Go to Post The only fee our team charges is for your heart and soul. No refunds. - Koko Ed [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:11
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Out of bounds...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/20/2000 8:43 AM MST
In Reply to: disqualified? posted by Suzy on 10/20/2000 6:46 AM MST:
Question:
If your team picks up the rack and 'carries' it to your teams side and you happen to swing the rack out of bounds (but you are still holding onto it and you are in bounds) will you be disqualified?
Answer:
Disqualification is not even an issue in this situation. Disabling is a possibility but not Disqualification.
Now to the specifics. If your robot applies force to the ground outside the field, your robot is subject to being disabled. If it applies that force via a ball or its arm or the square rack it is all the same with respect to this rule.
If the square rack is touching the ground outside the field at the end of the match, it will not count as a doubler.
Clear?
Joe J.
[IMG] code is Off
What.. animation disqualified!!! brokenleftthumb 3D Animation and Competition 35 04-04-2003 19:10
Disqualifications archiver 1999 13 23-06-2002 21:53
