental set up in due time.
#0047 (ChiefDelphi)
Re: So you want to stall a Globe Motor...
Posted by Raul.   [PICTURE: SAME | NEW | HELP]
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 10/24/2000 11:23 AM MST
In Reply to: So you want to stall a Globe Motor... posted by Joe Johnson on 10/17/2000 6:55 PM MST:
I thought the coupling was only rated for 30 to 60 in-lbs? If so, how can it transmit the stall torque?
Raul
[IMG] code is Off
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
Globe Motor and Thermal Protection archiver 1999 0 23-06-2002 22:03
Globe motor specs patrickrd Motors 1 06-01-2002 20:50
Help! Need a Globe Motor Dodd Motors 0 24-07-2001 11:57
