Go to Post You know you've made it big when people assume every imperfection is genius! - araniaraniratul [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Center Square Rack Scoring
Posted by Josh.
Engineer on team #247, Da Bears, from Berkley High School and Camou PICO.
Posted on 10/18/2000 9:30 AM MST
What is the scoring on the center square rack? If you have the rack on your side and there are points in there, does it double those or your whole score?
#0047 (ChiefDelphi)
Re: Center Square Rack Scoring
Posted by Pat.
Student on team #101, STRIKER, from St. Patrick High School and LoDan Electrtonics.
Posted on 10/18/2000 9:47 AM MST
In Reply to: Center Square Rack Scoring posted by Josh on 10/18/2000 9:30 AM MST:
The packet says that the center rack doubles you whole score.
#0047 (ChiefDelphi)
Rack only doubles -- Balls in ramps do the scoring
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/18/2000 10:36 AM MST
In Reply to: Re: Center Square Rack Scoring posted by Pat on 10/18/2000 9:47 AM MST:
The rack is only a doubler.
Balls in or out of the rack are not material to the score.
The only way to score is to put balls into scroring position on the ramps.
If you have the square rack on your side at the end of the match, your score from the balls will be doubled.
Is this clear?
Joe J.
[IMG] code is Off
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Center Scoring Rack archiver 2000 1 24-06-2002 00:10
Square Rack Sketch archiver 2000 1 24-06-2002 00:09
KSC Results archiver 2000 2 23-06-2002 22:19
