Go to Post I don't think finding a way to defend the center goals is un-Gracious Professionalismistic (wow). - Sachiel7 [more]
Unread 10-04-2008, 17:15
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: FRC 1771 Swerve Module
Unread 10-04-2008, 17:16
Aren_Hill's Avatar
Build Nifty Things
Re: pic: FRC 1771 Swerve Module
that looks familiar.....
A guy who likes robots.
Unread 10-04-2008, 18:50
AKA: Sean
It is somewhat similar. The big difference would be in how ours is all assembled by bolts or rivets versus yours is welded. Im working on a new revision now. How are you keying your wheels. Im planning on making wheels like that for next year.
Mentor 2415
Unread 10-04-2008, 18:52
Aren_Hill's Avatar
Build Nifty Things
all axles on our swerve are 7068 alum. hex, with the sprockets and bevel gears hex broaches and the axles held in by snaprings.
Unread 10-04-2008, 19:43
AKA: Sean
Cool. Specifically what is on the wheel to take the hex shaft. Look for the second revision in a little bit
Mentor 2415
Unread 10-04-2008, 20:21
Aren_Hill's Avatar
Build Nifty Things
the wheel has 2 pieces of .75" o.d. aluminum round 6061 with a 3/8ths hex broached in it. those 2 pieces are welded onto the waterjetted wheel sideplate
Unread 10-04-2008, 21:34
sorry to be a total noob, but what motor do u use to drive? or any drawing of the inside or an exploded view would be awesome. Thanks.
Unread 10-04-2008, 21:50
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
they use the cims in the other chassis picture with chain travelling to the modules to drive the wheels. Inside, there are just bevel gears going from the vertical shaft to the shaft the higher side sprocket is mounted on.
Unread 11-04-2008, 01:45
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
I'm considering a swerve drive for next year, but I've been having trouble finding hex shaft and sprockets that match. The only place I really know to look is McMaster. Where did you guys get yours?
Unread 11-04-2008, 08:54
hillale's Avatar
AKA: Alec Hill
We had a local sponsor make us custom 7068 aluminum hex shafts to fit the sprockets.
Unread 11-04-2008, 13:29
AKA: Sean
I am using 2 cims into a custom gearbox per side. It is a single speed transmission. Also the best way to get sprockets to match hex is to buy plain dore sprockets and broach them into a hex. Hex stock shaft is very cheap and can be bought at mcmaster.
Mentor 2415
Unread 11-04-2008, 13:32
AdamHeard's Avatar
Lead Mentor
However, 7068/7075 hex shafts that some teams are using have to be custom made.
Unread 11-04-2008, 13:37
AKA: Sean
Is 7068 or 7075 really necessary for a hex shaft that is short in length and supported on both ends. I would think that it would be plenty strong enough since you dont have to worry about a keyway.
Mentor 2415
Unread 11-04-2008, 16:28
AdamHeard's Avatar
Lead Mentor
I really doubt 6061 hex shaft would hold up in that situation; I haven't run the numbers, but I doubt it would work well in a place like the shafts in a drive.
Unread 12-04-2008, 00:14
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
In the picture above, of the module with a blue wheel, I was wondering how those sprockets drive the shafts. It doesn't look too me like they're hex, or keyed.
pic: 1625's swerve module (better pic) Aren_Hill Extra Discussion 25 22-07-2008 19:14
pic: FRC 1771 Swerve sdcantrell56 Extra Discussion 5 10-04-2008 16:17
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
