Go to Post Being a mentor only requires an open mind and fifty thousand times more responsibility. - Amanda Morrison [more]
Go Back   Chief Delphi > Competition > Championship Event
  #61   Spotlight this post!
Unread 10-04-2008, 14:37
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: FTC World Championships
Originally Posted by astephen68 View Post
On the map the da vinci is where the fll championship is going on right , unless ftc is there too?
From past experience, FLL is generally on Einstein.
FRC78: 2010-Present
FRC121: 2002-2009
  #62   Spotlight this post!
Unread 10-04-2008, 14:40
astephen68's Avatar
astephen68 astephen68 is offline
Build, Scout, Drive
AKA: Stephen
VRC #0478 (Mustang Robotics)
Team Role: Scout
astephen68 is just really niceastephen68 is just really niceastephen68 is just really niceastephen68 is just really nice
Does anybody know though what are the teams who qualified for Atlanta?
Soutern Ontario Championship
-Finalists
-Winners of the Drivers Challenge
-Finalists
  #63   Spotlight this post!
Unread 10-04-2008, 14:41
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Originally Posted by corpralchee View Post
Anyone else worried that they may have placed the fields too close together? Presumably there will be matches going on at the same time right? With the fields this close together I'm worried that people in the audience will get confused between announcers and fields. Also there is the crystal problem... I was expecting them to keep the fields far apart to minimize interference.
OR are they still only going to run one match at a time, just with four fields...
I suspect they will be running 2 matches simultaneously while queueing for the other two fields. The announcer may be announcing two fields at the same time....
One match at a time with 4 fields sounds much too inefficient for me.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
  #64   Spotlight this post!
Unread 10-04-2008, 15:56
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
I originally expected 2 matches at a time. However I also was expecting that the fields would be spread out some more...
Woot 100th post on CD!
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #65   Spotlight this post!
Unread 10-04-2008, 23:04
The Lucas's Avatar
CaMOElot, it is a silly place
The 2 announcer thing worked surprisingly well in NYC from what I saw. Trust me, you have some quality announcers They'll make it work.
Anyone else think they should have named the fields Edison and Tesla? Then they could play AC/DC's Back in Black like a dozen times
Robot Inspector
  #66   Spotlight this post!
Unread 10-04-2008, 23:37
AKA: Bates
FRC #0125 (NUTRONS)
So was the NYC tournament a primer/practice for the Atlanta Championship.
  #67   Spotlight this post!
Unread 11-04-2008, 00:20
Good luck to team 74 Team Overdrive. I will be cheering for you guys while in the FRC pits.
  #68   Spotlight this post!
Unread 11-04-2008, 08:34
astephen68's Avatar
Build, Scout, Drive
AKA: Stephen
Team Role: Scout
Wouldn't 4 matches at a time be more efficent and 2 matches while queing sounds right too but it's big enough to do 4 matches, why wouldn't they do that?
-Finalists
-Finalists
  #69   Spotlight this post!
Unread 11-04-2008, 08:37
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
You'd be running 4 matches which takes about 3-4 minutes, followed by at least 3-4 minutes downtime while you're switching between matches. Alternating fields, during the 3-4 minutes that 2 matches are running, the other two fields are doing reset. Same throughput (total number of matches run per hour), but there's some action going on nearly continuously. You're not stuck watching reset.
(since 2004)
  #70   Spotlight this post!
Unread 11-04-2008, 08:40
ttldomination's Avatar
Sunny
Have they posted the FTC divisions yet???
I'm lookin forward to that.
1648: 2013-2014
5283: 2015
  #71   Spotlight this post!
Unread 11-04-2008, 12:25
astephen68's Avatar
Build, Scout, Drive
AKA: Stephen
Team Role: Scout
Very true, Ok so 2 fields running at the same side and the fields are located on the map where a vinci is right?
-Finalists
-Finalists
  #72   Spotlight this post!
Unread 11-04-2008, 12:50
AKA: Bates
FRC #0125 (NUTRONS)
Correct.
  #73   Spotlight this post!
Unread 11-04-2008, 13:07
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Just an FYI to everyone: The FTC Opening Ceremony is scheduled to be from 12:00-12:30 on Thursday... The same time as the Chiefdelphi Webhug.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
  #74   Spotlight this post!
Unread 11-04-2008, 17:09
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Ok team list out and what division you will be in.
