Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 08-04-2008, 20:50
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
What is wrong with this part
Im really confused about this part. Sketch one needs two more dimensions except I have no idea what the sketch actually needs. There might be some lines that Im missing which can be causing the problem but beyond that I have no idea what the missing dimensions can be.
Unread 08-04-2008, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: What is wrong with this part
Hard to determine without Inventor loaded...
Unread 08-04-2008, 22:45
zachjo's Avatar
zachjo zachjo is offline
Shake 'N' Bake
FRC #0171 (Cheese Curd Herd formerly Extreme Engineering)
zachjo is a jewel in the roughzachjo is a jewel in the roughzachjo is a jewel in the rough
I am not sure that you have any problems with this part. I opened it and there were no errors. Looks like a solid square bar with two holes drilled on the two long sides. What is the part supposed to be?
Unread 08-04-2008, 22:54
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
I opened it as well and found nothing wrong with it...
Unread 08-04-2008, 23:07
Bethany Mc.'s Avatar
Bethany Mc. Bethany Mc. is offline
Fantasy FIRST Champion 2010
AKA: girl w/ the green fringe intertube/trackball dress
FRC #2996 (Cougars Gone Wired)
Bethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of light
Send a message via AIM to Bethany Mc. Send a message via MSN to Bethany Mc. Send a message via Yahoo to Bethany Mc.
Well what are you trying to do with this part. If you are trying to make it fully constrained, all you need to do is add a fixed point, and sketch 1 will be constrained. Other than that it looks fine. If you state what you are trying to do with the part, I might be able to help with greater detail.
~*~BaM BaM~*~
19th Annual Del Tech Drafting Winner 2008 in Inventor!
Robo Prom Queen 2008- thanks 399
Attending 2011:
Florida
St. Louis
Unread 08-04-2008, 23:52
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I opened it up and it looks fine. Do you just want to get rid of the sketch?
If so, all you have to do is go under extrusion 1 and extrusion 2 and right click on the sketches and click on visibility.
More information will help us help you.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 09-04-2008, 08:13
Adam Y.'s Avatar
Adam Y.
no team (?????)
Thanks. I was trying to fully constrain the sketch. Now why did I need to do that for my one part and the two other parts which are essentially the same drawing?
Unread 09-04-2008, 08:39
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Sketch1 is not constrained to the origin.
Read this document http://home.pct.edu/~jmather/AU2007/...7;20Mather.pdf
especially Tips 8-22
here is your fixed part. Later when I get a chance I will post another part the way I would have done it.
I do not grade student work that Sketch1 is not fully constrained.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 09-04-2008, 23:53
Well if you want a fully constrained part, you must have a fixed point, or a demesion based off of the orgin. I'm not sure why you didnt need to place a fixed point on the other two parts. I would need to look at them.
~*~BaM BaM~*~
Attending 2011:
Florida
St. Louis
Unread 10-04-2008, 00:36
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
I agree with the above posts saying that you are under constrained. Many people, however don't understand why you need to fully constrain your part. The main reason you constrain off the origin is that it allows you to constrain your assemblies easier. Rather than constraining off a side you can constrain off your planes which allow for easier changes (and alot less mental math) later. Also doing this allows easier use of the parameters feature in Inventor. Parameter allow you easily change dimensions of a part and when based off the origin it just gets easier. The easiest way to constrain your part is to go into the 2-D Sketch Panel>Project Geometry then click the two axis you want from the origin tab of the model panel. All thats left is to dimension your part off that.
Hopefully that was helpful,
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 10-04-2008, 08:18
JD Mather's Avatar
Here is how I would have done the part. Notice that the Feature tree is much more simple.
And note: The holes you used for a 4-40 UNC screw are too big - the screw will fall into the hole as there will be no threads. The screw diameter is .112 and your hole diameter is .112, thus no thread engagement. The correct tap drill size for a 4-40 UNC is a #43 drill (.084"). If you use the Hole tool to create your tapped holes Inventor will automatically assign the correct tap drill size.
Unread 10-04-2008, 20:36
Adam Y.'s Avatar
Adam Y.
no team (?????)
-Pat
Yes it was. I originally had a hunch that it had something to do with the constraining off the origin because I read it in a tutorial. The only problem was the tutorial mentioned it in passing.
Thanks that is much simpler.
Something wrong with this picture sanddrag Chit-Chat 2 30-04-2006 12:41
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
Whats wrong with this code? Morgoth Programming 4 19-01-2003 11:45
Buckeye Regional - Something wrong with this picture!! & update ColleenShaver Regional Competitions 2 17-03-2002 12:51
okay what the heck is wrong with me Zeinin Chit-Chat 8 16-01-2002 13:09
