Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Unread 27-09-2001, 08:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What every team needs. . .
I'm sort of getting tired of reading about the qualification process. We'll all live with it and get used to it, whether or not we love it or hate it. Some fine suggestions have been made by people far more level headed than I, and I hope FIRST reads them and thinks about them.
Now, with that said, I'd like some help
What do you all think is absolutely necessary for a rookie team to have? I'm looking for anything here; hand tools, power tools, whatever. . .
Immediately, what jumps to mind is:
Screwdrivers
Ratchets (Metric and Standard)
Power Drill
Jigsaw
Rivet Gun
Wire Tie Gun
Hack Saw
Belt Sander
Soldering Gun
Wire Stripper
Crimping Tool
Pliers of all sorts
Vice Grips
Calipers
Tape Measure
Circular Saw
Chop Saw
Bench Grinder
Loc-Tite
Toolbox
Well, that's enough for now. Is there anything super important I'm leaving out?
Christina and I have some money from our College of Engineering and Applied Sciences, and our high school has nothing to speak of. They didn't even know what FIRST was, really, until Tuesday morning.
We have access to the University's manufacturing and machining capabilities, but we're still going to need tools for small fixes and things at the competition site. If it's possible, I was thinking about using some of our money to get them started with tools and stuff.
Also, while I'm rambling. . . my high school (263 - Sachem Aftershock) had a platform donated to them a few years ago. They attached it to their cart, and it uses a hydraulic scissor lift to easily raise and lower the robot. Does anyone know where we can find one of these?
--Madison--
...down at the Ozdust!
Unread 27-09-2001, 09:08
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Some other things you might consider:
Extra fuses, relays and speed controls
Extra screws, nuts and washers
Heat shrink tubing and heat gun
Dremel tool and bits (grinding, drill etc...) comes in real handy
Electrical tape
A set of nut drivers
Allen wrenches (metric and SAE)
Hope this helps
Let me be the first one to say good luck to your team
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 27-09-2001, 09:30
Scott Wolfe's Avatar
Scott Wolfe Scott Wolfe is offline
#0470 (Alpha Omega Robotics)
Scott Wolfe is an unknown quantity at this point
Send a message via AIM to Scott Wolfe Send a message via Yahoo to Scott Wolfe
Robot Cart Lift
We got our lift cart from Grainger. You can check out their website www.grainger.com and order it online. One suggestion, make sure you get big enough wheels to get over all of the wires, cables , and bumps at competitions! We had to retro-fit big tires onto ours, now it's a beast but weighs almost as much as the robot! Best of luck!
Unread 27-09-2001, 22:38
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
organization!
One of the things every team should have is a small, organized toolbox which can be carried onto the floor. If you get to the finals the rounds come quick and frantic so you have no time to go to the pits and find your tools.
We try to standardize as much of the hardware as possible. Parts which wear out easily are replicated and kept in the carry out box. Wire and zip ties too. Rember extra chain master links if you use chains. We use a tote tray with small drawers below- the tray holds 2 batteries as well and we have one person assigned to keep the tray handy and the batteries fresh.
We have also begun to add an extra spike relay and speed controller into our bank on the robot itself. If one blows at a critical time it is a simple thing to switch the leads and get back into play. One of the worst experiences we had in 2000 was blowing a spike relay in the finals at Epcot and frantically navigating the crowd to the pit for one. Delphi jumped in and gave us one and we are really thankful for that.
Also- mark your tools well because there tends to be a lot of loaning of stuff around the pits and some may never return. Not deliberate pilfering (I hope) but in the mess all tools look alike!
Unread 28-09-2001, 11:17
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
One suggestion: if you use allen bolts, use the same size wrench for as many of them as possible. It's easier when you only have one size of allen wrench to worry about. That way, you don't have to try 4 different sizes of wrench to find the right one.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