Division Team Number Team Name
Franklin 1 Team Unlimited
Franklin 3 Mr. Roboto & SuperPals
Franklin 6 Driven Nuts
Franklin 8 Exploding Bacon
Franklin 13 ACME-Sand Blasters
Franklin 22 100 Scholars
Franklin 25 Rock-n-Roll Robots
Franklin 31 E.M.P.
Franklin 37 19 Below
Franklin 39 Zip Ties
Franklin 63 The Rebels
Franklin 67 EAST Bots
Franklin 92 Junior Bomb Squad
Franklin 118 Steel Hornets
Franklin 125 Northgate Robotics
Franklin 154 Renegade
Franklin 175 Checkmate
Franklin 177 Twisted Bots
Franklin 183 Metal Jackets
Franklin 197 Rams
Franklin 201 Brophy College Prep
Franklin 270 Apollo
Franklin 339 1114 Simbotics
Franklin 350 CybotronX
Franklin 356 Gigabots
Franklin 414 Bluffton Bolts
Franklin 420 Duckt Tape
Franklin 450 Children of the Swamp
Franklin 474 Team NOS
Franklin 477 Team Newbies
Franklin 482 Devilbots
Franklin 506 Pandara
Franklin 519 Epsilon Delta
Franklin 542 WHS Robotics
Franklin 567 Cheesy Poofs
Franklin 597 Papa Smurf
Franklin 603 S.W.A.T.
Franklin 613 MiniStang
Franklin 628 Robotroopers
Franklin 662 Brooklyn Mustangs
Franklin 679 RoboRaiders
Franklin 721 Gladstone
Franklin 733 Grady Gearbox Gangstaz
Franklin 747 Singapore SMART
Franklin 754 Autonomous Anonymous
Franklin 760 Rocky Mountain Tics
Franklin 767 Riptide Rush
Franklin 783 Riveted Steel
Franklin 800 Plenus
Franklin 802 Sweetch Yaocalli
Edison 2 Psychotic Strawberryz
Edison 4 Driven Bolts
Edison 7 TechBrick
Edison 12 ACME-Weather Makers
Edison 14 Vexy Things
Edison 23 Northrop Grumman Space Technology
Edison 30 Mr. T
Edison 32 Einstein's Daughter
Edison 38 Vexellent
Edison 52 Sahuarita High School
Edison 64 Occam's Engineers
Edison 74 Team Overdrive
Edison 110 MFS Foxes
Edison 120 Angelbots
Edison 136 Berkner Robotics
Edison 159 the Holy Rollers
Edison 176 Pigmice Vexed
Edison 179 Team Robot Rebels
Edison 189 Blizzard B
Edison 199 The Crushinators
Edison 211 RoboDogs
Edison 306 Lords of the Rings
Edison 349 NNSRI
Edison 355 Robo Gophers
Edison 368 Faberians
Edison 418 Exothermic Robotics 2
Edison 434 Uh-Oh's
Edison 466 Mustang II
Edison 475 Team Infinity
Edison 478 Mustang Robotics
Edison 500 Spontaneous Combustion
Edison 508 PiraTech Robotics
Edison 529 CocoNuts
Edison 548 Geek Squad
Edison 589 Hammered Steel
Edison 600 SHIRT
Edison 604 pwnage
Edison 614 Met Liberty
Edison 655 Rhode Rage
Edison 676 GSMST Beta
Edison 710 3 Brothers & Wesly
Edison 722 Vexagon Gladstone
Edison 738 Green Egg Robotics
Edison 752 BA Robot
Edison 757 Suburban Legends
Edison 761 Piecebots A
Edison 782 Stainless Steel
Edison 791 BRHS Warriors
Edison 801 Panteras UP
Edison 85 Eagle Engineering
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
  #75   Spotlight this post!
Unread 11-04-2008, 17:41
Sunny
Where'd u get this?
If i were to go on the FIRST site somewhere???
And i don't see Simbiotics on there...does anyone know what team number they are?
1648: 2013-2014
5283: 2015
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: Two Divisions at FTC World Championships! KathieK FIRST Tech Challenge 0 05-02-2008 15:31
[FTC]: 2008 FTC World Championship volunteers needed KathieK FIRST Tech Challenge 0 20-01-2008 21:54
Volunteer at FVC World Championships KathieK FIRST Tech Challenge 0 22-12-2006 17:33
Nationals? Why not World Championships? Joe Menassa Championship Event 23 14-03-2003 00:12
